i know there are a lot of conversion kits about to be released, but here's my take on it. my goal was to make a complete raptor frame that was both high performance, and cheap. that's what raptors are all about. people buy them because the parts are cheap, and they perform well. why take an affordable helicopter, and put a bunch of expensive carbon fiber all over it? my hope is that this conversion kit might be able to fill the demand for a reasonably priced 50 sized electric helicopter. i tried to keep the parts count and material cost as low as possible. this is not the final design, but it's close.
Features:
- Two piece G10 fiberglass frame. Cheap, ridgid, and light. G10 costs about 1/10th of what carbon fiber costs, and while not quite as stiff, has better impact resistance than carbon.
- Thrust bearings on top and bottom of main shaft. This is a requirement for any type of aerobatic flying, IMO. Without thrust bearings, the main shaft radial bearings deteriorate quickly under hard flying, robbing you of power, and costing you money to replace them.
- 120 degree CCPM. Keeps the heli light and parts count low. I'm using a logo 20 swashplate in the photos, but the kit would include a ring to convert the stock swash to 120 degree.
- Easy battery mounting straps. Couldn't be more convenient.
- Frames extend out past the batteries to protect them in a crash. Don't want to damage those expensive LiPos, right?
- Very ridgid servo mounting. Especially the rudder servo, which is supported on both ends by the frame.
- Machined aluminum bearing blocks, motor mount, and tail boom holders. The motor mount and bottom bearing block are one piece, which keeps everything ridgid and square.
- Motor is mounted high on the frames, which allows the batteries to also be mounted as high as possible. This keeps the center of mass closer to the head, which allows the heli to be more nimble.
- 7lbs, 9oz as pictured with the fiberglass canopy. 7lbs, 11oz with the stock plastic canopy. 5lbs, 6oz without batteries.
Equipment pictured:
- Head, tail, landing gear, shafts, main gear, pulleys all stock
- Motor: Actro 24-3 Heli
- ESC: Hacker 77-O Heli (using throttle curves)
- Rx: Futaba 9ch PCM
- Gyro: gy401 w/ 9253 servo
- 8s3p Thunder Power Gen2 Lites (obsolete)
- UBEC
- Mah 600mm carbon blades
- Mikado 3D paddles
performance is excellent with the actro 24-3 on 8s3p. it's actually better than the 24-4 on 11s2p. i think the 3 turn is just a better wind. it barely gets up to body temp after a hard flight. notice the stickers are still on it
. i'll get some video up soon. i also plan to try a "boxed" setup with a Neu 1515/2Y and 10s2p TP Gen2 Pro Lites. this should truly be the ultimate power system. the Box will fit on there perfectly, and the motor will point forward.
at this point, i'm not sure if i want to go through the trouble and expense of putting this kit into production. the raptor conversion market is already a bit saturated. that's why i included a poll with this post. what do you all think? would you buy it, considering all the options out there? i have no idea what the price will be, but i know the material costs will be almost negligible. my hope is that it will be somewhere between 100 and 150, but i am making no promises. thanks for your input.
high res photos are available in my rcgroups member gallery...
