Old Mar 17, 2005, 11:27 PM
Joel K. Scholz is offline
Find More Posts by Joel K. Scholz
Joel K. Scholz's Avatar
Kingsland, Texas USA
Joined Aug 2000
can astro gearboxes be converted for brushless motors
I love astro gearboxes.Strong and no prop adaptor necessary. I have used them with can motors with a spacer, but would love to use them with Mega 22/30/3 or other metric shaft motors. Is there a way?
Joel K. Scholz is offline Find More Posts by Joel K. Scholz
Old Mar 18, 2005, 12:02 AM
David Hogue is offline
Find More Posts by David Hogue
Blew out my flip flop
David Hogue's Avatar
USA, NC, Clayton
Joined Feb 2001
Joel,
Get in touch with Kirk at New Creations. He has pinions for diff diameters, or bores them out. I have done a astro box on a jeti 15/4 with one of his 5mm pinions. Was very reasonable, aslo.
Later,
David
David Hogue is offline Find More Posts by David Hogue
Old Mar 19, 2005, 08:35 AM
twest is offline
Find More Posts by twest
100% electric since 1990
twest's Avatar
United States, MA, Ware
Joined Jul 2001
Yes.
(edit- I thought I put the links here)
twest is offline Find More Posts by twest
Old Mar 19, 2005, 11:12 AM
Joined Aug 2000
Twest, Can you be a bit more specific? How?
Old Mar 19, 2005, 12:20 PM
twest is offline
twest's Avatar
Joined Jul 2001
First of all, astro makes brushless motors with 1/8" and 5mm shafts, so you can buy astro brushless with astro gearbox.
You can also buy both superbox and regular gearboxes with 5mm pinions. Mega motor/astro gearbox is a robust combo.
Here is a place to start: http://flydma.com/gearbox/36_gearbox...ath2=gearboxes
Note that on that page you can buy just the 5mm pinion gear, so if you have some astro gearboxes with helical gears you can buy just the pinion for 5mm shafts.
Astro makes great products but does not advertise all of them. Even their webpage (www.astroflight.com) does not show all details about their stuff.
Old Mar 19, 2005, 01:51 PM
Joined Aug 2000
Thanks Twest,
HOw should my timing be set for brushless motors. sirdirk007 Power Systems 4 Feb 10, 2005 11:30 AM
Can someone explain KV ratings for brushless motors. Brutus Power Systems 7 Oct 14, 2004 05:46 AM
CSD Twister (Carbon Model for brushless motors) jsc Aircraft - Electric - Airplanes (FS/W) 1 Oct 29, 2001 06:29 PM
Proper care for brushless motors?? rcastab Power Systems 4 Oct 08, 2001 08:47 AM
homebuilt controller for brushless motors Ron van Sommeren Power Systems 13 Jun 03, 2001 01:31 AM
