Old Mar 28, 2002, 12:51 PM
joystix is offline
Find More Posts by joystix
joystix's Avatar
Fremont, Ca, USA
Joined Jan 1999
Hangar 9 40 size Piper Cub power ???
Just finished a Hangar 9 40 size Piper Cub. Installed an Astro Geared 15 with Superbox, 15x8 Electric Prop, Jeti 50 amp ESC and 12 cells. The Astro table says with 14 cells and a 15x8 prop it could pull 59 oz. Does my combo seem like it can pull it. I just want enough power for leisure flying and touch and goes. Well I will try it at lunch time and see what happens...
Ric
joystix is offline Find More Posts by joystix
Old Mar 28, 2002, 01:08 PM
jrb is offline
jrb
Find More Posts by jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
12 cells might be a bit light.
Here's a post with some H9 Cub info: http://www.rcgroups.com/forums/showt...threadid=31304
What does you're weigh?
Any idea how many amps you're drawing?
Which prop are you using? APC"E" would be 15x10.
Have you downloaded the 30 day sample of MotoCalc ( www.motocalc.com )?
Fortunatley you can got to a few more cells with the Jeti 500; BUT you must NOT use BEC!
The easiest way is to keep the Jeti switch off, and use a separate RX pack.
jrb is offline Find More Posts by jrb
.40 size Piper Cub conversion John Z Scale Kit/Scratch Built 4 Sep 07, 2006 10:03 PM
Sold Hangar 9 J-3 Piper Cub - 25%. 100" wing span fockewulf37 Aircraft - Fuel - Airplanes (FS/W) 2 Feb 19, 2006 12:21 PM
For Sale Hangar 9 J-3 Piper Cub - 80" wing span fockewulf37 Aircraft - Fuel - Airplanes (FS/W) 0 Feb 15, 2006 12:47 PM
For Sale Hangar 9 J-3 Piper Cub 80 (DFW) lehma Aircraft - Fuel - Airplanes (FS/W) 0 Jan 05, 2006 12:55 AM
Sold Hangar 9 J-3 Piper Cub 80 TSHARK Aircraft - Fuel - Airplanes (FS/W) 12 Sep 04, 2005 10:54 AM
