Old Mar 14, 2005, 12:09 PM
dstrout is offline
Find More Posts by dstrout
Proudly 2.4GHz free!
dstrout's Avatar
Alexandria, VA, USA
Joined Feb 2003
Must-do mods for Piccolo Fun?
After some internal debate (and not getting what I wanted for it on Ebay ), I have decided to put together & fly my Piccolo Fun. I'll be using the Piccoboard Plus (or whatever it is -- has HH module, but not RX) for the moment. If I get it flying at all & like it, I'll switch to separates & cd-rom brushless, but I'm not willing to put another $200 into it before it ever leaves the ground.
Anyway, my intention was to build it exactly to the manual, rather than my usual "spirit of the manual" (prop in front, tail in back, battery in between) mode that I use for my airplanes. But, if there are any "must-do" mods, I'd like to know about them now. I don't mind putting another $40-50 into it, but I'd like to avoid spending more than that.
Also, where is a good place, other than helihobby (want to avoid), and hobby lobby (already know), to find piccolo parts?
thanks,
dave.
dstrout is offline Find More Posts by dstrout
Old Mar 14, 2005, 01:55 PM
∆nima is offline
Find More Posts by ∆nima
∆nima's Avatar
London Heathrow, Great Britain (UK)
Joined Oct 2003
These upgrades will make the biggest difference and should be done first, not that you cant fly it stock.
1. Ball bearings for head teeter, main shaft and tail.
2. Lipo batt
3. CNC ar link
4. ball in swash
Look on the ikarus picolo forums for info on blade trimming to pick up the headspeed a little to improve cyclic.
should be around $40 worth, i got everything in sterling so its hard to say.
∆nima is offline Find More Posts by ∆nima
Old Mar 14, 2005, 02:53 PM
dstrout is offline
dstrout's Avatar
Alexandria, VA, USA
Joined Feb 2003
cool, thanks. What's an "ar link" -- that one I don't recognize...
thanks,
dave.
Old Mar 14, 2005, 03:02 PM
Airwolfie is offline
Find More Posts by Airwolfie
in the interlink, on a big wet island
Joined Nov 2003
anti rotation link. the bit of plastic that is connected to the main shaft and the swashplate, it prevents the swash from rotating. get it? got it lol!
http://www.helihobby.com/html/piccolo_upgrades.html
I don't like to advertise for helihobby but they got nice pictures hehehe!! so go to this link and scroll down to almost the bottom, you will find them there.......
Airwolfie is offline Find More Posts by Airwolfie
Old Mar 14, 2005, 03:10 PM
Mod-junkie is offline
Find More Posts by Mod-junkie
You win again Gravity!
Mod-junkie's Avatar
AZ
Joined Dec 2004
I just got done building my pic fun kit and the bearings are a must the nylon ones are garbage.
Also later on you might want to pick up an aluminum swash.
Mod-junkie is offline Find More Posts by Mod-junkie
Old Mar 14, 2005, 03:19 PM
Eric Cartman is offline
Find More Posts by Eric Cartman
Joined Sep 2004
did you all forget about the cnc hub?
Eric Cartman is offline Find More Posts by Eric Cartman
Old Mar 14, 2005, 03:45 PM
lorents is offline
Find More Posts by lorents
Team MasterCard
lorents's Avatar
Norway, Oppland, Jevnaker
Joined Dec 2004
Get the anti-rotation link with two arms - that will keep the swashplate steadier.
Alu swash plate is great, but you can also get the plastic swashplate for Piccolo V2 - this one has a ball in the middle.
Lipos are a must...
You dont need the alu hub until you crash and break the plastic hub
Lorents
lorents is offline Find More Posts by lorents
Old Mar 14, 2005, 03:52 PM
kramer is offline
Find More Posts by kramer
top enforcer
kramer's Avatar
LaPorte, IN, USA
Joined Mar 2003
Wire landing gear,will save on frustration
kramer is offline Find More Posts by kramer
Old Mar 14, 2005, 06:46 PM
Geoffrey109 is offline
Find More Posts by Geoffrey109
Blade Springs "Rock"
Central Coast, CA
Joined Apr 2004
You can avoid the "death wobble" by installing rotor springs......
G109
Geoffrey109 is offline Find More Posts by Geoffrey109
Old Mar 15, 2005, 01:37 AM
helifrek is offline
Find More Posts by helifrek
3D Printing Enthusiast
helifrek's Avatar
United States, TN, Clarksville
Joined Feb 2004
if you have the stock tail setup you might want to invest in the DD (direct drive) tail rotor system, with your HH gyro and a DD tail, it should be rock solid. or, for $14 bucks "I think" you can get a ducted fan tail. works good with a HH gyro, I don't know which is better, I just like the way it looks also, I would invest in a one way kit as this will make flying smoother. sudden rpm changes in the motor = torque changes which will affect the yaw, so... that is a good investment but not absolutely necessary for it to fly well, I have a cut down FP w/o one and it flies well. good luck and keep us tuned in on your progress.
Brandon
helifrek is offline Find More Posts by helifrek
Old Mar 15, 2005, 01:53 AM
cormu is offline
Find More Posts by cormu
Kšnni Perkele
cormu's Avatar
Helsinki Vantaa, Finland
Joined May 2004
The 7.2 v tail motor is aa must if u use lipos (3cell)
and you would probablly need to upgrade the FETS and BEC on the piccoboard + i have PB+ and blew the fets real fast with liopos and a 310 motor .
You will need to use 2 IDENTICAL BEC regulators otherwise they do not share the load equally My board was cutting out all the time untill i added the second BEC now it has worked flawlesslly for over a year and half
the FETS are a higher ampage rating 10 A the origional ones are only 5 -8 amps if i remmebr corectlly
Here is a link to the mods i made on the picco board sorry but all part numbers are for RS I am in Finland.
http://www.cjp.fi/cormu/e107_plugins...?album=5&pos=1
cormu is offline Find More Posts by cormu
Old Mar 15, 2005, 05:13 AM
dstrout is offline
dstrout's Avatar
Alexandria, VA, USA
Joined Feb 2003
Cool, much thanks! Two questions: 1.) can anybody suggest a good place to get this stuff? and 2.), are those rototr springs a home-made thing, or something you can pick up?
I started building last night, and almost immediately stopped. Those plastic bushings look like they would be a real bear to get back out, so I'm going to wait until the bearings come and just install them to begin with. I though my Eco bearings were going to fit, but no such luck
I'm already set on the lipo front -- I have 3 or 4 2-cell packs of the qualcomm 950 phone bats from the Eco, plus a truckload of Etec 2s1p 1200's for my planes.
thanks,
dave.
Old Mar 15, 2005, 05:18 AM
dstrout is offline
dstrout's Avatar
Alexandria, VA, USA
Joined Feb 2003
That's with 3s, right? I'll be flying 2s1p lipos. Should I still go with either the "high authority" tail motor, or direct drive? I've got a johnson 250 with a 3x2 GWS prop on it from a pocket combat wing I could use. Or buy a DD kit.
thanks,
dave.
Old Mar 15, 2005, 09:10 AM
cormu is offline
Kšnni Perkele
cormu's Avatar
Joined May 2004
Ya that was with 3 cells, I dont beleave i have heard of anyone having trouble with 2 cells, But do buy the GWS high voltage tail motor and DD
I have had same motor now for over a year and its still going strong .. Before i changed it i was blowing a motor every other week including the Pic pro motors , the one im using now was ripped out of a IPS drive. sounds like the motor u have is perfect
3x2 is corcet size prop .
Old Mar 15, 2005, 12:10 PM
dstrout is offline
dstrout's Avatar
Alexandria, VA, USA
Joined Feb 2003
Holy smokes! I just priced a bearing set -- $30 from Helihobby, $39 from Boca, and $50 from hobby lobby! I'll check & see if maybe the bearings from my Eco will fit, and were just tight, but I think plastic bushing + white lithium greese may have to do
Question Mods for Piccolo to hover better?? Butch777 Micro Helis 11 Mar 10, 2007 04:04 PM
Zoom 400, 'must do' Mods? Brill 1 Mini Helis 4 Aug 01, 2004 11:33 PM
nimh question for Piccolo Fun tadatuo Micro Helis 7 Jan 31, 2004 12:41 AM
batteries for Piccolo fun Munch Micro Helis 2 Mar 09, 2003 08:22 PM
Fun Piccolo w/mods for sale Speedfreak Aircraft - Electric - Airplanes (FS/W) 0 Oct 20, 2002 12:11 AM
