View Poll Results: OK, Place your bets for fun. WILL SHE FLY?
"The force is strong with this one." 196 54.60%
"She may not look like much, but she's got it where it counts" 102 28.41%
"Negitive.... It just impacted on the surface" 24 6.69%
Pull up! Pull up!! Ba-da-boommmm! 37 10.31%
Voters: 359. You may not vote on this poll
Old Apr 25, 2005, 03:30 PM
snakeX2 is offline
Find More Posts by snakeX2
Flap chap
snakeX2's Avatar
Most Southern England, Brighton UK
Joined May 2004
They definetely are, i mean i'll be saving about 25 grams over the KAN pack plus i'll have 10 cell like voltage, should be a winning combination. I also need as much power as posible as i am not providing thrust equal/more than weight. I looked back and noticed GO is using a 28 oz powertrain with 20oz AUW, he doesn't even need the aerodynamics, where as i had to keep drag to a minimum. Thanks for the opinion, i'm sold on the 2A pack now
snakeX2 is offline Find More Posts by snakeX2
Old Apr 25, 2005, 03:45 PM
Aio_1 is offline
Find More Posts by Aio_1
Aio_1's Avatar
Ireland, Kildare, Leixlip
Joined May 2002
Originally Posted by JCaste
....0.4Ah are well worth 30g.
You could of course just as easily say 1Ah is worth 75g. You have to consider everything. size, balance, AUW, power, etc...
30g can make a big difference in some cases. Often it won't.
Snake,
Which type of 480 motor is it that you will use? Long can type or replacable brush type? What current do you plan to draw at full throttle? What is the total weight of the plane minus the battery.
Aidan
Aio_1 is offline Find More Posts by Aio_1
Old Apr 25, 2005, 03:53 PM
RobinBennett is offline
Find More Posts by RobinBennett
Sussex, UK
RobinBennett's Avatar
Crawley, West Sussex, UK
Joined Jun 2004
I'd look at the maximum power your motor and ESC can handle and get the battery that suits them. There's no point lugging around extra weight for half hour flights when you could fly a lighter plane and change the batteries at half time - it's not much more expensive to buy more smaller batteries.
OTOH if you think you might want to fit a bigger motor, or a twin, you should plan ahead.
One of these days I'll get around to building an X-wing...
RobinBennett is offline Find More Posts by RobinBennett
Old Apr 25, 2005, 04:03 PM
Rocketman1092 is offline
Find More Posts by Rocketman1092
Purdue Engineering
Rocketman1092's Avatar
United States, CA, San Diego
Joined Jan 2005
snakeX2, do you have a Lipo charger?
Rocketman1092 is offline Find More Posts by Rocketman1092
Old Apr 25, 2005, 04:11 PM
snakeX2 is offline
Flap chap
snakeX2's Avatar
Joined May 2004
Definetely, i planned ahead not long ago and got a more expensive charger for all batts including lipo. Money worth spent, i say .
I'm also going to get these lipo for all my models, i mean i don't have much, battery wise, and i was wise to keep my nickel type batterys to a minimum, i want to make the lipo change and stick with it (i hope).
And yes i suppose extra weight is gonna be ligged around with the 2A pack while the 1.6A is also very good, capacity wise anyways. My only concern is with all the models that i would use these batts with, would definetely require nose weight or tail weight to keep in balance, where is seemed that my old N-500 AR pack would balance perefectly at 150 grams, the 2000 mA would be in a sweet spot as it is in between the 185 gram KAN pack and 500 AR pack (150 grams). The 130 gram 1600 mA lipo wouldn't prove worth the less weight.
Old Apr 26, 2005, 01:17 AM
JCaste is offline
Find More Posts by JCaste
DIY user
JCaste's Avatar
Barcelona, Spain
Joined Jul 2004
Aidan, I said that "considering weight and capacity only, I'd buy the 2Ah batt". And of course 75 may well be worth 75g. But the truth is for most models a 30g difference is not critical, or even barely important at all. However, if batts are a major % of the AUW, it's better to have shorter flights but use a lighter plane.
JCaste is offline Find More Posts by JCaste
Old Apr 26, 2005, 10:03 AM
jeanfran42 is offline
Find More Posts by jeanfran42
Joined Dec 2004
a really BIG falcon
so.. what kind of ESC, batteries and motor would you suggest to make this one fly
http://www.mentalwardfilm.com/falcon1.htm
jeanfran42 is offline Find More Posts by jeanfran42
Old Apr 26, 2005, 10:57 AM
snakeX2 is offline
Flap chap
snakeX2's Avatar
Joined May 2004
None, you'd be better saving your equip for something that woudn't fall apart ! Thouhg i bet it would be soooo cool if one were to build a blue foam falcon this size, and have a 'light weight' setup. Now i wander how you would power it?
Old Apr 26, 2005, 11:59 AM
madrob is offline
Find More Posts by madrob
designer/builder
madrob's Avatar
Kars, Ontario, Canada
Joined Apr 2004
"Now i wander how you would power it?"
With a Hyper Drive of course!
madrob is offline Find More Posts by madrob
Old Apr 26, 2005, 08:42 PM
GO-RC is offline
Find More Posts by GO-RC
Have Bluecore....will fly
GO-RC's Avatar
Arizona, United States
Joined Mar 2005
1...2...3...GO!!
GO-RC is offline Find More Posts by GO-RC
Old Apr 26, 2005, 09:02 PM
Demon-Leather is offline
Find More Posts by Demon-Leather
"Experienced-Crasher"
Demon-Leather's Avatar
Rex, NC "Extreme Boonies"
Joined Jan 2002
Well!!!???..................
Looks like it was just released... did it keep going!?? More Photos! More! MOOOORREEE!!!!!!!!!!
Demon-Leather is offline Find More Posts by Demon-Leather
Happymcc is offline
Find More Posts by Happymcc
I USE CAPS - EYE TROUBLE
Happymcc's Avatar
Joined Aug 2004
Hey now thats a great picture
But you have to give us more than that
Happymcc is offline Find More Posts by Happymcc
Old Apr 26, 2005, 09:03 PM
SammyB is offline
Find More Posts by SammyB
Rem The Wasp CV-7 9/15/42
SammyB's Avatar
Santa Clarita,CA
Joined Apr 2004
what a tease
SammyB is offline Find More Posts by SammyB
Old Apr 26, 2005, 09:14 PM
Red 61 is offline
Find More Posts by Red 61
Outcast outlaw
As far away from RCGroups and the AMA as possible!
Joined Aug 2004
Looks like the Falcon is dodging an asteroid!
...I think I see the space slug...
Red 61 is offline Find More Posts by Red 61
Old Apr 26, 2005, 09:21 PM
T-Fly is offline
Find More Posts by T-Fly
T-Fly's Avatar
Jacksonville FL
Joined Feb 2005
Sweet!!!!
T-Fly is offline Find More Posts by T-Fly
Build Log MILLENNIUM FALCON & other STARWARS Parkflyers part 2!! GO-RC Parkflyers 689 Jan 17, 2016 08:37 AM
Help! Building a Millennium Falcon John Z Electric Sailplanes 4 Mar 13, 2007 09:26 AM
The Millennium Falcon dave_lilley Sailplane Talk 0 Sep 25, 2002 01:23 PM
The Millennium Falcon dave_lilley Electric Sailplanes 0 Sep 25, 2002 01:22 PM
Article The Millennium Falcon Dennis Weatherly Sailplane Talk 0 Sep 22, 2002 12:00 AM
