Old Mar 20, 2005, 10:03 AM
Nethole is offline
Find More Posts by Nethole
Registered Lurker
Nethole's Avatar
Joined Aug 2004
Switch from Brushed/KAN to chinese brushless/Lipo
One of the planes I've been flying is a E-Starter with a GWS C gear and 10x6 GWS prop using KAN 1050s. And would be lucky to get 5 minute flights.
Well, I swapped out the motor with a 12 T chinese special
http://cgi.ebay.com/ws/eBayISAPI.dll...e=STRK:MEWN:IT
Put on a APC 8x3.8 slow flyer prop.
Also put on a MaxAmps 1650 (and 2250 in a later test) 3S lipo.
Had more speed, more excess power (rate of climb), and obviously lower throttle.
I had done bench testing and timed/verified how much time an 8 amp draw would take to drop down to LVC. But, in flight, turns out I was using far less power. I stopped flying after 10 minutes. The charger put back in 660mah.
Assume I may be a 'minute' off in my flight time, so my actual amp draw in flight was around 4 amps.
This combo is potentially bumping flight times up from 5-ish minutes to 20-25 minutes with far more performance.
I predict far more brushless motor purchases and MaxAmp Lipo purchases in my future.
I do have concerns in that the prop shaft is so long. I remember from the GWS days, prop shafts get bent when you look at them wrong.
Has anyone else used these chinese brushless motors and had any problems with the length of the shaft? What did you do with it?
Nethole is offline Find More Posts by Nethole
Discussion Recommend outrunner/lipo to convert six motor b36 from brushed 400's RCWarbirds Power Systems 3 Jun 13, 2007 02:22 PM
How is a brushless differnt from a brushed motor? Mat Power Systems 4 Nov 04, 2004 07:55 PM
Alert Eco 8- From brushed to brushless, PROBLEM peterbruce Electric Heli Talk 20 Oct 25, 2004 09:38 AM
easy switch from 2s-3s lipo w/pixi 20??? kiteboarder Power Systems 1 Jan 04, 2004 07:09 AM
New switch from Schieppati - TINY! Bigfoot Aerial Photography 11 Mar 09, 2003 07:04 AM
