Old Mar 26, 2002, 07:42 PM
JFGrn is offline
Find More Posts by JFGrn
Head...Paper...Now!
JFGrn's Avatar
Valley Village, California, United States
Joined Mar 2002
Herr Fokker D VII
I thought I would share some pictures of my D VII flown by Willi Gabriel.
I built this model 2 years ago.
Its covered with Japanese Tissue.I designed and printed it on my computer.AUW. is 6.5oz, and with 8x270 mAh nimh
it fly's for around 10 to 12 min.
JFGrn is offline Find More Posts by JFGrn
Old Mar 26, 2002, 07:43 PM
JFGrn is offline
Head...Paper...Now!
JFGrn's Avatar
Joined Mar 2002
I'll try this?
Old Mar 26, 2002, 07:48 PM
JFGrn is offline
Head...Paper...Now!
JFGrn's Avatar
Joined Mar 2002
Sorry. For some reason it's not letting me post my pictures.
Will try again in the future.
Old Mar 27, 2002, 08:04 PM
JFGrn is offline
Head...Paper...Now!
JFGrn's Avatar
Joined Mar 2002
test
Old Mar 27, 2002, 08:05 PM
JFGrn is offline
Head...Paper...Now!
JFGrn's Avatar
Joined Mar 2002
So now it works
Old Mar 27, 2002, 08:06 PM
JFGrn is offline
Head...Paper...Now!
JFGrn's Avatar
Joined Mar 2002
JFGrn is offline
Head...Paper...Now!
JFGrn's Avatar
Joined Mar 2002
Old Mar 27, 2002, 09:31 PM
Dave Grife is offline
Find More Posts by Dave Grife
Dave Grife's Avatar
Coldwater, Mi. USA
Joined Jul 2000
Outstanding !!!!
what are the specifics regarding the equipment that your using??
Dave Grife is offline Find More Posts by Dave Grife
Old Mar 27, 2002, 09:57 PM
Joe Yap is offline
Find More Posts by Joe Yap
Singapore
Joined Nov 2001
Good Job! Are you using the scale hollow man's bust as the pilot?
Joe Yap is offline Find More Posts by Joe Yap
Old Mar 28, 2002, 12:27 AM
MichaelC is offline
Find More Posts by MichaelC
Upstate NY
Joined Oct 2001
Very nice! Equipment specs????
MichaelC is offline Find More Posts by MichaelC
Old Mar 28, 2002, 01:28 PM
JFGrn is offline
Head...Paper...Now!
JFGrn's Avatar
Joined Mar 2002
Responce
Thanks Guys,
Specs are:
First Version:3 channel Throttle, Elevator, Rudder, 2 CS10 Servos, 8x270 mAh nimh (They were the same size as the now 300 mAh nimh.), HY50D Motor 5:1 with a 7.25x4 Modella CO2 prop Hitec 5 speed control, and Carbon fiber Push rods.
Now: Same Everything Except, 8x270 mAh nimh (the new ones, same size as 110 mAh nicad's.)They hold there voltage better. and the GWS 5.9:1 Motor with an 8x6 GWS Prop.
Flight Charateristics are great, and alot of fun to ROG.
Old Mar 29, 2002, 11:18 AM
Gerald is offline
Find More Posts by Gerald
ὅπερ ἔδει δεῖξαι
Gerald's Avatar
Joined May 2000
Nice DVII! You did a great job at keeping the weight low. I'm almost finished with a Guillow's Thomas Morse S4C Scout which is the same size as the DVII and the weight will probably be almost 8oz. I couldn't resist adding ailerons so that added some weight.
Is 6.5oz what it weighs now with the present GWS motor, prop, and, newer 270 (110Nicad sized) cells? I haven't seen these yet. Do you know if they are lighter than the present 300mAH 2/3AAA NiMH cells?
Did you use the kit wheels? If so, are they vacuum formed like the ones in my Herr Pitts Special? I made homemade wheels for my Tommy which came out lighter than the Guillow's kit wheels but they still were a bit heavy at about 4g each.
Any wood replacement or strengthening done to beef it up for e-power?
-Gerald
Gerald is offline Find More Posts by Gerald
Old Mar 29, 2002, 09:08 PM
JFGrn is offline
Head...Paper...Now!
JFGrn's Avatar
Joined Mar 2002
Responce
Gerald
Thanks, Its was a fun Project!
Yes, 6.5oz is the AUW now.
As far as the batteries, they are about the same weight. They didn't have the 300s when I installed the 270s.
I did use the kit wheels which are laminated balsa. I do have a problem with them coming apart so I have to find replacement wheels.
I really didn't see a need to beef up the main structure other then installing the RC equipment. Although, I did change the landing gear, instead of the hard wood just glued to the fuse sides. I cut the hardwood struts per plan, but then glued Carbon fiber rod(.070) 2/3 the length of the inside part of the struts leaving 1/4 inch overhang at the top(to go into the fuse). Then capped each side with 1/16 sq. Balsa and shaped. On the inside of the fuse for hard points, I just glued 1/4sq.x3/8 long balsa then drilled to except the struts. Also, to save weight I used a carbon fiber axle instead of the piano wire. That alone cut half the weight of the landing gear assembly!
I hope that this makes sense.
Good luck with your S4C Scout, I would really like to see pic's , and hear how it fly's.
---John---
Rubber FF to E-RC Herr Fokker D.VII Zeroaltitude Scale Kit/Scratch Built 20 Dec 12, 2005 05:32 AM
Herr Fokker D-VII FF to RC conversion Zeroaltitude Scratchbuilt Indoor and Micro Models 1 Dec 05, 2005 09:31 PM
Herr Fokker D.VII for the winter/indoor season, help with paintschemes please! Zeroaltitude Scale Kit/Scratch Built 5 Sep 13, 2005 07:57 AM
Herr Fokker D-VII 4 ch indoor Davomatic Scratchbuilt Indoor and Micro Models 20 Aug 11, 2004 02:54 PM
Herr Fokker D-VII (24" Span) to r/c Lutin Scale Kit/Scratch Built 3 Oct 06, 2002 02:50 PM
