Old Mar 08, 2005, 02:33 AM
ivo is offline
ivo
Find More Posts by ivo
ivo
Slovakia
Joined Mar 2005
Piper PA-8 Skycycle - no documentation?
Hi everybody! First I have to say my English is "poor" so be patient... Once I have read on this discussion something about Piper PA/8 Skycycle. To be honest, I love Piper' s airplanes and this one is realy beautiful. These were the reasons, why did I decide to make it. That was in the end of last summer. And because I didn' t want a small model, I decided to make it in the scale 1:3 (not exactly), that meens the wingspan around 2m, exactly 2.2m. Now I've got ready rudder, elevator and almost fuselage which is made of laminate (sandwich polystyrene/fiber glass). In the article I've read here, there was a problem with passage between fuselage and wing. I've solved this problem with little construction between fuselage and a first rib. This construction should only help to keep the geometry of my model. And what was next? Well, then I bught two bottles of assembly foam and fill whole place between the first rib and fuselage. After cca 2 days you can cut and grind it with emery. It's great and easy to do!
But, now I've got another problem- how did the landing gear work? And what about the engine? I did not found any useful pictures or something like this. Somebody help me please! It would be ideal to know somebody who has this machine in full size and who could make hundreds of photos...
ivo is offline Find More Posts by ivo
Old Apr 05, 2005, 10:54 PM
gearup is offline
Find More Posts by gearup
Joined Sep 2003
the landing gear was similar to the chipmonk and Zlin ( oleo, fixed, and fwd of cg bolted to main spar) I'll try and get some pictures posted for you
gearup is offline Find More Posts by gearup
Old Apr 06, 2005, 12:18 PM
max z is offline
Find More Posts by max z
max z's Avatar
The Netherlands, ZH, Boskoop
Joined Mar 2001
Ivo, you probably have these pictures that I found on the net already, but I'll post them anyway. Great choice, I like the little plane. I read that the fuselage was made up from a jettisonable fuel tank that fighters used during WW2 to extend their range.
Max.
max z is offline Find More Posts by max z
Old Apr 14, 2005, 05:37 PM
flicka5 is offline
Find More Posts by flicka5
W. NY
Joined Jan 2002
plans
Model RC plans are available for this design in the states.
flicka5 is offline Find More Posts by flicka5
Old Aug 31, 2007, 06:21 PM
megawatt is offline
Find More Posts by megawatt
I'm Charged!
megawatt's Avatar
The end of the Oregon trail
Joined Jan 2001
Hello.Wow,old thread.Did you ever finish this model?
I am building 1/4 scale version of Skycycle, and am also looking for more documentation.Since there was only one of these airplanes ever built(excluding replicas) finding much in the way of photo's is tough.The prototype was destroyed in a hanger fire.
You might purchase a set of the Vintage R/C plans.(1/4 scale)They show a lot of detail.Also try EAA here in the states.They reportedly have a bit of documentation on this aircraft.
Jeff
megawatt is offline Find More Posts by megawatt
Old Aug 31, 2007, 06:24 PM
megawatt is offline
I'm Charged!
megawatt's Avatar
Joined Jan 2001
Vintage R/C plans: http://www.vintagercplans.com/main.htm
EAA(experimental aircraft assc): http://www.eaa.org/
Old Aug 31, 2007, 06:31 PM
megawatt is offline
I'm Charged!
megawatt's Avatar
Joined Jan 2001
These guy's might be able to help also: http://www.sky-tek.com/nx47y.html
Old Jul 17, 2009, 04:12 PM
pat41 is offline
Find More Posts by pat41
Joined Jul 2009
Old Skycycle Kit
Capitol Model Aircraft Co., of Brooklyn, NY, put out a balsa kit of the Skycycle. It was a control line model with a 30 inch wingspan. I don't know when the kit was produced, but the outline of the parts was printed on balsa sheets and you had to cut out the pieces yourself.
pat41 is offline Find More Posts by pat41
Old Jul 29, 2009, 08:13 PM
coosbaylumber is offline
Find More Posts by coosbaylumber
Joined Jul 2005
As I rememebr, there was a late 1950's edition of Air Progress that had some three views and something else on the Skycycle. They mentioned it was sort of One-off, and built from parts of another A/C.
As to Pat...
The Capitol line went to Sou. Calif. and then to Missouri now. Is advertised in M.A. every so often.
Wm.
coosbaylumber is offline Find More Posts by coosbaylumber
Old Jul 30, 2009, 08:50 AM
jjscott is offline
Find More Posts by jjscott
United States, WI, Elm Grove
Joined Apr 2007
Here is my dad's Skycycle u control, built, I suppose, from the Capitol kit. Probably taken in 1946-49. Powered by a Viking twin.
Jim
jjscott is offline Find More Posts by jjscott
Old Sep 19, 2015, 09:34 PM
duradad is offline
Find More Posts by duradad
United States, CT, Brookfield
Joined Sep 2010
1/3 scale Piper Skycycle Sky Cycle
I just acquired a foam core wing with fiberglass fuse of the PA-8 . Looking for plans and manufacturer of this model.
duradad is offline Find More Posts by duradad
Old Sep 20, 2015, 01:32 AM
GeorgeG97322 is offline
Find More Posts by GeorgeG97322
Power Upward
GeorgeG97322's Avatar
United States, OR, Albany
Joined Jun 2007
Wasn't the original pa-8 built from a drop tank of a fighter aircraft, corsir I believe. And due to the size of the fuselage and canopy it cause control problems for the rudder?
George
My dad built the capital model kit of it too. He put an O&R 23 in his.
GeorgeG97322 is offline Find More Posts by GeorgeG97322
Old Sep 20, 2015, 03:14 AM
mintie is offline
Find More Posts by mintie
mintie's Avatar
Kaiapoi , New Zealand
Joined Jun 2007
Mr google is your friend
https://en.wikipedia.org/wiki/Piper_PA-8 and there is plenty more
https://en.wikipedia.org/wiki/Carlson_Skycycle
This is mine I built from a peanut scale drawing.
36 in w/s
Made of foam,c/f depron and paper
4 HXT 900 servos and 3s 1300 bat.
Now on floats...flys really well
mintie is offline Find More Posts by mintie
Old Jan 26, 2016, 10:23 PM
duradad is offline
Joined Sep 2010
1/3 scale Skycycle
Here is my recently completed 80 inch PA8 Skycycle.
Old Jan 27, 2016, 02:19 PM
packardpursuit is online now
Find More Posts by packardpursuit
Joined Jan 2009
Piper Skycycle documentation.
This 1946 scale drawing, by William Wylam, appears here:
http://www.outerzone.co.uk/plan_details.asp?ID=695
as part of a CL model plan.
Some more photos along with scale drawings by James Triggs, appear here:
http://www.fiddlersgreen.net/models/...-Skycycle.html
Note enlarged rudder in photos! Trigg's drawing appears to be based entirely on Wylam's earlier effort.
packardpursuit is online now Find More Posts by packardpursuit
Question Piper Pa-8 Skycycle megawatt Scale Kit/Scratch Built 15 Jan 29, 2016 05:49 AM
MA Mar 86 / Piper PA-8 Skycycle Question crashsiegel Electric Plane Talk 0 Nov 15, 2003 05:27 PM
Graupner Speed 500 BB Race 8.4v No.6303 - availability? Phil.Taylor Power Systems 4 Jul 02, 2003 04:03 AM
Piper PA-11 Dereck Scale Kit/Scratch Built 16 Jan 09, 2003 10:43 AM
