According to hacker's advertising...
"This motor features Oversize bearings, Curved Neo-magnets, and High efficiency stator design. These motors produce the most power at lower current consumption than other popular Outrunner designs!" It seems that I've also read somewhere that they're Kv's are the ones "considered" to be wrong becuase of the higher efficiency. Again, I'm just going off what I've read in ads and websites. |
Not guessing --
I am flying -- using the 11x7 GWS HD on the 20/20L AND 20/22L , w/ 1320 yellow stripe TB 3 cells. 12.5 oz models AUW I never pull more than 17 amps -due to small connectors -but there is NO -None NYET, heating problem in batt/controller or motor. If you want to see really spectacular performance - try these -they run smoother than the APC and pull like crazy. |
Frank, i would think that either motor would do you well, if it is out right speed your looking for consider a smaller higher pitched prop like a 8x6 or 9x6.
As a side note I have tested the 20L on 2s pack of 1320's with 12x3.8 prop and it drew 13-14A for roughly 110watts woould like to see what a 13X4 3d prop would do, i need to get a tach. HAppy Phil. don't know any of what you ask, may give Josh a call to find out if he knows Killer |
Joined Dec 2004
well men here goes.
i have mounted the 22L that i recieved in a fancy foam 300L with a apc sf 10-4.7 prop. a tp 2100 lipro . cc pheonix 25 controler. hi tec 6 ch radio . hitec s55 servos. the plane weighs about 16.5 oz. does any body have any idea as to how good opr bad this will work? where can i get a A20 20L? i tried two hobby shops and ended up with a 22Lone said he had some motors coming in but did not know when or if there would be a 22L in the ones that are coming. where and how do i get one or two? do you think there might be some at the seff meet in andersonville ga this month? this is only about a three hour drive from LA to there.always a dollar short and a day late. please somebody find me one. thx cavier. |
| Thread Tools | |
| Sold NEW Hacker A20-20L and X-20 ESC | The Don | Aircraft - Electric - Power Systems (FS/W) | 2 | Jun 28, 2007 08:27 AM |
| Yippee! New Hacker 20-20L WOW! Part. 2 .......(and some other A20s?) | Aio_1 | Power Systems | 410 | Dec 03, 2005 09:40 AM |
| Hacker 20-20L knock???? | hoppy | Power Systems | 10 | Jul 18, 2005 08:43 AM |
| Magnets on Hacker 20-20L | psk560 | Power Systems | 9 | Mar 21, 2005 07:21 PM |
| Axi 2808-24 vs Hacker 20-20L with Groove | KillerAir | Power Systems | 2 | Mar 11, 2005 08:34 PM |
