Old Mar 19, 2005, 12:17 PM
balsa splinters is offline
Find More Posts by balsa splinters
Joined Feb 2005
Quick servo question
Hi! I am in the process of buildin a MM Cessna, than a MM switchback sport. My question is what servos should I use? I do NOT want GWS, and I have heard good things about Hitec. I went to hitecs site, and I do not know which servos I should use. Should I use the HS50's? 81's? I will probably use a Berg or JR reciever for both planes. Thank you!
(Yes I have searched for the answers!)
balsa splinters is offline Find More Posts by balsa splinters
Old Mar 19, 2005, 12:56 PM
rcav8r2 is offline
Find More Posts by rcav8r2
rcav8r2's Avatar
United States, PA, Beaver
Joined Sep 2001
I have the Cesssna and have HS55s in it for about 3 years or so now. Work flawlessly.
Not sure about the SB, but I use HS56s (pert near the same size as the 55s but with karbonite gears, and ball bearings) in my planes in this size range. They are holding up just fine.
rcav8r2 is offline Find More Posts by rcav8r2
Old Mar 19, 2005, 01:05 PM
Joined Feb 2005
Thanks! I guess I'll go with 55's in the cessna, and 56's in the switchback but with a 55 rudder (Cost)
Old Mar 19, 2005, 06:01 PM
Up&Away is offline
Find More Posts by Up&Away
The original Flying Pigs Sqd.
Up&Away's Avatar
Netanya, Israel
Joined Aug 2002
HS55's will do just fine. Why no GWS? I have GWS in most of my planes, and the only problem I ever encountered where of my own doing.
RW
Up&Away is offline Find More Posts by Up&Away
Old Mar 19, 2005, 07:07 PM
Joined Feb 2005
No GWS because my 2 picos are held together with duct tape, one had a connector that shorted, and I want to take no risks with kit built balsa planes. I was gentle with the sevos too, ther only abuse was flying on a SS. Their 4ch RX I have has tons of hits too. I just don't want to use them anymore.
PS: Where is a good online store to buy the sevos that you guys have had luck with? Thanks!
Old Mar 19, 2005, 10:01 PM
aeajr is offline
Find More Posts by aeajr
Proud member of LISF and ESL
LI, New York, USA
Joined Mar 2003
HS-55s shoudl work well. I use both Hitec and GWS servos and not prob with either.
aeajr is offline Find More Posts by aeajr
Old Mar 19, 2005, 11:22 PM
Up&Away is offline
Up&Away's Avatar
Netanya, Israel
Joined Aug 2002
try servo city for Hitec servos.
Old Mar 20, 2005, 04:31 AM
aeajr is offline
LI, New York, USA
Joined Mar 2003
www.servocity.com
www.servohut.com
www.towerhobbies.com
All have Hitec servos. I have used all three.
Old Mar 20, 2005, 07:07 PM
lafjax is offline
Find More Posts by lafjax
Jacksonville, Florida, United States
Joined Jul 2004
I use Bluebirds exclusively. 21 oz torque for the BMS-371 from Balsa Products, 4 for $52. Very good and the size of HS-55's.
lafjax is offline Find More Posts by lafjax
Discussion quick servo question for yak 54 heligrom Foamies (Kits) 2 May 31, 2006 05:12 PM
Discussion Quick Servo Question laanguy Slope 3 Mar 02, 2006 06:12 PM
Discussion Quick Servo question Imdbombboarder Electric Plane Talk 7 Jan 09, 2006 06:14 PM
Quick servo question? Steve KO Electric Heli Talk 3 Jan 30, 2002 10:14 AM
quick servo question? petey pete Parkflyers 1 Jan 14, 2002 08:25 AM
