Old Mar 26, 2002, 10:47 PM
Acer is offline
Find More Posts by Acer
Acer's Avatar
Loveland, Colorado
Joined Mar 2000
What are the Airfoils for the Zagi THL? (or similar)
I had a Zagi THL a couple of years ago and it flew pretty well. I want to cut scaled down version out of white foam but I threw out the THL before tracing the airfoil. Does anyone have the airfoil that was used for the THL, or do you have a good root/tip airfoil for a ~30" w.s. flying wing glider? Thanks.
-- Acer
Acer is offline Find More Posts by Acer
Old Mar 26, 2002, 10:59 PM
chlee is offline
Find More Posts by chlee
chlee's Avatar
Atlanta, GA
Joined May 2000
Zagi airfoil
Acer,
The Zagis have proprietary airfoils, Zagi-8, Zagi-10, etc. These are available with that Italian shareware program Profili.
However, you might do better with an MH-45. This is the airfoil used in the Wedgie and some other flying wings. The coordinates are available at:
http://beadec1.ea.bs.dlr.de/Airfoils/mhfoils.htm
I suspect that the MH-45 will perform better at the lower Reynold numbers of your scaled down wing. Or maybe the MH-44, which is slightly thinner...
Of course, if someone here actually knows something about aerodynamics, please correct me.
Lee
chlee is offline Find More Posts by chlee
Old Mar 26, 2002, 11:12 PM
Acer is offline
Acer's Avatar
Loveland, Colorado
Joined Mar 2000
Thanks Lee for the responce. I made a 24" glider using the MH45 airfoils. It worked well. Launched roughly 80 feet with a good throw. But, it only stayed up about 30-40 seconds. It would be a great mini sloper as it flew very well in wind and was extremely aerobatic. The MH 45 was a good FAST airfoil but I am looking for a slower more of a "Floater" airfoil. It probably needs to be a little thicker like the THL airfoil with a built in reflex. Any more ideas?
-- Acer
Old Mar 26, 2002, 11:20 PM
Acer is offline
Acer's Avatar
Loveland, Colorado
Joined Mar 2000
I forgot to ask, on all my flying wings I made, I always used balsa wood for the elevons. Would it work well to actually cut the elevons from the foam itself and thus have a "true" airfoil without having extended flight surfaces (balsa elevons). I've noticed that most of the F3J Flying wings of Europe use this method. Would it work well with smaller gliders?
-- Acer
What are the Airfoils for the Zagi THL (or similar) Acer Electric Sailplanes 0 Mar 26, 2002 10:48 PM
FT NIB Turbo 450 for Promax Cobalt (or similar) Megowcoupe Aircraft - Electric - Airplanes (FS/W) 2 Dec 06, 2001 09:50 AM
What is the best charger for zagi batteries? funflyer Power Systems 3 Jun 05, 2001 12:24 PM
What is the best charger for zagi batteries? funflyer Foamies (Kits) 2 Jun 04, 2001 10:07 PM
What is the fastest motor for a ZAGI! funflyer Foamies (Kits) 19 May 21, 2001 01:35 AM
