Old Mar 12, 2005, 04:22 PM
didiver is offline
Find More Posts by didiver
carpe diem
didiver's Avatar
Belgium
Joined Dec 2004
14.4V for speed 600 8.4V
Hello,
can i put 14.4V on a speed 600(8.4V)?
thanks
didiver is offline Find More Posts by didiver
Old Mar 12, 2005, 04:32 PM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
As long as you make sure your prop is small enough to limit the amp draw, and that your ESC is rated for 4s. Watch the maximum rpm too - bouncing brushes are not a good thing!
Cheers, Phil
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Mar 12, 2005, 04:33 PM
Chippie is offline
Find More Posts by Chippie
North East England UK
Joined Jan 2003
you probably could...and with a prop on it, it wouldnt last long....
Cant you reduce the cell count...or is this a lipo pack....?
even that could be reduced.
Chippie is offline Find More Posts by Chippie
Old Mar 12, 2005, 04:42 PM
didiver is offline
carpe diem
didiver's Avatar
Belgium
Joined Dec 2004
ok... i will reduce... put it's not lipo but nicd...
it's actually 2 speed 600 in "parallele", so i must take good nicd to have about 50Amp..
what is the best for 50Amp?
Old Mar 12, 2005, 06:13 PM
didiver is offline
carpe diem
didiver's Avatar
Belgium
Joined Dec 2004
is it dangerous to run with 14.4V for motors of 8.4V?
thanks
Old Mar 12, 2005, 06:19 PM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
NONONO.
It will be fine on 14v. Assuming its the #3301 or #3316, and assuming its either geared, or running a small prop (6x4 or 7x5)
But you need to be more specific: There are at least 5 models of 'speed 600, 8.4v'
Race #6312
BB SP #6313
BB SP #6309
BB #3316
straight #3310
Two are possibly a bit marginal.
But the rest will do the 20k plus RPM that that sort of voltage implies no problem.
Old Mar 12, 2005, 06:29 PM
didiver is offline
carpe diem
didiver's Avatar
Belgium
Joined Dec 2004
ok.. thanks.. it's #6312..race, so i continue with 14.4V.. but motors will be too hot? no?
Old Mar 13, 2005, 05:04 AM
vintage1 is offline
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
on DD a 5,1 x4.5 prop pulls around 30A and is about the limit I'd say. In bursts! Probably over propped even then 4.1x4.1" prop maybe.
But RPM is only 28,000 or thereabouts: That is probably OK.
Best efficiency will be at somethong like 15A or so, so provided you can operate in the sub 20A region it should be OK.
3.5:1 gears and a 10x7 gives a nice sort of power on 12 cells at low 30K RPM.
(9k at the prop)
Its not a question of heat so much - more a question of wherther the brushes and armature can physically take the RPM.
The #6312 looks like a sagami with the open brush gear.
If you have a whattmeter, try it on a small prop - 4x4 or so, and spin it up slowly to see if it starts to get erratic at full power - try and keep the current under 25A - 20A if possible - and get a feel for how hot it gets.
Too hot to touch is OK, over boiling point is too far. wet finger is a good test.
If it can handle the RPM, then its just a question of limiting the current to something sane.
Old Mar 13, 2005, 12:45 PM
717 is offline
717
Find More Posts by 717
717
717's Avatar
SF Bay Area, CA, USA
Joined Apr 2003
Vintage1,
Does your finger touch temp test apply to brushless outrunners as well?
717 is offline Find More Posts by 717
Old Mar 13, 2005, 05:38 PM
vintage1 is offline
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
Just about, but neodym magnets ar even more fragile than ferrites. I'd be worried about a motor that was over 100C on the case exterior with neo magnets.
I can't remember the curie point but its not a lot higher than that. Usually the glue softens and the magnete fall off anyway
Cobalt is the magnet that can stand heat. 300C or more.
What Battery for Speed 600 8.4V EricE Batteries and Chargers 1 May 22, 2005 04:51 PM
~~FS~~ TWO Speed 600 8.4v motors NIB jbc455 Aircraft - Electric - Airplanes (FS/W) 0 Jun 18, 2003 05:04 PM
~~FS~~ TWO Speed 600 8.4v motors NIB jbc455 Boats (FS/W) 0 Jun 18, 2003 05:01 PM
Speed 600 8.4V Flint Power Systems 10 Jan 15, 2003 08:08 PM
graupner speed 600 8.4v race motor aryeh Electric Plane Talk 12 Jan 09, 2002 08:11 PM
