Joined Dec 2004
Does this motor work with the stock aerohawk?
Wanted to know if this motor (High Authority Tail Motor - Wired w/ Pinion) will work as an upgrade to the stock tail motor on the aerohawk. Also, I'm using a 2 cell 1200 mah lipo.
http://www.helihobby.com/html/skylark_upgrades.html Or would it be better to do a dual tail motor setup? (Twin Tail Motor Mount and tail Guard Kit) http://www.helihobby.com/html/skylark_upgrades.html Or are there any better ideas? Also, does anyone know where I can purchase a monster 4200 pro carbon tail motor? Thanks |
Tampa, FL
Joined Jul 2004
You could jsut get the GWS edp50 motor, http://www.balsapr.com/catalog/motor...oductId=gws100.
It the same thing as the high authority motor from Ikarus (someone correct me if I am wrong). Its cheaper, like 10 bucks and you dont need to use gears, it will give u solid performace in DD. The monster 4200, I think, can be found at heli-fever.com Virat |
San Carlos, California, United States
Joined May 2002
This is the same motor as the "high authority tail motor".
You'll need a pinion puller to move the pinion. http://www.balsapr.com/catalog/motor...ductId=S663356 Toshi |
Central Coast, CA
Joined Apr 2004
I can't report on the High Authority Motor, didn't have it in long enough. Like I said, the N20 is the way to go.....It's made for 7.2 volts and it's a brushed motor....Also the Esky Tail Motor is reporting longer lasting without weight penalty, I also flew a Colco Motor a long time, but it was 50/50 one good one bad......Don't focus too much on tail brushed motors.....keep buying them, I still have stock motors just incase.....as long as you don't put the 3s1p power on them they sometimes last a long time.....
www.homefly.com has N20 motors... G109 |
Joined Dec 2004
Joined Dec 2004
Do you mean removing them from the stock tail motors? |
| Thread Tools | |
| Discussion Will this motor work to 3d with Flatana | north dakota kid | Power Systems | 6 | Jul 07, 2006 10:13 PM |
| Question Will this motor work with shockyflyers | bamm | 3D Flying | 36 | Apr 12, 2005 04:46 PM |
| Will this ECS work with this motor? | blk96gt | Power Systems | 3 | Feb 23, 2005 07:47 PM |
| Question Will this motor work with this plane??? | raythomas | Parkflyers | 10 | Jan 02, 2002 08:06 PM |
| How does this all work? | Teamairplane | Electric Plane Talk | 5 | May 27, 2001 05:20 PM |
