Old Mar 11, 2005, 08:50 AM
X-spec is offline
Find More Posts by X-spec
Joined May 2004
Re: Any Yellow Aircraft F-18 Twin owner here?
HI! Guys,
I 'm very much interested in turbine jet now and looking into Yellow Aircraft F-18 Twin. But now it seen to me I face a small problem, I did some search and find out Y/A F-18 got two version? One is Fiberglass and the other is in Epoxies or something like that? . F-18 owner what do you run under your fuselage? Some owner say as long is a 45Lbs it will fly well can I go with something lower then 45Lbs?
Is the Y/A F-18 door gear easy to install because I also herad them say that the door gear is the most problem on this kit. Is there anybody building it right now care to share your viwe and information to me please? before I purchase the kit. Some photo pictres with detail will be more better. at less I had some idea where should I start before this kit ship in.
X-Spec
X-spec is offline Find More Posts by X-spec
Old Mar 11, 2005, 09:19 AM
uncljoe is offline
Find More Posts by uncljoe
Col.Hooligan Air Force
uncljoe's Avatar
Phoenix,Arizona
Joined Jul 2001
Do a search on RCU ...There is a build thread there from last year
Semper Fi
joe
uncljoe is offline Find More Posts by uncljoe
Old Mar 11, 2005, 10:10 AM
Marty C. is offline
Find More Posts by Marty C.
An Aussie in Canada
Marty C.'s Avatar
Belleville, Ontario.
Joined Sep 2003
Hi X-Spec, I personally do not own one myself just yet, but Iam on the waiting list for the soon to be released ARF big Yellow F-18. The guy to ask all about the F-18 would be Yellow Aircraft rep Shaun Evens.....maybe he will chime in on this thread and answer some of your questions. Iam pretty sure this model will fly fine on turbines with less than 45lb thrust.... a lot would depend on obviously the finished AUW of the model as to which turbines would be options. As to epoxy or polyester glass work??? the early versions were indeed polyester but current kits are all epoxy composite construction as far as Iam aware....
If you do not like the idea of dealing with the gear doors ask Shaun about the soon to be released big ARF Yellow F-18 complete with fitted gear doors etc etc etc... I cant wait for that one
Cheers-
Marty C. is offline Find More Posts by Marty C.
Old Mar 12, 2005, 07:28 PM
X-spec is offline
Joined May 2004
Thank You UncleJoe & Mr Marty.C for the information I 'll check with Mr Shaun from Yellow Aircraft and look at RCU also. TKs!
X-Spec
Old Mar 12, 2005, 09:56 PM
SDCrashmaster is offline
Find More Posts by SDCrashmaster
Joined Feb 2005
You can e-mail Shaun @ skyhigh315@cox.net
He will have a website up soon that has some great images of some of the nicest YA twin F/A-18's out there.
I happen to be the one building the site as we speak.
Good luck...spectacular jet.
Paul
SDCrashmaster is offline Find More Posts by SDCrashmaster
Old Mar 13, 2005, 02:28 AM
Downwind3Zero is offline
Find More Posts by Downwind3Zero
It's like an addiction!
Downwind3Zero's Avatar
NY, Rochester
Joined Oct 2003
Here's a Yellow FA-18 I found, powered by a JetCat P120
Downwind3Zero is offline Find More Posts by Downwind3Zero
Old Mar 13, 2005, 03:26 AM
grbaker is offline
Find More Posts by grbaker
La Porte, Texas
Joined Sep 2004
Mine flew great on a P160. I did not build it. It is a very old twin DF model that has been converted to single turbine. It weighs 35 pounds dry. The previous owner flew it with a Ram 750 when he first converted it and then put a Ram 1000 in it.
grbaker is offline Find More Posts by grbaker
Old Mar 13, 2005, 05:20 AM
X-spec is offline
Joined May 2004
Wow! Nice picture on the F/A F-18 thanks! Downwind3Zero, and to Mr Paul spectacular information also on how to reach Mr Shaun Thank a lot too and also to grbaker Hmmmm.........install a P160 how much thrust on this Jetcat turbine? Was AMT Olympus HP( High Power ) too much for this plane? I was been told it needed at less 45Lbs thrust to powering it well?? .............
X-Spec. THANKS! Everybody.
Old Mar 14, 2005, 08:52 AM
X-spec is offline
Joined May 2004
HI! Downwind3Zero ,
Can you please show me your F-18 Twin spec? What 's the different between this two version? The Polyerter fiber glass & Epoxy gel composite any weight issue on it? How about the new ARF version anyone built already?
X-Spec.Thanks
Old Mar 16, 2005, 03:48 AM
NY, Rochester
Joined Oct 2003
X-Spec, sorry, the picture in my post belongs to a fellow RC'er, can't give you any other info that posted above.
Chris
Old Mar 16, 2005, 08:19 AM
X-spec is offline
Joined May 2004
Chris
That 's O.K. thanks.
X-spec
FS Yellow Aircraft F-18 rc jet flyer Aircraft - Fuel - Airplanes (FS/W) 0 Oct 23, 2004 02:50 PM
Yellow aircraft F-16 Ductedfan jet rtf just add RXTX littlepiston Aircraft - Fuel - Airplanes (FS/W) 1 Oct 03, 2004 02:20 AM
Yellow Aircraft F-4 RPM Fuel Jet Talk 16 May 11, 2004 03:33 PM
Cool Yellow Aircraft F-18 Twin EDF GregG Electric Ducted Fan Jet Talk 39 Jul 18, 2001 01:21 PM
Yellow AC F-4 twin KRose Electric Ducted Fan Jet Talk 10 Jun 26, 2001 08:47 PM
