Old May 09, 2001, 02:58 AM
atsiang is online now
Find More Posts by atsiang
San Jose, California, United States
Joined Feb 2001
Anyone have experience with this Speed 300?
Hi
I was looking at Hobby Lobby's website and came upon the Simprop Electronic Speed 300 motor. Does anyone have previous experience with this motor? How much better is it than the Graupner Speed 280?
Al
[This message has been edited by atsiang (edited 05-09-2001).]
atsiang is online now Find More Posts by atsiang
Old May 09, 2001, 11:57 AM
KeithK is offline
Find More Posts by KeithK
What Canary?
KeithK's Avatar
Huntsville, AL USA
Joined Jul 2000
It performs as described in the H-L text. This is the motor they sent out to cure underpower problems in a lot of their WW1 Foamies such as my Sopwith Pup. Can't say it is "better" but as the text says, it puts out a lot more power and uses a lot more amps.
KeithK is offline Find More Posts by KeithK
Old May 09, 2001, 02:19 PM
jberg is offline
Find More Posts by jberg
jberg's Avatar
MSC Rödinghausen, Germany
Joined Feb 2001
Hi,
the Speed 300 makes the difference between cruising and hovering for indoor models, but it needs *a lot of* amps. The power level is almost at Speed 400 level. Use a high gear ratio, at least 5:1. Use at least 350mAh NiCd's, 500AR/600AE fit better. By the way, this motor is good for very small ducted fan units due to its high kv (revs per volt) ratio.
Jochen
jberg is offline Find More Posts by jberg
Old May 09, 2001, 04:45 PM
Bill Glover is offline
Find More Posts by Bill Glover
Bill Glover's Avatar
United Kingdom, Bracknell
Joined Nov 2000
Sounds like similar characteristics to the Permax 280 BB? That's rated at 30W output (versus 12W for the stock 280).
Bill Glover is offline Find More Posts by Bill Glover
Old May 09, 2001, 07:34 PM
Joined Feb 2001
I was thinking about using this particular Speed 300 to power my GreatPlanes BLT but wasn't sure whether it would too overpowering.
Old May 09, 2001, 08:30 PM
busheadfox is offline
Find More Posts by busheadfox
Sandston Va USA
Joined Mar 2001
I tried one as a replacement for a 280 motor in a form bi-wing plane and it worked pretty well but only lasted 3 or 4 flights before it burned up. Lots of current and battery didn't last very long either. Havent tried another one yet. Gave up on 280 motors and use either gws systems or speed 400 on slightly larger planes.
busheadfox is offline Find More Posts by busheadfox
Discussion Anyone have experience with this Cox EP 380 Trainer? IWC Parkflyers 2 Oct 20, 2006 08:24 AM
Discussion Anyone have experience with GWS speed controllers? ibange Power Systems 4 Oct 05, 2006 08:08 PM
Discussion Anyone have experience with this Birddog kit? IWC Scale Fuel Planes 4 Sep 22, 2006 01:47 PM
Anyone have experience with this kit? ave Scale Sailplanes 5 Aug 29, 2005 04:45 AM
Anyone have experience with this plane? LLoo Electric Plane Talk 11 Aug 12, 2005 04:34 PM
