Old Mar 10, 2005, 09:26 AM
Eventually...I will fly
Israel
Is this a good setup for a TM400 (and other GWS planes as well)
will it be verstile for other planes as well (gws warbirds,magpie)
Himax 2025-4200/Cobri 20 Gearbox, Red, 11T, 72T
Castle Creations Phoenix 25 brushless speed controller
Tanic 3s 2220 12C Lithium Polymer battery pack
props APC 12x6 (should i get the E or SF)?
Eran
eran_k is offline Find More Posts by eran_k
Old Mar 10, 2005, 02:37 PM
FAA Certificated
Joined Nov 2004
This setup will probably not turn the prop more than 7K RPM, so an SF prop is probably good on the TM 400. The Cobri gearbox is nice & has adjustable ratios - so that will be useful in other setups - as will the speed controller.
The 3s 2200 battery is pretty heavy - but you could always go to a 2-cell and lower the gearbox ratio. If you change to a 14T pinion you have 5.1:1 ratio and could swing a 12x4.7 prop on 2 cells with good thrust I bet (this is where MOTO-CALC comes in handy...)
Bottom line - this setup will probably be 10x the power you need to enjoy a TM 400, hang on :-)
stealth916 is offline Find More Posts by stealth916
Old Mar 11, 2005, 01:47 AM
kensp's Avatar
Darwin Australia
Joined May 2002
The 12x6 will give far too much thrust but it will not give enough speed to fly the TM 400 with safety. You will be hanging around the two times stall speed and this is not fast enough to fly with ailerons. A change to an APC 10x7 Slowfly wil raise the speed to 2 1/2 times stall speed which will be much better.
But the main problem is that the geabox ratio is 6.6:1 and this is to high to be of use for the faster GWS aeroplanes including the Warbirds. A gearbox ratio of between 4:1 and 5:1 would be much better.
Ken
kensp is offline Find More Posts by kensp
Is this a good setup for GWS mustang? Alex Shipp GWS (Grand Wing Servo) 3 Jul 24, 2004 03:15 AM
Good setup for a first time GWS flyer saitrix GWS (Grand Wing Servo) 0 Jan 19, 2004 10:02 AM
is this a good setup for newbie T-IFO / Slow Stick / T3D CAP pakman Parkflyers 1 Oct 09, 2003 02:30 AM
Is this a good setup for newbie newminimark Parkflyers 8 Sep 08, 2003 11:37 AM
good setup for GWS zero? astroflyer Parkflyers 0 Jun 30, 2002 07:45 PM
