Old Apr 03, 2005, 12:49 PM
Texy is offline
Find More Posts by Texy
Texy's Avatar
Newbury, UK
Joined Aug 2002
OK, I got some good results here.
3s2p lipo pack - didn't measure voltage, but it's freshly charged.
9047 gws WOT 13Amps 7600 rpm = ~ 19oz thrust
9-7 APC 11A 7000 rpm = 25oz thrust
This was about 3/4 throttle, but I couldn't mount the motor well enough for it to be safe - it kept rotating on my makeshift stand!
Texy is offline Find More Posts by Texy
Old Apr 03, 2005, 01:26 PM
ScienceGuy is offline
Find More Posts by ScienceGuy
United States, NY, Marion
Joined Sep 2001
Texy,
Speaking as one who has has a couple of motors "fly" right off a stand, do not continue testing until you mount much more securely!!!!!!!!!!!!!!!!!! Your esc, eyes or favorite/least favorite cat could be history in a split second.
Hugh
ScienceGuy is offline Find More Posts by ScienceGuy
Old Apr 03, 2005, 01:33 PM
Texy is offline
Texy's Avatar
Newbury, UK
Joined Aug 2002
I was careful - honest. I could tell it was moving around as the rpm's increased.
I,ve stopped now
All my previous motors have been in a gws gearbox so I,m wondering how
to stick mount it. I,ve seen cable tie wraps like the above used with epoxy,
but that would seem a bit permanent.
Komodo need to design a mount, one thinks
Texy
PS it was nice to see that my dvm measured 13amps, even though its rated to 10 only
Old Apr 03, 2005, 02:33 PM
Bilbobaker is offline
Find More Posts by Bilbobaker
Bilbobaker's Avatar
United States, UT, Salina
Joined Apr 2003
I use two sided servo tape and three nylon tie wraps and it seems to work fine.
The servo tape keeps it from slipping etc.
But the motors I've built have a little longer tube.
Bill
Bilbobaker is offline Find More Posts by Bilbobaker
Old Apr 03, 2005, 02:47 PM
Texy is offline
Texy's Avatar
Newbury, UK
Joined Aug 2002
Cheers Bill - that would seem to be the answer. I could see the tube twisting as I increased the throttle, but it didn't move forward. Lots of torque
Texy
Old Apr 03, 2005, 03:02 PM
radfordc is offline
Find More Posts by radfordc
radfordc's Avatar
United States, KS, Lansing
Joined Jan 2002
15 turns of 24 ga wire. Not nearly as good a Da V.
radfordc is offline Find More Posts by radfordc
Old Apr 03, 2005, 04:12 PM
hubgar is offline
Find More Posts by hubgar
Toronto Canada
Texy,
"Easy and cheap GS stick mount."
rysium posted this a while back. Go to post #55.
Hope it helps. Click
HERE
Hubert.
hubgar is offline Find More Posts by hubgar
Old Apr 03, 2005, 06:26 PM
Da V. is offline
Find More Posts by Da V.
You can do it!!!
Da V.'s Avatar
Joined Mar 2005
Hello to all,
Motor mount will come very very soon.
Da V.
Komodo Hobby
www.komodohobby.com
Da V. is offline Find More Posts by Da V.
Old Apr 04, 2005, 02:41 AM
Texy is offline
Texy's Avatar
Newbury, UK
Joined Aug 2002
Originally Posted by hubgar
Texy,
HERE
Hubert.
Thanks for that idea. What I still have from my slowstick is the black plastic tube that was for the tail removal option, which none of us use of course.
I will modify that in the same way as above.
Cheers,
Texy
Old Apr 05, 2005, 11:17 PM
columbiarcdude is offline
Find More Posts by columbiarcdude
columbiarcdude's Avatar
St. Louis, Missouri
Joined Oct 2000
My motors arrived today. They looked very very nice. Can't wait to wind one and put it in a plane and fly it.
Tom
columbiarcdude is offline Find More Posts by columbiarcdude
Old Apr 06, 2005, 07:01 AM
racer78bu is offline
Find More Posts by racer78bu
Racer78Bu
racer78bu's Avatar
Birmingham, Alabama, United States
Joined Jun 2004
finished first motor
I finished my first cd-rom last night. 12 turn 24 gauge n50's. All tests were good going to wire it to the speed control today and test it during the monsoon rianstorms were getting. Thanks again Da V.
racer78bu is offline Find More Posts by racer78bu
Old Apr 06, 2005, 09:24 AM
Modellhobby is offline
Find More Posts by Modellhobby
Modellhobby's Avatar
Lidköping/SWEDEN
Joined Aug 2003
Just tested first selfwound motor!
Measured the supplied wire - 0.6 mm - 23 gauge.
16 turn wye.
3s1500HD - 9x5HD - 6 Amps wot.
Runs very smooth.
I´m a happy, happy man!
Will be mounted on my Shocky Extra.
Stefan
Modellhobby is offline Find More Posts by Modellhobby
Old Apr 06, 2005, 09:40 AM
Texy is offline
Texy's Avatar
Newbury, UK
Joined Aug 2002
Did you measure thrust, or rpm's ??
Texy
Old Apr 06, 2005, 09:48 AM
Lidköping/SWEDEN
Joined Aug 2003
Sorry,
Don´t own rpm meter. Yet.
Haven´t built a teststand either so...no such data.
Flying will tell!
Stefan
Old Apr 06, 2005, 02:15 PM
Ron van Sommeren is offline
Find More Posts by Ron van Sommeren
homo ludens modellisticus
Ron van Sommeren's Avatar
Netherlands, GE, Nijmegen
Joined Feb 2001
Checks and tests to perform BEFORE connecting your newly wound motor, ESC and batteries, may save you from frying your ESC, first message in this thread, the rest of the thread is also worthwhile reading, bookmark it:
http://www.rcgroups.com/forums/showthread.php?t=240993
Vriendelijke groeten Ron van Sommeren
Ron van Sommeren is offline Find More Posts by Ron van Sommeren
Komodo KH-283 double stator outrunner motor kit Ron van Sommeren Power Systems 697 Feb 16, 2007 11:18 PM
Oveview the construction of Outrunner Motor Kit KH-278 - Part 2 Texy Power Systems 660 Aug 14, 2006 12:10 PM
New Komodo KH-283 Outrunner Motor Kit is available now at US$25.88 only!!! Da V. Power Systems 314 May 30, 2006 03:59 PM
Alert Great News! Super Offer of Komodo Hobby KH-278 Outrunner Motor Kit Da V. Power Systems 32 Mar 31, 2005 10:51 PM
Alert Komodo Hobby e-shop - "Outrunner Motor Kit KH-278" Da V. Product Announcements 2 Mar 15, 2005 09:39 AM
