Old Mar 11, 2005, 10:58 AM
Vagabond324 is offline
Find More Posts by Vagabond324
RETIRED PHILLY FIREFIGHTER
Vagabond324's Avatar
Philadelphia, PA USA
Joined May 2004
My 2nd. electric aircraft. help needed
I am working on an ARf that has very poor instructions and I am tring to figure out what Power system to put in it that would work the best.
The airframe is a pusher configuration called a Sky Arrow by Hacker. The max prop size appears to be about 6 inches. The box states the following
Motor : 280 to 400 size motor.
WS : 1080mm (41 11/16)
Length: 780mm (30 11/16)
Weight 400-500g I believe this is around 14 to 17.5 oz.
I want to fly this aircraft with floats later on so I need the most power possible. I'm sure this weight is without any electronics installed like servos or reciever. I plan on using a Hitec 555, 3 HS-51 servos as well as the appropiate CC speed controller, I would also like to use Li-po batteries to get the best power for the lowest weight. I would like to hear what would be a good motor, battery, speed controller configuration for this. Also are there better receivers available that would reduce the weight. Thanks in advance for your help. Jon
Vagabond324 is offline Find More Posts by Vagabond324
Old Mar 11, 2005, 01:30 PM
Vanning is offline
Find More Posts by Vanning
WAA pilot #21
Vanning's Avatar
Princeton NJ
Joined Dec 2003
This one?
http://www.ilmailuliitto.fi/shop/hacskyarr.html
from the weight & the size, id say a GWS 350c-C motor & gearbox, a 0970 prop, CCpixie 20 speedo and 2cells ~1500mah lipo
Stick a Himax 2025-5200 brushless motor in the above gearbox and a CC pheonix25 speedo for a kick in the pants.
wait- it looks like a 9" prop is too big. Ok, then use the above motors direct drive.
http://www.gws.com.tw/english/produc...em/edp300h.htm
the 0630 or 0543 prop looks good.
Vanning is offline Find More Posts by Vanning
Old Mar 11, 2005, 01:41 PM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
I think I would go for the maximum power possible and probably forget a gear box as it may make the mounting a bit of a pain.
LIPOS certainly and if you get 3s LIPO of about 2200 capacity, then you can either for a permax or Graupner 7.2v 400 motor, or a permax 480 'long can 400'
Gunther prop or APC 5.5x4.5 shoudl sort it all out prop wise.
Frankly I think it will only need a 400.
If money no obvject a mega 16/15/5 or thereabouts would slot on and give as much power as the 480, but weight in like the 400.
Discussion TF Cessna 310 Electric conversion help needed skripo Giant Electric Planes 31 Jun 25, 2012 05:36 PM
Discussion Electric motor help needed!!!!! DeadByDawn72 Power Systems 9 Jan 31, 2007 04:50 PM
Alert 3D electric power - Help needed Thermaltake Power Systems 5 Dec 09, 2004 03:50 AM
Could it be my motor? Help needed.... kenny_dilger Electric Plane Talk 3 Dec 20, 2001 06:54 PM
gas to electric conversion help needed. mflann Electric Plane Talk 8 Sep 10, 2001 07:03 PM
