Old Mar 13, 2005, 08:53 PM
acewannabee is offline
Find More Posts by acewannabee
Crash Test Pilot
Jacksonville,Florida
Joined Jan 2005
JR Quattro Tx not working with ESC
JR quattro lite Tx R610M receiver works great with my 20a E-Flite esc.
Just got a new(maybe) great planes ESC GPMA2429 when its powered up the little red light comes on but no out put to motor I checked the V.and use motor to check it.I checked the switch on the esc and it reading fine.
I shaved off the tab just like i did for Hitec servos and they work fine.But do i have to do something else for a Great Planes esc...
is there somthing with the center pos.wire??
btw bought off e-bay it was in a sealed plastic bag from the factory.I looks like the original stuff but i can't find the model # or cat# on the web site.it also says slinger arf on the bag...
thanks for any help.
acewannabee is offline Find More Posts by acewannabee
Old Mar 14, 2005, 10:43 AM
RGHCOWNER is offline
Find More Posts by RGHCOWNER
LAS CRUCES, NEW MEXICO
Joined Jul 2003
esc woes
When the red light comes on does it stay on or does it flash?
Have you tried waiting a bit, pull the throttle all the way down and then back up?
Is the motor rating on the esc right for the motor you are using?
I've used 610s a lot for electric and sometimes I've gotten an esc that just doesn't want to work.
RGHCOWNER is offline Find More Posts by RGHCOWNER
Old Mar 14, 2005, 01:26 PM
ebill3 is offline
Find More Posts by ebill3
ebill3's Avatar
United States, WA, Puyallup
Try this.
Make sure the throttle is at cut off when you switch on.
Go to WOT and hold it there for several seconds.
Back to cut off.
Now advance throttle and it should be OK.
Bill
ebill3 is offline Find More Posts by ebill3
Old Mar 14, 2005, 05:10 PM
Crash Test Pilot
Joined Jan 2005
hhhheeeeeyyyyyyy!!!!!! ebill3 you are the man!!!!! I should pay pal you a service call.Pluged inthe batt.turned on the esc the light came on, held wot then the light started blinking (guess i missed that last night).pulled back and then works fine.Looks like I have to do this every time.??no big deal.Do you have any exp.with this model GPMA2429??I'm wondering what the specs are.I'm going to do a best test tonight to find out about the bec if it has one and see if it can handel the motor for a full run.it shoud it was supplyed for a 400 speed.Is this standard for great planes esc's???
thanks again.
Old Mar 14, 2005, 06:01 PM
ivanc is offline
Find More Posts by ivanc
S.A.D. member
ivanc's Avatar
United States, TX, Round Rock
Joined Dec 2004
Yes, that's the initializing procedure of the ESC. Its purpose is pure safety. If you turn the Rx on BEFORE the Tx then the ESC will not load (initialize) and you can not accidentaly start the motor. Looks like it's standard for GP/Hobbico ESCs.
ivanc is offline Find More Posts by ivanc
Old Mar 14, 2005, 09:15 PM
ebill3 is offline
ebill3's Avatar
Ace - Sorry, I don't have any info on that ESC. Glad it is working OK. As ivanc said, that appears to be the standard GP routine.
Bill
Cool E-flight brushless motor not working with my ESC? Bgarrett777 Power Systems 3 Mar 17, 2005 09:12 PM
Question Jr XP651 not working with JR GWS crystals/receivers? machine Radios 7 Jun 29, 2004 09:24 PM
FS: JR Quattro TX on ch 27 with JR grey cap ch 27 RX crystal Dukester Aircraft - Electric - Airplanes (FS/W) 7 Jun 28, 2004 07:59 PM
FS: JR Quattro TX on ch 27 with JR grey cap ch 27 RX crystal Dukester Aircraft - Fuel - Airplanes (FS/W) 3 Jun 28, 2004 07:58 PM
FS: JR Quattro TX CH 26 with warranty (4 months old) temp_oct Aircraft - Electric - Airplanes (FS/W) 7 Nov 04, 2003 05:07 PM
