Old Feb 21, 2011, 08:47 PM
MrE
United States, WA, Gig Harbor
Joined Aug 2007
Has anyone successfully installed Power ProView on windows 7?
I just got a new laptop and cant get it to run properly. The problem seems to be the USB drivers. I keep getting an error message that I need a 64 bit version of the driver install program.
Any help would be appreciated.
MrE is offline Find More Posts by MrE
Old Feb 22, 2011, 01:00 AM
BEC
BEC's Avatar
Auburn, Washington USA
Joined Jan 2001
Now I need to go look at whether it runs now. I got it installed on Windows 7 Starter on my Acer and I've since installed Home Premium 64.....hmmmmmm.......
BEC is offline Find More Posts by BEC
Old Mar 21, 2011, 03:12 AM
MrE
Joined Aug 2007
Did you have a chance to test it out?
Im still having no luck.
Old Mar 23, 2011, 06:04 PM
Fourdan's Avatar
Antony (France)
Joined Sep 2003
Hi
Today I received from Jeff L. (Mri) a driver package for Win7 64 bits
ProView v 2.2.1.2 is now running on my Win7 home PC
What I have done
a) Install ProView from Mri website
b) Download the zipped file WinDriver Default (2.08.02)
c) Extract in some folder (for example \ProgramFiles\MedusaResearch\WinDriver)
d) Put on that folder a copy of DPinst.exe (for me coming from \windows\system32)
e) From that folder run DPinst.exe .. authorize all ...
f) See that 2 drivers are installed
g) Run ProView without USB cable
h) Connect the USB cable .. wait to have driver OK
i) Now you can "connect" (menu)
It's OK
Louis
Fourdan is offline Find More Posts by Fourdan
Old Mar 25, 2011, 01:32 AM
MrE
Joined Aug 2007
Thanks! I'll give that a shot
Old Mar 25, 2011, 05:13 AM
MrE
Joined Aug 2007
I got it to work - finally!
I could not find a copy of DPINST.exe on my computer. I had to download the WDK driver kit and install that. Then it took several tries to find the correct 64 bit version of the program.
Finally got the 2 drivers to install, but PPView still would not run correctly.
Uninstalled and re-installed PPV and got the same message that I needed the 64bit version of DPINST!!!
Copied the newer version into the same folder as the installer for PPV and that worked BUT now Im getting the error message that Im missing the MRIxx...DLL file. Grrrrr
Finally found that and moved it manually into the PPV run folder and...... IT WORKS!
Whew!
Thanks again!
Did some more looking and
Old May 28, 2011, 06:37 PM
Actively makin humans obsolete
Razor_Racer's Avatar
Northern Virginia
Joined Jul 2007
Just scored one on ebay for $13 shipped, what a deal! Super easy to use too, hats off to Medusa for making such an easy product.
The only software bug was the MRI2xx.dll, so I just copied that to my windows folder and it worked fine after that.
First run!
Razor_Racer is offline Find More Posts by Razor_Racer
Old Jun 07, 2011, 10:26 AM
Joined Jun 2011
Anyone have a unit that they willing to part with?
I really need one with a temp probe for battery monitoring.
Update: Got one !!!
Thank you Medusa Research
kbgrninja is offline Find More Posts by kbgrninja
Old Feb 03, 2012, 06:25 AM
Joined Feb 2006
Does anyone know if the latest software for the Power Analyzer PRO is still available? I had it running on my laptop (Windows 7 64 bit) but that laptop is history. Trying to rebuild everything on a new laptop.
b1bone is offline Find More Posts by b1bone
Old Feb 03, 2012, 10:36 PM
USA
Joined Jan 2002
PM me your email address and make sure you can receive a 17+MB attachment and I can send you what I have.
Ohmic is offline Find More Posts by Ohmic
Old Feb 09, 2012, 06:21 PM
Dragon
mech9's Avatar
Vancouver B.C. Canada
Joined Sep 2004
You can get it here:
http://powerproview.com/downloads.html
Cheers Rob.
mech9 is offline Find More Posts by mech9
Old Feb 10, 2012, 01:02 AM
BEC
BEC's Avatar
Joined Jan 2001
It's good to see Jeff putting the software back up where folks can get to it......good indeed.
Old Feb 13, 2012, 09:18 PM
Joined Feb 2006
PeteB, Rob, BEC, thanks for getting back to me. Hopefully I have everything I need. Also, I agree BEC. I was fortunate enough to get a couple of Jeff's motors years ago and I corresponded with him a few times. I believe him and his products will be missed.
Thanks again.
Old Feb 13, 2012, 09:58 PM
Joined Feb 2006
PAP is up and running on Windows 7 again. Thanks everyone!!!
Old Feb 23, 2012, 08:26 AM
abreimeris's Avatar
United States, CO, Aurora
Joined Apr 2009
I have a brand new Power Pro Deluxe, and a new Thrust Cell if anyone is interested. Send a PM with an offer.
Thanks!
abreimeris is offline Find More Posts by abreimeris
Discussion New RPM Sensor for the Power Analyzer Pro MRI Product Announcements 3 Nov 20, 2007 05:31 PM
Discussion Power Analyzer PRO fixture twilkers Electric Motor Design and Construction 1 Sep 19, 2007 08:37 PM
Sold Medusa Research Power Analyzer Pro watt meter pda4you Aircraft - Electric - Batteries & Chargers (FS/W) 6 Feb 12, 2007 09:34 PM
Article Medusa Power Analyzer Pro Review JWarren Electric Plane Talk 12 Nov 14, 2006 03:41 PM
Power Analyzer Pro AWG Wire Size? Ohmic Medusa Research 2 Oct 08, 2005 07:09 PM
