Old Mar 08, 2005, 02:40 PM
bogas is offline
Find More Posts by bogas
Joined Feb 2005
Cool
castor oil or synthetic
Which fuel to use? I've read articles where some say castor oil will gum up the carb.
A newbie thats ready to run in a new engine. What fuel would you recommend?
bogas is offline Find More Posts by bogas
Old Mar 08, 2005, 04:06 PM
ivanc is offline
Find More Posts by ivanc
S.A.D. member
ivanc's Avatar
United States, TX, Round Rock
Joined Dec 2004
What's your engine? The manufacturers will usually recommend the type of fuel for their engines in the manual.
ivanc is offline Find More Posts by ivanc
Old Mar 08, 2005, 05:45 PM
mcflyboy is offline
Find More Posts by mcflyboy
mcflyboy's Avatar
Joined Jan 2005
Seconded
mcflyboy is offline Find More Posts by mcflyboy
Old Mar 08, 2005, 06:25 PM
clipclop is offline
Find More Posts by clipclop
QLD, Australia
Joined Sep 2003
As you are a newbie, I would recomend castor based fuel.
Reason ? well castor will protect your motor better against a lean mixture setting.
synthetics are equally as good ,--- provideing the temp of the motor is within normal limits , but dureing a lean run the temp will climb and synthetics become useless as they vapourise . it is this vapouriseation that allows synthetics to burn with the fuel and not leave the oily mess out of the exhaust that castor does.(only bad point)
A good article on oils can be read hear:- http://archive.dstc.edu.au/BDU/staff/ron/
click on FAQ in the list ,left , then scroll about 25% doun to the synthetic oil Q?
Verry informative based on "REAL" facts, to quote a few lines :- "In spite of all this, the synthetics are still excellent lubricants if you know their limitations and work within those limits. Used properly, engine life will be good with either product. Cooked on a lean run, castor oil will win every time"
Stewart
clipclop is offline Find More Posts by clipclop
Old Mar 09, 2005, 12:44 AM
bogas is offline
Joined Feb 2005
My engine is a O.S. 46 ax
LHS sold me castor based fuel,but after reading alot of info, just unsure which way to go.
Boy this is a tough sport to break into. Thanks for the replys.
Old Mar 09, 2005, 01:38 AM
bogas is offline
Joined Feb 2005
Hey Clipclop. I read that article from the site you steered me to.
Very informative. I'm sticking with the castor oil for now. Thanks alot buddy
I can sleep tonite. Thanks again !
Old Mar 09, 2005, 08:12 PM
smedsky is offline
Find More Posts by smedsky
Kirkland Wa.
Joined Mar 2005
For a bushed engine Castor is mandatoty. For a BB engine syn is fine but a little castor will help prevent some long term rust.
smedsky is offline Find More Posts by smedsky
Old Mar 10, 2005, 08:10 AM
GregG is offline
Find More Posts by GregG
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
Bogas and Smedsky, Welcome to RC Groups!
GregG is offline Find More Posts by GregG
Old Mar 12, 2005, 08:33 AM
FenceMagnet is offline
Find More Posts by FenceMagnet
Vintage Flyer
Treasure Island, FL
Joined Jan 2002
synthetic fuel with a few % castor added will go a Looooooong way to protecting your engines.... I recently picked up flying again after a 3 year absence.... my wife passed away then and flying was not on my mind for a long while.... well, I'm married again, and she talked me into resuming my hobby.... I had 4 or 5 planes hanging in my workroom, and they had been hung their the last time I went flying.... no preparation or after run oil or nothing.... after working them free with some wd40 and a hairdryer (can't seem to find that heat gun!!) I lubed them with some MarvelMystery and went flying..... not a hitch, they all run great and no noisey bearings or anything... I credit that sticky film of castor that remained in the engines for protecting them from time and corrosion....
FenceMagnet is offline Find More Posts by FenceMagnet
Old Mar 12, 2005, 09:32 AM
staggerwing is offline
Find More Posts by staggerwing
In NY's beautifull hills
staggerwing's Avatar
Binghamton Broome Cty, New York, United States
Joined Jun 2004
Yes to castor
Synthetics will leave a residue that induces moisture,a fact was proven yrs ago. Castor will get gummy ---but only after YEARS of sitting, but that film will protect your engine during & after running.
The same synthetic problem goes for gas engines------use a proven natural petroleum based oil for mixing IE Pennzoil For Aircooled Engines---proven from many years in the ultralight industry for max protection w/ low carbon buildup.
staggerwing is offline Find More Posts by staggerwing
Old Mar 13, 2005, 02:22 AM
50+AirYears is offline
Find More Posts by 50+AirYears
United States, SC, Irmo
Joined Jul 2004
Had a ball bearing engine sitting with a plane in an Oak tree for almost a month.. Water coming off an Oak tree during a rain gets very acidic. Since I always use a high percentage of Castor, after I got this plane and engine back, I poured out the very brown water, and found out that there was no corrrosion inside the engine, event though some other metal parts inside the plane that had gotten wet were pretty well corroded, including the landing gear wires and a couple servo connectors.
50+AirYears is offline Find More Posts by 50+AirYears
Old Mar 13, 2005, 07:39 AM
GregG is offline
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
Jimwhite, Welcome to RC Groups!
Old Mar 13, 2005, 04:03 PM
Vintage Flyer
Treasure Island, FL
Joined Jan 2002
thanks
Old Mar 14, 2005, 08:30 AM
ivanc is offline
S.A.D. member
ivanc's Avatar
Joined Dec 2004
I'm using the pink Omega fuels that contain both castor and synthetic oil and I'm happy with it as well as my engines are. I'm using it for all my engines - most of them are BB 2-stroke, one bushing 2-stroke and a OS FS70II 4-stroke.
Old Mar 16, 2005, 02:30 PM
Vette is offline
Find More Posts by Vette
Beam me up Scotty
Vette's Avatar
Central Ohio
Joined Dec 2002
I too have always used Morgan's Pink Omega, it is the best of both worlds IMO.
Vette is offline Find More Posts by Vette
Discussion Why have castor oil in your fuel opposed to synthetic oil? Sir-Ipswich Car Talk 1 Aug 09, 2007 06:48 AM
Castor or synthetic oil? W'rkncacnter Engines 10 Aug 18, 2004 04:25 AM
Removing Castor Oil from Wood? Brill 1 Fuel Plane Talk 12 Jan 27, 2004 03:04 PM
GWS 300C "B", Oil it or not? KeithLuneau Parkflyers 4 Jul 27, 2002 08:55 AM
