Old Mar 22, 2005, 07:58 PM
foo972 is offline
Find More Posts by foo972
Joined Jan 2005
Rave
any ideas for a 3 channel foam plane 400 motor
hey guys like some help
i have 2 naro servos and a c geared 400 motor and i want to make a foamy using this stuff
i want a plane just to fly around the yard while i charge my batteries for my other planes
please any help
kevin
foo972 is offline Find More Posts by foo972
Old Mar 22, 2005, 10:56 PM
DIVEPASTOR is offline
Find More Posts by DIVEPASTOR
Kerrville, Texas
Joined Dec 2004
If you just want a romp around foamie, could you try a wing like the Unicorn? I have one and it take two servos, a 400 motor and a three channel radio. It glides wonderful if you leave it the 48 inches that it comes with, I have even found thermals with mine and flew it until I was tired of looking up, when you bring it down for a landing if you bring it in close and stall it right in front of you, you can just reach out and catch it, I've done it a number of times! Any way it is one option that you might consider. you can find them at Unicorn.com
Joseph
DIVEPASTOR is offline Find More Posts by DIVEPASTOR
Old Mar 23, 2005, 04:24 PM
snowball1288 is offline
Find More Posts by snowball1288
1Point Landing Specialist
Joined Nov 2004
maybe you could get a depron 3d plane and sort of "tone it down". Center teh rudder and secure it, grab one extra servo so you have two for teh ailerons, and attach em with a Y harness. Then put the 3rd servo on the elevator. 3rd channel - throttle. fancyfoam.com planes are built to use GWS Gearboxes...
of course, a better idea would just be to spend the money and get the proper radio, servos and maybe a brushless system and you'll never fly any of your other planes again
snowball1288 is offline Find More Posts by snowball1288
Any ideas for low cost foam cutting power source? slowflyer Foamies (Kits) 24 Apr 10, 2009 12:45 PM
Any Ideas for which Brushless motor to run in my Vasa 65 and K&A F86?? Joe Elston Electric Ducted Fan Jet Talk 52 Oct 05, 2006 04:07 PM
Quick! HUge winds outside! Any ideas for kite glider sort of plane to fly in the wind beep684 Electric Plane Talk 8 Nov 22, 2005 09:56 PM
Plan ideas for 1" foam plane. mb571 Foamies (Kits) 19 Dec 07, 2004 05:29 PM
Any ideas on a good 7 cell brushless geared motor for speed 400 type sailplane? bfraser Power Systems 4 Jan 29, 2003 01:21 PM
