Old Mar 22, 2005, 01:40 PM
Inverted_Fly is offline
Find More Posts by Inverted_Fly
brushless nutjob
Inverted_Fly's Avatar
Atlanta
Joined Apr 2004
not all planes can just bank and yank like you describe. A great deal of modern 3ders have a hard time doing that, especially the Tensor.
flat turns are easy and fun. vertical pinwheels however, are difficult and fun.
Inverted_Fly is offline Find More Posts by Inverted_Fly
Old Mar 22, 2005, 06:56 PM
sbmon is offline
Find More Posts by sbmon
Joined Aug 2004
So we have coordinated turns, banked turns, and flat turns. I am still a little confused, I understand that a banked turn is not always a coordinated turn but can be, but a flat turn is never a coordinated turn (is this correct)? Sorry for the knit picking on the terminology I would just like to get a handle on the differences among these turns.
thank you
shawn
sbmon is offline Find More Posts by sbmon
Old Mar 22, 2005, 10:17 PM
SkyPyro is offline
Find More Posts by SkyPyro
Burnin' holes in the sky!
SkyPyro's Avatar
Gilbert, AZ
Joined May 2003
Like Inverted Fly said, the best turning technique depends on the airplane. A standard coordinated turn is where the plane is banked to one side and rudder in the same direction is applied to keep the plane tracking through a circle. This is how a "competition turn" is done. A "yank and bank" turn is basically initiated by banking the plane so much that yaw doesn't matter, then pulling up on the stick. The guys that do this are the ones you usually end up ducking for at the field . Finally, a flat turn is where rudder is moved to one side and aileron/elevator are used to keep it straight and level.
Dan
SkyPyro is offline Find More Posts by SkyPyro
Old Mar 23, 2005, 12:07 AM
steelgtr is offline
Find More Posts by steelgtr
San Jose, Ca.
Joined Jan 2005
Dan
So, would a typical foamy need elevator and aileron to execute a flat turn?
bob
steelgtr is offline Find More Posts by steelgtr
Old Mar 23, 2005, 01:20 AM
ryanl2006 is offline
Find More Posts by ryanl2006
ryanl2006's Avatar
Ames, Iowa
Joined Oct 2002
bob
Most will. Usually when rudder is applied the nose will drop and one wingtip will drop but it depends on the plane. Some planes can do it with just rudder, but most require aileron and elevator to remain flat.
ryanl2006 is offline Find More Posts by ryanl2006
Old Mar 23, 2005, 01:24 AM
SkyPyro is offline
SkyPyro's Avatar
Gilbert, AZ
Joined May 2003
Your theoretical "perfect foamy" wouldn't need elevator or aileron to pull off a flat turn. However, even the best designs have some degree of coupling. Aileron is just used to keep the wingtip on the inside of the turn from dropping (or climbing if there is forward sweep/anhedral). Elevator is then used to keep the plane from climbing or diving.
Dan
Old Mar 23, 2005, 06:19 AM
dick hanson is offline
Find More Posts by dick hanson
dick hanson's Avatar
slc ut
Joined Nov 2003
the new Shockflyers - F3A and YAK- balanced for nice controllable maneuvering -NOT really tailheavy - do instant flat turns with rudder only - no fiddling with other axis.
The coupling is so minimal as to ignore in all but extended max deflection turns .
There are no typical foamies - I know of .
but a good typical 3D type that is of latest generation -all do instant , flat turns -even a rank beginner can do em.
These planes are all flat -flat wing ,flat stab- no dihedral but the lateral area is well balanced and the common engine /wing/stab force setup is pretty darn nuetral
dick hanson is offline Find More Posts by dick hanson
New 16/15/5, do I grind a flat spot on the shaft? Captain Carlton Power Systems 9 May 21, 2003 07:23 AM
Turns on a motor???? Majortomski Power Systems 10 Jan 01, 2003 02:02 PM
Why does nose drop in turns on flying wings? rparigoris Modeling Science 9 Sep 30, 2002 06:29 AM
How many turns on a speed 400 motor stealthy Power Systems 5 Dec 14, 2001 11:34 PM
flat turns in a thermal maciek Electric Sailplanes 20 Apr 25, 2001 12:03 AM
