Old Mar 17, 2005, 12:52 AM
lazy-b is offline
Find More Posts by lazy-b
Manila, Philippines
Joined Jul 2004
How do you clean up those 20 years old IC's pin
Guys: How do you clean up those old ICs pins. to make it solderable, beside using a files and sandpaper......I have a bunch of 4N35 opto-coupler, its difficult to solder...its very difficult to clean those individual pin one by one....I was thinking of just droping the whole ICs in a Special Solution to clean up those pins?
I just wonder what kind of Solution should I use?
lazy-b is offline Find More Posts by lazy-b
Old Mar 17, 2005, 01:40 AM
pic man is offline
Find More Posts by pic man
Joined Mar 2005
solder with flux? though you prolly knew that thats my guess, ive never found a surface i couldnt solder
pic man is offline Find More Posts by pic man
Old Mar 17, 2005, 01:46 AM
Acetronics is offline
Find More Posts by Acetronics
"MAYONNAISE"
Acetronics's Avatar
Le Treport, France
Joined Jun 2004
Hi, lazy-b
Many solutions from the designer's drawer:
1) an old secretary's ink rubber ( for it's Remington's faults )
2) a fiber glass eraser pen
3) a special eraser to clean copper on PCB boards before hand design
from your favourite car painter
very fine grain ( 400 or more ) emery sheets or polishing paper
Regards
Alain
Acetronics is offline Find More Posts by Acetronics
Old Mar 17, 2005, 02:06 AM
Romych is offline
Find More Posts by Romych
Smolensk, Russian Federation
Joined Aug 2004
You can try Acetilsolicilum acid (Tablet of Aspirin). Plase pins on it and heat with soldering iron. But good ventilation required, bad smell
Romych is offline Find More Posts by Romych
Old Mar 17, 2005, 07:29 AM
die fliedermaus is offline
Find More Posts by die fliedermaus
die fliedermaus's Avatar
Kansas
Joined Jul 2002
The aspirin trick does work.
WHOOOOOOOOOOOEEEeeeeeeee what a stink though.
die fliedermaus is offline Find More Posts by die fliedermaus
Old Mar 20, 2005, 09:48 PM
lazy-b is offline
Manila, Philippines
Joined Jul 2004
Guys.....Thanks for all your advice.. I should try ASPIRIN next time.....Its much easier than filing or sandpaper.
Old Mar 21, 2005, 08:56 PM
Comatose is offline
Find More Posts by Comatose
Dimension Engineering
Akron, Ohio
Joined Jan 2002
Before you do that, try changing the solder you're using. Some fluxes are relatively whimpy.
I'm very partial to Kester 44. Its a little bit more than the crap you find at radio shack, but worth every penny.
Comatose is offline Find More Posts by Comatose
Old Mar 24, 2005, 08:34 PM
jperch is offline
Find More Posts by jperch
Too lazy to repair!
jperch's Avatar
Round Rock, Tx
Joined Oct 2002
What is coating the pins? Is it black?
Way back in the day, when I used to repair computers for a living, some chips pins would turn black over time. If they were soldered in place this was not a problem. But back then, many computer boards used sockets. This would cause connection problems. The thing is only certain manufacturers chips would turn black. Usually TI chips were the worst. The thing is that TI used to (maybe still do?) silver plate their pins. The black build up was silver tarnish. Just like your mom's good silver. What we used to do was to take the cips and dip them in a silver cleaner, then dip them in rubbing alcohol, then in hot water. Then we would let them dry. The alcohol would remove any residue from teh silver cleaner. The water would remove the alcohol. The parts would come out nice and shiny and work for several years after that.
But, I got to tell you, silver cleaner doesn't smell very good either.
JOe
jperch is offline Find More Posts by jperch
Old Mar 25, 2005, 12:30 AM
TMorita is offline
Find More Posts by TMorita
San Carlos, California, United States
Joined May 2002
I clean them with the green scrubbing pads in the kitchen section of my supermarket.
Toshi
TMorita is offline Find More Posts by TMorita
Old Mar 28, 2005, 12:58 AM
lazy-b is offline
Manila, Philippines
Joined Jul 2004
guys: the pin is not coated by Black, its color is Grey, when I try to Tin it with solder, the solder do not adhere to the pin. the ICs is made by PHILIPS......sometimes its too much work to clean up 40 pcs x 6 pins, thats 240 pin.....I rather buy new one.
next time will try the ASPIRIN or Silver clean as suggested by you guys.
Thanks.
Ellion
Old Mar 28, 2005, 09:12 AM
Gary Warner is offline
Find More Posts by Gary Warner
York Electronics
Gary Warner's Avatar
Dallas Tx USA
Joined Apr 1999
BTW, the fiberglass spot sanding pen is available from Pro Motocar Products. PH# 1-800-334-2843 or on the web at www.promotorcar.com . This is the same kind of product used be car-guys to clean the coms of the car motors. I use it to cut away PBC paint on boards that are broken and need to be jumpered. It's a very useful product for anyone who solders.
Gary
Gary Warner is offline Find More Posts by Gary Warner
Old Mar 30, 2005, 10:01 AM
epkoncept is offline
Find More Posts by epkoncept
San Diego Lindberg, California, United States
Joined Jan 2002
black-->silver oxide
FYI black coloration on a silver plated pin is not an issue. Silver oxide is a good conductor.
I've seen more discoloration of the pins of chips that were placed in the black antistatic foam. Don't know if it a coincidence but my older chips that were left in the black foam seemed to have dirtier looking leads ?
I've seen the funny discoloration, ie splotchy grey/tan color. I though it was just the under plating of the pins. I am not sure, how common it was a long time ago, but pins were often tin (Sn) plated over coppper. If you are really interested you can go to the last few pages of the manufacture's spec sheets and it should list the final finish of the pins and sometimes also the material used in the lead frame. If it is not listed in the back of the spec sheet, you will have to go to the package information catalog of that manufacturer.
epkoncept is offline Find More Posts by epkoncept
Old Mar 31, 2005, 04:27 PM
hwhall is offline
Find More Posts by hwhall
Joined Aug 2004
> discoloration of the pins of chips that were placed in the black antistatic foam<
I read somewhere that some of those antistatic foams, especially the older types, were subject to some kind of chemical breakdown that would actually corrode the pins of chips left in them for a long time. -Wayne
hwhall is offline Find More Posts by hwhall
How do you set up your two channel sailplane? ptlpc Thermal 11 Nov 05, 2004 07:45 AM
How do you clean servos aeajr Sailplane Talk 8 Feb 14, 2004 09:51 PM
How do you clean CA of covering film? vintage1 The Builders Workshop 15 Feb 08, 2004 05:56 AM
How do you set up your flap and aileron with Eclipse? Magna Electric Sailplanes 7 Jan 20, 2004 04:21 PM
How do you tighten up your Rotor nuts? Plane Crazy Electric Ducted Fan Jet Talk 9 Feb 09, 2002 09:09 AM
