Old Mar 28, 2002, 01:32 AM
Gerry Markgraf is offline
Find More Posts by Gerry Markgraf
Gerry Markgraf's Avatar
S. Calif
Joined Mar 2000
Just finished a couple of Tom Hunt's designs
I just finished an Elipstick 700 and a Watter. Both Tom Hunt "Stick" designs. Neither one has flown yet. Elipstick has an Astro 05 Cobalt and is covered with Micafilm. Watter has a sp 480 and is covered with Litespan (with a couple of thinned coats of dope for extra waterproofing. Will see how they fly soon.
Gerry
Gerry Markgraf is offline Find More Posts by Gerry Markgraf
Old Mar 28, 2002, 01:34 AM
S. Calif
Joined Mar 2000
Here is the Watter
Gerry
Old Mar 28, 2002, 04:29 AM
oded mazor is offline
Find More Posts by oded mazor
oded mazor's Avatar
Tel Aviv-Yafo Sde Dov, Israel
Joined Apr 1999
wow, looks great.
looking forward to hearing your flight report regarding the elipstik 700. what battery pack will you be using ? how hard was it to build ?
Oded.
oded mazor is offline Find More Posts by oded mazor
Old Mar 28, 2002, 08:37 AM
Sabrejock is offline
Find More Posts by Sabrejock
Sabrejock's Avatar
Winnipeg, MB Canada
Joined Jan 2000
Watter
Could be the angle of the photo, but am I seeing down-thrust in the Watter??? Tex.
Sabrejock is offline Find More Posts by Sabrejock
Old Mar 28, 2002, 11:12 AM
Ryan Nau is offline
Find More Posts by Ryan Nau
Tork it or Dork it
Ryan Nau's Avatar
Elizabethville,PA USA
Joined Jul 2000
Good job on the Elipstik and the Watter. I agree with Alan, when you get one ModelAirTech plane, you can't stop building them, you need more. I have 5 MA-T planes currently flying.
Let us know how the Elipstik 700 Flies. I've been thinking about getting that kit. I had an 460 that flew great but flight times were to short and it didn't like being heavy, and my 260 never did fly that well.
Ryan Nau is offline Find More Posts by Ryan Nau
Old Mar 28, 2002, 11:28 AM
Alan W is offline
Find More Posts by Alan W
Alan W's Avatar
NY
Joined May 2000
Planes or Pringles ???
Tom's designs are like pringles.....once you start you just cant stop !!!
IMO the 700 elipstik is the best of breed
Alan W
Alan W is offline Find More Posts by Alan W
Old Mar 28, 2002, 07:09 PM
Tom Smith is offline
Find More Posts by Tom Smith
Rhinebeck CD-99,00,01,02
Tom Smith's Avatar
New Bern, NC
Joined Mar 2001
Ryan, I wish your 460 looked like Gerry's 700. Tom
Tom Smith is offline Find More Posts by Tom Smith
Old Mar 28, 2002, 09:57 PM
S. Calif
Joined Mar 2000
Thanks for the good words guys. I have the same problem with Tom's designs, I can't quit. I built 2 of the Elipstick 460s, 2 of the Elipstick 280s, a Tumblewatt, F-117 Nitestick and a Dimwatt. Its so neat to take a sheet of 1/8 balsa, strip it into sticks and make a good flying airplane. Only problem I had with the Elipstick 700 was the long, unsupported upper rib caps. They would snap any time I put any pressure on them - so I had to add some vertical supports between the upper and lower caps. Also on the elevons, when I built them out of 1/8 stock and then sanded both sides to smooth for covering, the net thickness was closer to 1/16. This made the elevons very flimsy for covering with Micafilm and they would twist and warp. I made the second set out of 3/16 and when I sanded them they were just over 1/8. This was much more rigid and did not warp when covered. Finally, the Watter has no downthrust. The picture makes it look that way.
Gerry
Old Mar 29, 2002, 09:53 AM
GregG is offline
Find More Posts by GregG
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
Great looking planes, Gerry! Have you flown the Watter yet? Is it all strip wood including the underside of the fuse? I'm wondering how well an open bay structure stands up to water takeoffs and landings. Keep up the good work!
GregG is offline Find More Posts by GregG
Old Mar 29, 2002, 11:16 PM
S. Calif
Joined Mar 2000
Thanks Greg. Yes, I have flown the Watter- once. Not off water though. Tried a hand launch and it flew away nicely. Got it up high and tried a stall and it fell off on one wing pretty bad. Had to be careful landing it to avoid letting airspeed get too low. I checked the wings for straightness and added a little washout. That should fix it. Havn't found a good spot to fly off water yet.
Gerry
Old Mar 30, 2002, 05:10 PM
GeeW is offline
Find More Posts by GeeW
SB-28 UK Display Pilot
GeeW's Avatar
ENGLAND
Joined Jul 2001
Watter goes a treat of the water. On both of mine i have put a diagonal stik on each side from the bottom of the front windshield to the bottom of what would be f1. Cause the nose crumples very easily else. My watters also do great slide and goes on grass.
The second one even does ROG from grass.
GeeW is offline Find More Posts by GeeW
Old Nov 29, 2014, 08:51 AM
rewday is offline
Find More Posts by rewday
Joined Oct 2012
I just got back from the maiden of my Elipstick 700 and "holy cow!" what a great flier! I built it two years ago and after a shaky test flight where it nosed into the ground, I put it away. I kept looking at it in the basement, and finally said, "I have to try this, it will either fly or come back a pile of sticks. Well today was 1mph winds so I took it out. Once I got the feel for it, it flies beautifully! It is like a slow flier/aerobat. It turns on a dime and with the throttle cut, it drifts to the ground and settles like a butterfly. Tom Hunt, you are a master! Thanks for my newest fun flier Tom.
rewday is offline Find More Posts by rewday
Retracts for Tom Hunt's Beech 18 astroboy Electric Plane Talk 8 Aug 05, 2010 04:19 AM
Tom Hunt's He-111 Rekitter Scale Kit/Scratch Built 152 Sep 30, 2006 07:48 PM
One Man's Saga to build his dream plane...a DF VTO -- Tom Hunt's Vertigo -- RCPower! AMCross Fuel Jet Talk 1 Jun 19, 2004 06:05 PM
Maidened Tom Hunt's SSP 400 skunkape High Performance 7 May 24, 2004 07:06 PM
Tom Hunt's Ryan PT-20 Neil Morse Scale Kit/Scratch Built 3 Jul 17, 2003 10:23 AM
