Old Mar 16, 2005, 06:36 PM
gpw is online now
gpw
Find More Posts by gpw
gpw
“There’s no place like Foam”
gpw's Avatar
United States, LA, New Orleans
Joined Jul 2002
Dornier DOX...???
But I still vote for the most beautiful prop plane of all the "Constellation"... that's 4 motors Gene...
gpw is online now Find More Posts by gpw
Old Mar 16, 2005, 07:08 PM
FoamingInMI is offline
Find More Posts by FoamingInMI
Oops get the hot glue gun
FoamingInMI's Avatar
Lansing, Michigan, USA
Joined Sep 2004
The Connie is a beauty all right, but one of Hughes' other designs is my favorite, the world speed record H1 plane. Check out those sleek lines, not bad for a 1930's design.
Look at that bottom profile, I've been tempted to make it into a pusher canard, of course I'd have to move the rudder up to the "front".
Gary D
FoamingInMI is offline Find More Posts by FoamingInMI
Old Mar 17, 2005, 07:54 AM
sheba is offline
Find More Posts by sheba
Vienna Wv
Joined Sep 2001
Gene... You did a great job on the C47. I am building one now. I don't get on here much but follow the builds every day. I would like you or someone to consider a C 130 or 160 FF build. I think it would generate a lot of interest. Please!!! Joe
sheba is offline Find More Posts by sheba
Old Mar 17, 2005, 07:55 AM
gpw is online now
gpw
gpw
gpw's Avatar
Joined Jul 2002
Foam , it is a Beauty !!!!! Canard out of a H-1 , huh???? Keep talking like that and we'll have to invite you into "the Order".....hahahahah
C-47...now comes the tough part ... cannibalizing a radio from something else ... Never enough radios!!!!
C130??? Hmmm???
Old Mar 17, 2005, 12:03 PM
Gene Bond is offline
Find More Posts by Gene Bond
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
Just gotta find the right power system. I'll be darned if I'm going to put 4 x $10 worth of brushed motors on one! Maybe if I can find a lower Kv 250 or 260 motor laying around in surplus somewhere I hate to use 4 280's, and 4 IPS's is out of the question... I'm too cheap!
One thing at a time. I'm scheming away on the Sorta Stealth Sport right now... It is a bomber, after all
Then maybe a C-130
Gene Bond is offline Find More Posts by Gene Bond
Old Mar 17, 2005, 02:15 PM
sheba is offline
Vienna Wv
Joined Sep 2001
Gene Maybe just a set of plans for the C130. I'm sure somebody will build it. Joe
Old Mar 17, 2005, 03:05 PM
Joined Sep 2004
Dropping a tank out of the back end, talk about your major trim changes! Wonder how many clicks that took...
Gary D.
Old Mar 20, 2005, 09:26 AM
gpw is online now
gpw
gpw
gpw's Avatar
Joined Jul 2002
How I spent my Saturday morning ....
The weather was clear and calm ( for a change ) , I got to the field at daybreak (06:15).. there was a light ground fog over the grass .... Got the C-47/DC-3 ready , oiled the motors , checked the surfaces and props for proper movements /operation ... the motors didn't sound quite as HOT as the j250's we've been using , but being a believer , we tossed it ..... Wow!!! it has more power / speed than I realized ... very fast non scale flying ,but FUN .... while fumbling around , I accidentally touched that stick on the left and somehow reduced the power ...Boy does this thing fly slow and look exactly like a "Goonie " in the air ... Way Way COOL!!!! and very relaxing !!! I'm glad I chose to follow the REM controls suggested by Genebond, simple and work great ... even managed a few loops (more non -scale )... This is a FUN plane , and would probaby be a really good introduction to twins if built as presented ...Thanks Gene, another "WINNER"!!!!!!!!!!!
Old Mar 20, 2005, 09:43 AM
sheba is offline
Vienna Wv
Joined Sep 2001
C130 - C160
Just build a C130 - C160 either 4 motors or 2 motors builders choice. Joe
Old Mar 20, 2005, 06:12 PM
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
Glad it worked, Glen. Pretty surprising how little power it takes to fly, huh? and quiet, too!
Touch and goes are great fun as well.
sheba: I haven't looked at the C-160, Is it the european version of the C-130 with 2 motors? Seems like I saw someone mention it.
C-130 study: I found a suitable surplus motor How's about 4 x $1.50 for the power plant... Oh, yea, props, too Looks like 3x2 props. Darn, I was hoping for 4 or 5", but I'm going to look at something else here, before I pin it down and start drawing. I think Ideally, I'd like to see 6-8a total current, on 2s. I like that power range as far as batteries go. It would probably work fine with some old Li-Ions in parallel Heck, with as much wing as these have, the weight won't make that much difference. The only real concern will be wing bracing. That's more a problem due to the 4% chamber I love...
Old Mar 20, 2005, 07:42 PM
sheba is offline
Vienna Wv
Joined Sep 2001
Search for a C160 Transall I found some great pictures of a German air Force C160 flying at an airshow. Joe
Old Mar 20, 2005, 07:56 PM
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
Ahhh... Yea, it'd work. But a quad would be cooler
Old Mar 21, 2005, 08:04 AM
gpw is online now
gpw
gpw
gpw's Avatar
Joined Jul 2002
What about the old "flying Boxcar" ????
Old Mar 21, 2005, 09:24 AM
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
This one?
Fairchild C-119 Flying Boxcar
Old Mar 22, 2005, 07:25 AM
pacro is offline
Find More Posts by pacro
TOPDOG
Taiwan
Joined Oct 2003
mmmmmmm maybe i'll try this dc3 on x2 2025-4200s
pacro is offline Find More Posts by pacro
DC-3/C-47 kits? CAWayne Electric Plane Talk 126 Feb 10, 2012 10:38 AM
Sold DC-3 / C-47 sloper pdawg Aircraft - Sailplanes (FS/W) 2 Oct 06, 2005 08:52 PM
Cool GB Brushless for the GWS DC-3/C-47? ticketec Power Systems 0 Oct 21, 2004 01:52 AM
DC-3 / C-47 very scale prop-hub set up Splash Parkflyers 47 Aug 10, 2004 08:41 AM
