Norfolk Intl, Virginia, United States
Joined Jul 2004
I limit my razor 400 to 20 oz planes and under now, seems to be better all around for my 3D flying. I'd really go with the E49. It takes my 56 in. 32 oz. plane straight up from my hand! Throw it in the Himaxx gearbox and your good to go.
Gwelan, Thanks! Randy |
Pasco, Washington
Joined May 2004
Randy
I can't figure out how you got to 38 oz. Can you substitute bluecor for some of the other materials? If you can get the weight down to 28 oz you would be a lot better off. I sure like the concept of a Bird Dog pusher. Keep going. |
Well, that's part of the problem. I'm still running the Nikon with the internal 2AA batts, so it and the canister are 10oz. My gear (Batt., servos, rx, esc and motor) is around 11oz (sp400 & GB are too heavy) The fuse is around 7 oz and the wing around 10 oz. Wing and fuse have way too much glue. I glued 3 layers of fff for the fuse and added some plywood in a couple of areas. I'm seriously considering building a wing jig to bake the fff in the oven, like I do my smaller wings. It would eliminate the rows of glue in the bend and makes a really rigid wing. I would be able to make 24" panels in my oven. That would probably save an oz. I'm certain that I could save another oz on the fuse and should save at least an oz on the motor upgrade. I think I may be stuck on the camera weight unless I run it on a single lipo, but I don't have a charger that will charge just one cell right now. So, overall I should be able to build the next one at least 3 oz lighter. So, I think I can get the next one down to 35oz, which would help a lot. But, even at 38 oz, it's only 8.3oz wing loading on the 60 inch wing, so with the right power it should be okay. At 35oz it would be really good at 7.64oz loading...that would be a real floater! It definitely has room for some improvement.Randy |
Joined Jul 2004
Randy, check out the thread on the SlowTabria on how to bend the wings. No need for glue in the bends or baking jigs, time consuming, heavy, and ugly.
Bend them, wrap them in tape and your flying. Mine never warp or bend and if they do, a little heat and your flying again. Overbuilding adds weight. My 56 in ST(SlowTabria) weighs 19.6 ozw/o battery, 30 ozs with camera and battery. You'll get yours down to 30 oz no problem. My 60 in.scratch built blufoam Buccaneer weighs all of 26 oz. (picture below) and its covered in Econolite. The E49 amps is correct on a 12in prop. with D gear. I've burst it to 18 amps/190 watts on the 13 in.prop. Little sucker is a sleeper, really goes. E49 w D gear, 1260 prop, apogee 3cell 1020ma. WOT-11.8 amps, 117 watts 1/2 throttle-5.9 amps, 63 watts With 2100ma, 3cell; 11.92 amps, 122 watts (12 in, Dgear) Hope that helps. |
Joined Jul 2004
Ridgetop..
Sorry I missed your earlier post (#21). What would I build next for a Cessna style AP plane? Why, the SlowTabria of course!
I haven't posted the latest video yet, but this thing flies great and does stuff they are not normally supposed to due! I'll post it when its done. Giving it some thought, I would probably work on a AP Seaplane, waterproof and tough. If I can hook a lure to it, maybe do some aerial fishin'! Or maybe build the "NoodleDog", Randy's new bird into a Seaplane! Just think, pictures in the air, and when it lands in water, snap some underwater shots too!
You know, you make that sound almost possible! Well, at least you know it won't sink. Randy |
| Thread Tools | |
| What do you get when you combine a CP piccolo and a nitro airboat? | rkramer | Micro Helis | 3 | Jul 05, 2005 04:02 PM |
| What do you get when you have a 3 way? | Larry3215 | Sport Planes | 5 | Oct 21, 2004 02:29 AM |
| what do you get when you cross a Picco stick and a tm | Pablito | Parkflyers | 20 | Feb 06, 2002 09:51 AM |
