Old Mar 25, 2002, 08:59 PM
varnellb is offline
Find More Posts by varnellb
Longview, Tx
Joined Oct 2001
what weight to thrust ratio for rog?
I was just wondering what thrust I would need to get an airplane off the ground. My friend wants to put a camera in a plane for a project. Thanks,
Brandon
varnellb is offline Find More Posts by varnellb
Old Mar 25, 2002, 09:27 PM
DaveW is offline
Find More Posts by DaveW
Folsom,Ca,USA
Joined Apr 2001
Sorry,
No simple answer to this one. Depends on type of plane, airfoil etc...
However, I have seen a Pico Cub carry a throw away camera and micro servo to trip the shutter, velcroed to the fus side. Plane flew about the same with the extra weight as without and its not that big a plane.
works best to have camera pointing towards the wingtip. That way you point the wing at what you want to take. Works much better than pointing forward. Owner was pretty good at taking picture of what he wanted to see.
Of course you get one picture per flight.
It had a S400 with a 2.3:1 gearbox powering it.
Hope this helps
Dave
DaveW is offline Find More Posts by DaveW
Old Mar 25, 2002, 09:52 PM
varnellb is offline
Longview, Tx
Joined Oct 2001
thanks,
My friend found a good deal on a home security camera or something and we gutted it out. part of the transmitter is a little heavy, but not exactly sure how much weight it will add. Hopefully it will work out.
Old Mar 25, 2002, 10:03 PM
ScottS is offline
Find More Posts by ScottS
ScottS's Avatar
Houston,TX
Joined Mar 2000
No easy answer. What type of ground- smooth concrete or 4" grass. What type and size of wheels, how easy do they roll. How big is the airplane?
In some cases the thrust won't really matter, I have a couple of taildraggers that will simply pull themselves noseover when wheels get stuck in the grass.
ScottS is offline Find More Posts by ScottS
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
Depends on the length of the runway.
One of the reasons for flying boats was the runway length was unlimited, so the power installed could be sized to the cruise requirement, not the takeoff situation.
As chase for the S3A we used a Grumman TF9F-6 Cougar .. A fighter plane.. which was runway length limited at Palmdale in the summer time. 12,000 feet was too short!
Sparky Paul is offline Find More Posts by Sparky Paul
Old Mar 26, 2002, 10:13 AM
Dick Huang is offline
Find More Posts by Dick Huang
Dick Huang's Avatar
Dallas,TX, USA
Joined Mar 1999
I would use a weight to thrust ratio of 3 as a minimum.
This will take a long runway; try hand launching the plane with a helper that can run at 10 to 15 mph!
Dick Huang
Dick Huang is offline Find More Posts by Dick Huang
Question Weight to Thrust ratio gbarc Scratchbuilt Indoor and Micro Models 2 Sep 06, 2006 02:43 PM
what kind of thrust is better for my formosa? jeff262 Power Systems 18 Apr 01, 2004 03:04 AM
So really, what is the turn-around-ratio for a 9-12 cd-rom motor? landru Power Systems 1 Mar 12, 2004 01:22 PM
At what weight to thrust ratio does a plane fly good? Nik-rc Power Systems 14 Jun 21, 2003 03:51 PM
1:1+ weight-thrust ratio? Wheazel Electric Ducted Fan Jet Talk 3 May 02, 2003 05:53 PM
