Old Mar 26, 2002, 06:25 PM
tqpham is offline
Find More Posts by tqpham
United States, OR, Portland
Joined Feb 2000
bandit instruction manual
Bought mine used and it didn't come with one. Could someone scan one and email me if it's only a few pages? Or fill me in on the set up parameters, especially for spoilerons. Also, where should the CG lie? TIA
tqpham is offline Find More Posts by tqpham
Old Mar 26, 2002, 07:25 PM
Adam Neat is offline
Find More Posts by Adam Neat
Adam Neat's Avatar
Winchester; Ohio
Joined Feb 2001
Ill check back here in a couple hours when I get home. The manual is pretty specific about control throws and the CG range. Ill grab it and give you the details here in a bit.
Adam
Adam Neat is offline Find More Posts by Adam Neat
Old Mar 26, 2002, 09:37 PM
Adam Neat's Avatar
Winchester; Ohio
Joined Feb 2001
Ok; Straight from the manual.
Ailerons; +10mm / -4mm
Elevator; +/- 4mm
Spoilers/Brakes; Ailerons +14mm, Elevator -1.5mm
CG 55mm back form the leading edge.
Adam
Old Mar 27, 2002, 06:24 PM
tqpham is offline
Joined Feb 2000
Thanks Adam for the info. Hopefully, I can get mine in air with a very humbled geared speed 480 by this weekend.
Mini IFO Instruction Manual? KatanaGuy Scratchbuilt Indoor and Micro Models 4 Oct 12, 2003 12:35 PM
Really GOOD training instruction manual needed Bigfoot Beginner Training Area (Aircraft-Electric) 3 Sep 24, 2002 07:54 PM
Instruction Manual Humor Dsegal Electric Plane Talk 13 Sep 24, 2002 07:42 AM
Wanted: Instruction Manual for SR Cutie Rudderman98 Aircraft - Electric - Airplanes (FS/W) 2 Jul 23, 2002 09:39 AM
needed: Instruction manual for FMS Supernova 250S Keitha Aircraft - Electric - Airplanes (FS/W) 3 Jun 18, 2002 07:11 PM
