Old Mar 24, 2002, 02:31 PM
Michael in Toronto is offline
Find More Posts by Michael in Toronto
E-flyer since 1981
Michael in Toronto's Avatar
Joined Oct 2000
EDF50 scratch built foam Jet flies
I purchased what I think was the first EDF50 available in the Greater Toronto Area. I built the model below from the inner-foam layer of a piece of foam core board and flew it today for the first time. This is my own design, built from experienced guesses for sizes and shape.
The model flies on 6 x 110mah batteries for about 2 minutes. It flies slowly enough that I plan to try it indoors. I flew it first, and then my son. The first flights were perfect (no crashes, easily controlled flight and nice landings) despite wind gusts blowing it around.
Total weight, with battery pack is 161.5 grams (approx. 5.7 ounces).
Michael in Toronto is offline Find More Posts by Michael in Toronto
Old Mar 24, 2002, 02:44 PM
steve neill
steve neill
Guest
n/a Posts
Very nice! Glad to hear it flew well. It's hard to beat a delta for stability.
Try 7 cells next time and compare. I've been using 7 110's on all My EDF 50 models.
Great job!
Steve
Old Mar 24, 2002, 03:06 PM
GoEFlight is offline
Find More Posts by GoEFlight
AeroMicro
GoEFlight's Avatar
Santa Clara, CA
Joined Sep 2001
Hello Michael:
Sweet and Elegant.
GoEFlight is offline Find More Posts by GoEFlight
Old Mar 24, 2002, 04:32 PM
Mikey-flies is offline
Find More Posts by Mikey-flies
Alberta, Canada
Joined Sep 2001
Great looking little plane! We should get a plans site up for edf-50 planes. Did you roll the duct for the fan?
Mikey-flies is offline Find More Posts by Mikey-flies
Old Mar 24, 2002, 05:16 PM
E-flyer since 1981
Joined Oct 2000
I cut the duct out of the same foam, in a long rectangular shape. I then held it under hot pouring water, and slowly and gently rolled it up tightly. I taped it tightly with masking tape and let it dry and cool down overnight. This morning I carefully cut it to fit the fan unit - I finished building it this morning, and flew it at noon.
Old Mar 24, 2002, 05:43 PM
russ6421 is offline
Find More Posts by russ6421
russ6421's Avatar
ny
Joined Dec 2000
I would say give it a toss over the lake and I would catch it but you have to get your flight time up just a bit more.Very nice I have a couple of the EDF-50 I guess I will have to get busy
russ6421 is offline Find More Posts by russ6421
Old Mar 25, 2002, 01:09 PM
dorysch1 is offline
Find More Posts by dorysch1
Electriaddict
dorysch1's Avatar
Melville Saskatchewan Canada
Joined Mar 2001
Very nice Michael that's a cool little plane!
dorysch1 is offline Find More Posts by dorysch1
Old Mar 26, 2002, 03:33 PM
Demon-Leather is offline
Find More Posts by Demon-Leather
"Experienced-Crasher"
Demon-Leather's Avatar
Rex, NC "Extreme Boonies"
Joined Jan 2002
NICE!!
Looks Very,Very,Nice in the Air! My hat's off to You Mike! Those Canadians! ehhh?!! Bob
Demon-Leather is offline Find More Posts by Demon-Leather
Old Mar 26, 2002, 06:17 PM
Robbie d is offline
Find More Posts by Robbie d
Crazy Cessna Owner
Robbie d's Avatar
Australia, SA, Windsor Gardens
Joined May 2001
That looks sweet, the last plane I saw in that configuration was powered by a pulse-jet. My hat off to the inventor of foam, for bringing us so much fun.
Robbie d is offline Find More Posts by Robbie d
Old Apr 10, 2002, 09:54 PM
Rampager is offline
Find More Posts by Rampager
Toronto, Canada
Joined Apr 2002
Howdy neighbor!
I just found this forum and am amazed at how far the hobby has come in the short while I've been "away" . I pulled out the old RC gear tonight and got a few things working, the 4 channel isn't cooperating though
I absolutly have to build a DF and its great to see they can be scratch built and designed succesfully. I just may need some more details on that setup you have!
I have a Novak M5 ESC, its a tad heavy but will this be acceptable for my first few df models? Where did you get your fan?
Thanks in advance
Cheers,
James
Rampager is offline Find More Posts by Rampager
Old Apr 10, 2002, 10:56 PM
Admiral_Red is offline
Find More Posts by Admiral_Red
Vice President at MultiGP
Admiral_Red's Avatar
San Antonio, Texas
Joined Oct 2001
Rampager: Buy a cheap 5amp esc, they are cheap, and light enough for electric flight. Every gram counts! The Novak is WAY too heavy for edf-50's. Might work in a bigger jet though!
Michael: Great looking bird! Awesome job!
Admiral_Red is offline Find More Posts by Admiral_Red
Scratch built...Foam Cub romans1015 Foamies (Kits) 12 Feb 20, 2010 05:56 PM
Scratch Built Foam Planes romans1015 Foamies (Kits) 5 Oct 20, 2002 04:40 PM
First Scratch Built Foam ? BobFlyer Foamies (Kits) 3 Oct 02, 2002 04:22 PM
Scratch-Built Foam Mooney zagisrule! Parkflyers 33 Sep 16, 2002 12:07 AM
Scratch built Foam flying wing WTXHog Foamies (Kits) 4 Sep 30, 2001 11:04 PM
