Old Mar 06, 2005, 10:18 PM
Gene Bond is offline
Find More Posts by Gene Bond
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
FAQ
Time for a Twin - Blu DC-3 / C-47 project
I've had this one sitting on the back burner for a while, and finally got the bug. After checking on a few other threads, and discussing size and such, I made the decision to go forward.
Here's the plan at this point:
Twin EDP-100 (280DD w/ 5x3 prop)
R/E, optional A/E or A/E/R
48"ws
35" length
~340sqin
Hope to be under 12oz
so... 5.1oz/sqin should float well
To answer a few questions right off the bat:
Why 280's, I thought you were a big J-250 fan?
- I have a bunch of 280's left over from building J-250 geared setups, so they are free
Can I use IPS-A drives?
- Sure, a pair of IPS-A's with 8x4.3 props on 3s would be great!
Can I use CD-Rom Motors?
- Yes, but it sure gets expensive with 2 esc's. Maybe YOU can make 2 motors start together, I can't.
Can I use J-250's?
- Sure, use 4x2.5 props, and 10-12A batteries. It'll be prenty powerful!
Why 2 different aileron cutouts?
- Take your pick, scale or simple.
Box or rolled fuse, instead of crutch-style?
- Hey, I'm lazy! I don't know if this thing'll fly! I just don't have the time or energy right now...
Anyway, here's some progress and preliminary plans:
Edit: Added the C-121 plans
Gene Bond is offline Find More Posts by Gene Bond
Old Mar 07, 2005, 01:08 AM
jimkirley is offline
Find More Posts by jimkirley
Joined Jul 2004
How does one keep up, your killing me!
jimkirley is offline Find More Posts by jimkirley
Old Mar 07, 2005, 06:20 AM
lift off is offline
Find More Posts by lift off
HELL no you cant fly it!
lift off's Avatar
Joined May 2004
GENE UR A BEAST! Keep it up dude!
lift off is offline Find More Posts by lift off
Old Mar 07, 2005, 07:24 AM
gpw is offline
gpw
Find More Posts by gpw
gpw
“There’s no place like Foam”
gpw's Avatar
United States, LA, New Orleans
Joined Jul 2002
Looks like great FUN ... I just gotta' build this one ..proportions are perfect ... Thanks once again Gene!!!!!!!!!
gpw is offline Find More Posts by gpw
Old Mar 07, 2005, 02:10 PM
Joined Jul 2004
Gene, Thanks alot for the plan, btw, the full picture of the plan is a nice bonus, helps with layout and taping!
Old Mar 07, 2005, 02:40 PM
snolord1 is offline
Find More Posts by snolord1
Krued Up
snolord1's Avatar
United States, MA, Chicopee
Joined Jul 2004
i'm with this 1 too gene
snolord1 is offline Find More Posts by snolord1
Old Mar 12, 2005, 09:52 AM
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
Finished up last night....
RTF weight w/ 2s1200 13.3oz... not bad!
Paint takes 2-3 times as long as the rest of the build!
Will fly tonight indoors
Old Mar 12, 2005, 09:53 AM
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
BTW, here's a simple way to do windows!
Old Mar 12, 2005, 10:20 AM
FoamingInMI is offline
Find More Posts by FoamingInMI
Oops get the hot glue gun
FoamingInMI's Avatar
Lansing, Michigan, USA
Joined Sep 2004
Good Looking C47 Gene!
Very nice Gene, this one is destined to become another Blucor classic.
Some planes you just gotta paint, I know cuz I'm painting one now. It cried out for RED!
Good job & have fun flying her.
Gary D.
FoamingInMI is offline Find More Posts by FoamingInMI
Old Mar 12, 2005, 12:27 PM
DiabloKid is online now
Find More Posts by DiabloKid
CAP 232-aholic
DiabloKid's Avatar
Centreville, VA
Joined Jan 2003
Bravo Gene! Nice work there. Looks like winner. Is that 3mm depron?
DiabloKid is online now Find More Posts by DiabloKid
Old Mar 12, 2005, 01:53 PM
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
It's BluCor Fan Fold...
Old Mar 12, 2005, 03:45 PM
BrMiHi08 is offline
Find More Posts by BrMiHi08
No time to fly
BrMiHi08's Avatar
USA, MO, Independence
Joined Nov 2003
It's looking for a cool plane, I might go with the ips-a motor on it, not sure yet. I am too soar after paintball to do anything anyway.
BTW: What are you using for landing gear?
BrMiHi08 is offline Find More Posts by BrMiHi08
Old Mar 12, 2005, 04:12 PM
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
Ooops, I guess I did forget to explain the landing gear...
I used 2 pieces of LitePly, 1/8x2x3", and some .078" wire. I drilled a hole for a 'torque anchor', and lashed the wire down with some floss. I'll add it to the drawings some time. I hot glued the ply plates to the bottom of the wing, and wrapped soeme tape around the LE for good measure.
Old Mar 12, 2005, 06:49 PM
gpw is offline
gpw
gpw
gpw's Avatar
Joined Jul 2002
That's really COOL!!!!!
Old Mar 12, 2005, 07:42 PM
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
Oh yea...
Notice the blue masking tape on the motors? That's so I can hot glue them in place. I don't know if you've tried, but hot glue doesn't stick to metal parts worth a darn. It must have to heat up the surfface of the part it's sticking to to be effective, and the metal must 'sink' the heat away too quick... anyway, it doesn't stick. So, the tape gives some surface for the glue. Otherwise, use epoxy...
DC-3/C-47 kits? CAWayne Electric Plane Talk 126 Feb 10, 2012 10:38 AM
Sold DC-3 / C-47 sloper pdawg Aircraft - Sailplanes (FS/W) 2 Oct 06, 2005 08:52 PM
Cool GB Brushless for the GWS DC-3/C-47? ticketec Power Systems 0 Oct 21, 2004 01:52 AM
DC-3 / C-47 very scale prop-hub set up Splash Parkflyers 47 Aug 10, 2004 08:41 AM
