Go Back   RC Groups > Aircraft - Electric - Airplanes > Parkflyers
View Poll Results: OK, Place your bets for fun. WILL SHE FLY?
"The force is strong with this one." 185 55.22%
"She may not look like much, but she's got it where it counts" 94 28.06%
"Negitive.... It just impacted on the surface" 22 6.57%
Pull up! Pull up!! Ba-da-boommmm! 34 10.15%
Voters: 335. You may not vote on this poll
Old Mar 19, 2005, 02:03 AM   #1
Have Bluecore....will fly
Gold Member
GO-RC's Avatar
MILLENNIUM FALCON Parkflyer??
OK so no wings, no vertical stab, no air foil shape but with enough power and the right control surfaces will it fly? Can you imagine the look from others at the flying field as your Falcon glides smoothly around with tight barrel rolls and quick vertical climbs? Is it possible?
Have blueCore will try.
So just for something different and fun I'm going to give it a try. Here’s the game plan. I’m going to build a prototype out of Bluecore and power it as a himax brushless pusher. If it flies build a ship with a 6mm Depron sub structure and 3mm hull plating. Power this with a Wemotec minifan and a Mega 16/15/3. I’m going to try to keep them as scale looking as possible.
Not sure on the controls yet but was thinking of a vertical stabilizer made of some type of clear material, thin plastic or something light that wont be seen during flight. Also use a split elevon setup on either side of the motor. Maybe a little motor down thurst added in to help keep the nose up? I’m open for suggestions.
This is all for fun, so any comment or help is encouraged.
Below are a few pics of the ship and then the build so far.
  • Name: falcon_sidee1.jpg
  • Name: falcon front tilt1.jpg
  • Name: falcon_top.jpg
  • Name: falcon back1.jpg
  • Name: falcon-bluesc2.jpg
GO-RC is offline Find More Posts by GO-RC   Reply With Quote
Old Mar 19, 2005, 02:16 AM   #2
Gold Member
GO-RC's Avatar
Build pics
ship so far...
  • Name: fal 1.JPG
  • Name: fal 2.JPG
  • Name: fal 3.JPG
  • Name: fal 4.JPG
Old Mar 19, 2005, 07:28 AM   #3
Evil Plane Doer
jskrebs's Avatar
Very, Very cool,
I have a stalled Tie FIghter project underway. The Falcon may be a good EDF ship?
jskrebs is offline Find More Posts by jskrebs   Reply With Quote
Old Mar 19, 2005, 04:04 PM   #4
Gold Member
GO-RC's Avatar
Originally Posted by jskrebs
Very, Very cool,
I was thinking the same thing. The hole between the mandibles will travel right through the ship with the assembly supports removed and the hull design leaves plenty of room for the fan.
ATie fighter would be tough but cool!
Old Mar 19, 2005, 05:49 PM   #5
Pook's Avatar
Good luck with your build Chad. Where did you get the MF plan from ?
Piers
Pook is offline Find More Posts by Pook   Reply With Quote
Old Mar 19, 2005, 08:24 PM   #6
Gold Member
GO-RC's Avatar
Plan
I enlarged the plan from STAR WARS The Essential guide to Vehicles and Vessels. It has a nice top view and a front view. Not a whole lot of other blue prints or 3-views out there that i could find.
Old Mar 20, 2005, 03:20 PM   #7
Gold Member
GO-RC's Avatar
Added the side rails. Went ahead and put them all the way around even over the side escape hatches. Thinking this would help keep everything aligned. I plan on cutting that portion out later. Got to love the ease of working with foam.
  • Name: FALCON RAILS1.JPG
  • Name: FALCON RAILS2.JPG
Old Mar 20, 2005, 04:08 PM   #8
Pook's Avatar
I really do think youve got a pretty good chance of that flying quite nicely - the shape isnt to bad at all..
Piers
Old Mar 20, 2005, 10:33 PM   #9
DIY user
JCaste's Avatar
Send a message via MSN to JCaste Send a message via Yahoo to JCaste
I like it!
JCaste is offline Find More Posts by JCaste   Reply With Quote
Old Mar 20, 2005, 10:41 PM   #10
Gold Member
GO-RC's Avatar
Made a little more progress. Began plating the bottom of the hull. When it was done I gave it a good toss over the carpet and it glided straight and smooth for a moment till it lost air speed then the nose dropped. Haven't set the cg yet but I was encouraged.
  • Name: fal plate1.JPG
  • Name: fal plate2.JPG
  • Name: fal plate3.JPG
Old Mar 21, 2005, 06:29 AM   #11
Pook's Avatar
Hrrmm Good, the chance of success looks. Guided by the force, you are.
Piers
Old Mar 21, 2005, 07:41 AM   #12
Gotta find some charger..
Buku Gaidin's Avatar
Whow, that's very cool !!
I already saw project of X-wings but never the Millenium !! (also saw an Enterprise )
But, what system are you going to use for powering it ?
Anyway, this project rocks !
Buku Gaidin is offline Find More Posts by Buku Gaidin   Reply With Quote
Old Mar 21, 2005, 10:59 AM   #13
Flap chap
snakeX2's Avatar
I'm watching this thread closely. Is there any chance those little GWS IPS geared motors may work with this?
snakeX2 is offline Find More Posts by snakeX2   Reply With Quote
Old Mar 21, 2005, 12:16 PM   #14
Gold Member
GO-RC's Avatar
Hello,
Should be able to make some more progress today. I'll post more photos tonight.
Buku- I was going to power the pototype with a Hi-max HA2025-4200 brushlees motor and a Thunder Power 11.1v 1320 mAh battery. This should be enough to get her moving.
SnakeX2- If we can keep the weight down a GWS geared 350 might be enough to keep her flying not sure on the IPS though. Right now i'm looking for a flying weight around 18OZ. Keep fingers crossed.
I shall continue for the Force is my ally. And a powerful ally it is. Its energy surrounds and binds us. We must feel the Force around us. Here....there....everywhere! Yes, even between the land and the ship!
Old Mar 21, 2005, 12:51 PM   #15
Flap chap
snakeX2's Avatar
18 oz sounds a porker, still it must be big, hard to tell in the pics. I guess you want the power, as it doesn't look too aerodynamic!
I wouldn't mind seeing a smaller version if yours flys well. Maybe some plans would help . I plan to make a small, hot-wired version out of polystyrene, shouldn't take long.
Great progress indeed, and it looks damn good as well. Just imagine this thing flying, you couldn't get more crazy than you .
James,
Build Log MILLENNIUM FALCON & other STARWARS Parkflyers part 2!! GO-RC Parkflyers 670 Jan 30, 2010 08:06 PM
Help! Building a Millennium Falcon John Z Electric Sailplanes 4 Mar 13, 2007 10:26 AM
The Millennium Falcon dave_lilley Sailplane Talk 0 Sep 25, 2002 02:23 PM
The Millennium Falcon dave_lilley Electric Sailplanes 0 Sep 25, 2002 02:22 PM
Article The Millennium Falcon Dennis Weatherly Liftzone Archive 0 Sep 22, 2002 01:00 AM
Congratulations SimpleM!
