Old Mar 20, 2005, 05:59 PM
HIGHFLYER99 is offline
Find More Posts by HIGHFLYER99
HIGHFLYER99's Avatar
North East
Joined Nov 2001
looking for build thread with upclose photos
I am trying to assemble a levi-like model , I want to go 3 servo's but
would like this explained photogenticly a photo being worth a thousand words
other questions remain for me.
-how to configure 1 servo to control both ailerons
-what channels to use since I've only ever flown 3 channels
Thanks in advance
HIGHFLYER99 is offline Find More Posts by HIGHFLYER99
Old Mar 21, 2005, 03:03 PM
alabamaboatguy is offline
Find More Posts by alabamaboatguy
CrashingBama
Orange Beach, Alabama
Joined Feb 2005
a good (or at least the best i know of off hand) illustration to show you how to do the ailerons off of one servo is here
http://www.gws.com.tw/english/servic...ane_manual.htm
its the manual from the gws a-10, which uses one servo in themiddle of the wing push/pulling
alabamaboatguy is offline Find More Posts by alabamaboatguy
Old Mar 21, 2005, 03:04 PM
CrashingBama
Joined Feb 2005
whoops, click on the A10, then click on P-8
Old Mar 21, 2005, 03:36 PM
North East
Joined Nov 2001
ok thanks. I happened on some better photos after exhausting search on these threads. Wish there were a photo search!!!
Old May 04, 2005, 08:15 PM
EDC121 is offline
Find More Posts by EDC121
WIND!? WHAT WIND?
EDC121's Avatar
Honolulu Intl, Hawaii, United States
Joined Sep 2004
HIGHFLYER,
So where is the links if you found better photos?
EDC
EDC121 is offline Find More Posts by EDC121
Old May 04, 2005, 09:39 PM
North East
Joined Nov 2001
This was a while ago. I searched quite a bit and I happened on some that depicted what I was after. It isn't easy to have 1 servo to control both ailerons and get it just right!
Old May 05, 2005, 12:14 AM
wired one is offline
Find More Posts by wired one
tissue for issue
wired one's Avatar
Beavertown Oregon
Joined Jan 2005
2 rods bent into the ailerons, then run back to the middle of the wing, where there are little arms on the rods. then control rods come from the servo to the little arms. system was originally in a rare bear i had, that blew to pieces, so i recovered the rods and used them again. weee.
wired one is offline Find More Posts by wired one
Old May 05, 2005, 05:45 PM
North East
Joined Nov 2001
It helps alot to have adjustable rods instead of having to adjust the control surface in the primitive fashion I did. Is there a closeup version of that pic?
Old May 05, 2005, 05:53 PM
tissue for issue
wired one's Avatar
Beavertown Oregon
Joined Jan 2005
where the servo rods connect are little wood arms that are mounted on a plywood block. the block has a hole drilled in and the rod from the aileron is glued into it. but if i was going to do it the same way again, i would use pieces of small wood dowel, or maybe bamboo skewer pieces with holes drilled in. then attach the horn to said dowel. make sense?
Old May 05, 2005, 09:21 PM
EDC121 is offline
WIND!? WHAT WIND?
EDC121's Avatar
Joined Sep 2004
Thank You for the posts
It is sometimes frustrating to look at all the searches and find a post with the right questions but no answers.
When I get my single ailerons setup I will snap some close-ups.
EDC
Old May 06, 2005, 08:47 PM
North East
Joined Nov 2001
Here's my setup
I had to screw on servo arm extenders made from scrap plywood. Hope it holds!
Old May 21, 2005, 04:46 PM
Downwind 1 is offline
Find More Posts by Downwind 1
Downwind 1's Avatar
massachusetts
Joined Aug 2003
That looks a little scary.
Downwind 1 is offline Find More Posts by Downwind 1
Old May 21, 2005, 08:13 PM
North East
Joined Nov 2001
ok
It's seems to be working ok. my ailerons are being held on by tape alone. After a few crashes, the glue is adding to the weight.
Old May 21, 2005, 08:54 PM
Silent is offline
Find More Posts by Silent
Silent's Avatar
New York City
Joined May 2005
Check this out..
Silent is offline Find More Posts by Silent
Help! Looking for build thread on AK Models Pitts tigerbug Electric Plane Talk 2 Feb 26, 2006 01:00 AM
looking for some help with PDA's newguy Life, The Universe, and Politics 4 Jul 09, 2002 09:37 PM
Looking for speed plane, with this gear I have. jocappy High Performance 1 May 08, 2002 03:41 PM
Looking for motor/gearbox with 1.5 to 2 oz of thrust fritts Parkflyers 5 Nov 13, 2001 01:10 PM
Looking for model to travel with kenny_dilger Parkflyers 3 Jun 03, 2001 04:15 PM
