Old Mar 18, 2005, 09:54 PM
lostrider is offline
Find More Posts by lostrider
flying thing
lostrider's Avatar
Joined Mar 2005
Alert
Dragonfly can be converted to Belt drive Tail ? Yes, Come on, we can do...?
Hi all,
anybody tried this?
i think, it must be possible,
- with pha-01,
- not another esc,
- but adding a servo for controlling tail prop angle,
- and tail prop angle shaft system, + belt drive to the mainmotor
if this conversion completed succesfully, dragonfly will be good,
i dont like this separate tail motor system, and its freaky workin.
300 stock motor will be enough for all power? with li-poly it seems possible and cool,
i think, power consumption is must be equal, or better than seperate..
any comments please,
i must do this thing, because im bored
- sorry for my poor english..
lostrider is offline Find More Posts by lostrider
Old Mar 18, 2005, 10:00 PM
TMorita is offline
Find More Posts by TMorita
San Carlos, California, United States
Joined May 2002
This was discussed a lot about three years ago.
If you search through old messages you will find that Mario had designed a belt drive system and was trying to get enough people to preorder so he could manufacture it.
One problem with main-motor driven tails on FP helis is when you throttle down, the tail rotor loses authority, so I think motorized tails are probably better for FP helis.
Toshi
TMorita is offline Find More Posts by TMorita
Old Mar 18, 2005, 10:01 PM
flying thing
lostrider's Avatar
Joined Mar 2005
Clutch system?
adding a clutch included belt drive system is possible;
with non-geared belt system
so we dont need a tail prop mechanics, fixed tail prop, and clutch belt drive system,
i need find anything for making this belt.. or invert an a belt to non-geared side
Old Mar 18, 2005, 10:03 PM
flying thing
lostrider's Avatar
Joined Mar 2005
yes but it must not be fixed-speed or fixed-mechanics?
Old Mar 18, 2005, 10:59 PM
TMorita is offline
Joined May 2002
Why do you want a clutch?
There's no need to stop the tail rotor.
Toshi
Old Mar 18, 2005, 11:03 PM
flying thing
lostrider's Avatar
Joined Mar 2005
clutch for speed coupling, for tail speed control,
no tail mechanics, fixed tail propellers & coupling clutch to toothless belt drive<->ballbearing,
servo controled belt tightness
Old Mar 18, 2005, 11:31 PM
loserbaby is offline
Find More Posts by loserbaby
some guys never learn...
Galt, CA
Joined Jan 2005
sounds like your trying to complicate a simple system, a clutch, fixed pitch prop? If it's gonna work your gonna need some input from a gyro, Belt tension is a thought, but may be way to sensitive to control. It would be easiest to stick with what has been done already, a working TR hub, then adapt your belt drive to it.
loserbaby is offline Find More Posts by loserbaby
Old Mar 18, 2005, 11:41 PM
flying thing
lostrider's Avatar
Joined Mar 2005
yes,
yes, but its dragonfly
so, we; dragonfly users need some mechanic too,
and i think,
+ it must better than toothed-pitched belt drive system,
+ this thing dont have this problem: wasting your tail gears
+ less tail weight
+ no belt breaking,
+ stabil tail propellers
when i have spare time, i will try this,
only need,
pha-01 must be controlling an a servo, no extra esc
any ideas for connection schema?
Old Mar 18, 2005, 11:48 PM
Tonystott is offline
Find More Posts by Tonystott
Its all fun
Tonystott's Avatar
Australia, NSW, Forster
I think it would be an easier task to convince fliers to all change to the same mode!
I think also that insisting on using a PHA-01 is making life unnecessarily difficult.
If you really need to have a driven tail, it would be way cheaper to buy a 22D and spend the effort debugging it.
Sorry, but I just don't see the justification when there are so many other heli designs out there which can be picked up so cheaply.
Tonystott is offline Find More Posts by Tonystott
Old Mar 18, 2005, 11:51 PM
flying thing
lostrider's Avatar
Joined Mar 2005
you right, but me too
you right, but me too,
i have this heli allready,
so i need mods on this,
can u give me 22d for free?
Old Mar 18, 2005, 11:53 PM
flying thing
lostrider's Avatar
Joined Mar 2005
and i dont like 22d's and others tail systems,
i see, driven tail users have many problems with tail systems,
so i try to find better
Old Mar 19, 2005, 12:19 AM
flying thing
lostrider's Avatar
Joined Mar 2005
an a sketch
Old Mar 19, 2005, 02:27 AM
Its all fun
Tonystott's Avatar
If the idea is to adjust the tension to adjust the tail speed, the belt is going to melt!
Old Mar 19, 2005, 08:43 AM
flying thing
lostrider's Avatar
Joined Mar 2005
than it can be a shaft&wheel
Old Mar 19, 2005, 12:27 PM
thanhTran is offline
Find More Posts by thanhTran
That tree again!!!!
thanhTran's Avatar
Germantown, MD, US
Joined Sep 2004
Hi Lostrider,
Why do you want to adjust the belt tension? Usually the belt tension is fixed and there is a servo used to adjust the angle of the tail blade by pulling / pushing a tail pitch slider which in turn changes the pitch of the tail blades to increase or decrease the force generated by the tail rotor.
Does PHA-1 have an output to connect to tail servor? I think it has only 2 motors output right? Or do you have an extra servo channel from your radio?
I don't like seperate tail system either. When I was using seperate set up with a piccolo V2, the tail rotor still kept running by itself even when the main motor has stopped (throttle 0, but the rudder was 50). That tiny tail rotor hit my eye lid and I was so mad because of that incident.
I think the problem with dragonfly is that it's small and light. A tail belt system requires a bigger boom and a belt. That's heavier than the stock boom. ALso nontooth belt may slip during run if you dont' have enough tension so that may cause loosing tail authority. Don't under estimate it, the tail gear & tail rotor shaft of shogun slip lots of time. Loosing tail authority in fly is bad as you could crash easily . I have the tail rotor & its shaft flew off its holder and its gear a few times. Those were really nasty crashes
thanhTran is offline Find More Posts by thanhTran
Belt drive tail conversion on aluminum crutch question. Heli Mod Man Electric Heli Talk 54 Jun 29, 2005 02:07 PM
Matt's Tail Belt Drive and tail hunting...found solution..! chrisw Electric Heli Talk 16 Aug 21, 2004 10:53 PM
Flight Reports of the Zoom Hubdave Belt Drive Tail. UAVProducts Mini Helis 0 Jul 13, 2004 03:43 PM
Free Corona Belt Drive Tail Kit!!!!! Heli Mod Man Electric Heli Talk 18 May 24, 2004 08:20 PM
Choppahedz Corona with JRVE gear & belt drive tail mthomson Electric Heli Talk 12 Mar 16, 2004 01:43 PM
