Old Mar 14, 2005, 04:56 PM
andrew b is offline
Find More Posts by andrew b
dieselburner
andrew b's Avatar
Wyke, Bradford, west yorks
Joined Mar 2005
Kestrel Autogyro
Has anyone built one of these models, a free plan from RCME in 2003 ?
If you have and it flys, would you be able to help me clear up some details which aren't clear on the plan or in the magazine article.
andrew b is offline Find More Posts by andrew b
Old Mar 14, 2005, 09:53 PM
jodini is offline
Find More Posts by jodini
AND FOR MY NEXT TRICK....!
jodini's Avatar
Omaha Millard, Nebraska, United States
Joined Sep 2004
Have you checked out this........
http://www.autogyro.com/models/bishop/kestrel.htm
jodini is offline Find More Posts by jodini
Old Mar 15, 2005, 03:34 PM
boberos is offline
Find More Posts by boberos
Ontario Canada
Joined Aug 2003
That plan on ebay is an old controline plan. Interesting though.
Scientific had a 1/2A controline gyro years ago. Saw one fly at Florida gyro meet last year. Wing was pretty big so I am not sure if the blades contributed much lift or just went along for the ride. Fun to watch.
boberos is offline Find More Posts by boberos
Old Mar 15, 2005, 03:45 PM
boberos is offline
Ontario Canada
Joined Aug 2003
Sorry guys,
My response above was intended for the "more autogyro video" thread.
About the Kestrel, it looks a lot like Dave Boddington's 'Gyrace' to me.
Old Mar 15, 2005, 03:55 PM
andrew b is offline
dieselburner
andrew b's Avatar
Joined Mar 2005
Thanks, Jodini, I read that article with interest and maybe it confirmed a suspiction
On the plan, the C of G is given as almost under the leading edge, while the text in the magazine article gives it as 1 3/4 inches back from the L.E, just about under the main spar! If he built his without the article and balanced it as per plan, it would be rather nose heavy and sluggish to respond
I have decided to modify the rotor bearings from those given in the plan by using model car bearings for the top bearing, and plain plastic car bearings for the lower set. I intend to power it with a PAW 35 diesel, as the fuel economy will be much greater thereby saving 3 or 4 ounces in the weight of the fuel. ( I like diesels)
The model as standard looks "bare" without a cowl, I will see how the motor sits on the mount before I can decide on the cowl, although the tail wheel as shown could be a good hidden counter balance the weight for the cowl
Old Mar 16, 2005, 09:01 AM
jodini is offline
jodini's Avatar
Joined Sep 2004
You could just take an old 1/2a cox engine...take out the piston, off the back plate and bolt it down. An easy rotor head!
Old Mar 16, 2005, 12:28 PM
andrew b is offline
dieselburner
andrew b's Avatar
Joined Mar 2005
them little cox motors are worth money here in the UK , I'll stick with car bearings at 2.50 each (reckon thats still a rip-off)
Old Mar 16, 2005, 12:30 PM
andrew b is offline
dieselburner
andrew b's Avatar
Joined Mar 2005
I built a gyrace some years ago and it flew pretty well until the brass bush bearing siezed in flight and the rotor stopped
Old Mar 16, 2005, 12:34 PM
andrew b is offline
dieselburner
andrew b's Avatar
Joined Mar 2005
since then I have had the work/wife/children illness
Old Apr 15, 2005, 01:56 AM
andrew b is offline
dieselburner
andrew b's Avatar
Joined Mar 2005
a leap forward
Luck was on my side yesterday....I was driving past a closed down model shop yesterday, I spotted the owners clearing out thier stock and picked up 2 new in the box PAW 35 r/c motors including 7 tins of D1000 for 80
to follow on from that, I called in at the local bearing shop, who sold me 4 beautiful sealed stainless steel flanged instrument bearings as "obsolete" stock (4mm X 10 X 5). the rotors should rotate just by looking at them
Old Apr 17, 2005, 06:28 AM
andrew b is offline
dieselburner
andrew b's Avatar
Joined Mar 2005
ahhh, kicking myself over the bearings now, I pulled the spindle motor out of a dead hard drive and it has 2 beautiful sealed instrument bearings 5 X 13 X 4 mm
Old Feb 08, 2006, 03:01 PM
johnvb is offline
Find More Posts by johnvb
Canberra, Australia
Joined Nov 2002
How did the Kestrel end up AndrewB? One of my mates is about halfway through building one as well, but blown up to .46 size.
johnvb is offline Find More Posts by johnvb
Old Feb 11, 2006, 06:14 PM
andrew b is offline
dieselburner
andrew b's Avatar
Joined Mar 2005
I haven't had chance to try it, my "flying field" (swamp?) floods during the winter and its been too cold. Hopefully will have a chance over the next few weeks.
Old Feb 11, 2006, 09:38 PM
David Hogue is offline
Find More Posts by David Hogue
Blew out my flip flop
David Hogue's Avatar
USA, NC, Clayton
Joined Feb 2001
I have a used Kestrel here, I got at a swap meet recently. It was flown with a glow engine, but I intend to electrifly it. The previous owner told me to balance it at about the LE of the "wing" so that goes along with what you said about the cg earlier, Andrew. I am waiting for a motor to come in that should work pretty well on this...should be interesting if nothing else!!
David
David Hogue is offline Find More Posts by David Hogue
Old Feb 12, 2006, 07:30 AM
andrew b is offline
dieselburner
andrew b's Avatar
Joined Mar 2005
Electrify My kestrel has a PAW 35 diesel swinging a 12 X 6 " master airscrew @ 8500 rpm on "straight" fuel.
I have a copy of the plans and the magazine article if you need them. The CG on the plan is 3/4" before the LE and mine wieghs in lightly at 3lb 8 oz.
