Old Mar 05, 2005, 08:36 AM
SkDmRkLcY is offline
Find More Posts by SkDmRkLcY
Duck and Cover
SkDmRkLcY's Avatar
Ohio
Joined Nov 2004
Easy Star Question on Build
I am building my new easy star and I was wondering if it will work ok if I use stripping tape to attache the two fuse halfs togther rather than glue incase I want to take it apart after the first couple of flights, and then glue it. I have looked in the Giant collection of threads but just get lost in it.
SkDmRkLcY is offline Find More Posts by SkDmRkLcY
Old Mar 05, 2005, 09:23 AM
mrX is offline
mrX
Find More Posts by mrX
mrX
mrX's Avatar
Columbus, Ohio
Joined Jan 2005
Most people I think are using double-sided poster tape, and then reinforcing with a strap/duct type tape along the nose seam and bottom edge.
mrX is offline Find More Posts by mrX
Old Mar 05, 2005, 10:09 AM
aeropal is offline
Find More Posts by aeropal
aeropal's Avatar
Joined Jan 2003
Related Thread
aeropal is offline Find More Posts by aeropal
Old Mar 05, 2005, 04:45 PM
Duck and Cover
SkDmRkLcY's Avatar
Ohio
Joined Nov 2004
Thanks, I used that method and we will see how it goes.
I have another Question are the rudder and elevator supposed to be all one piece, or am I supposed the top or edges so it hinges with the rest of the foam. It says nothing in the manual about this.
Old Mar 06, 2005, 07:07 AM
Joe_Atlanta is offline
Find More Posts by Joe_Atlanta
this space available
Joe_Atlanta's Avatar
Atlanta, GA
Joined Dec 2004
Not sure what you are asking, can you rephrase the question?
Joe
Joe_Atlanta is offline Find More Posts by Joe_Atlanta
Old Mar 06, 2005, 09:57 AM
Duck and Cover
SkDmRkLcY's Avatar
Ohio
Joined Nov 2004
I found what I was looking for I think. The Rudder control surface was not cut out at all, the rudder and control surface were all one piece of foam no cuts at all. Am I supposed to cut out the top notch to let the rest of the control surface move back and forth. Same is true for the elevator.
Old Mar 06, 2005, 02:47 PM
Atlanta, GA
Joined Dec 2004
Correct. Cut top of rudder, left and right side of elevator, leave the other compressed foam areas as hinges. Work the control surfaces by hand 20-30 times to loosen them up.
More tips are at: Detract's Easy Star fan page. There's a lot of good info collected from the ongoing EZ Star thread (in the Foamies section) on Detract's page. You should also check out Tyber's page, which has an annotated build sequence: http://www.tyber.com/easystar/
Joe
Multiplex Easy Star Built on time! Speed E Freak Foamies (Kits) 10 Sep 01, 2009 11:30 AM
Help! Newbie with an Easy Star question... -- Answered Omelets Electric Plane Talk 7 Jan 14, 2007 10:17 AM
Discussion Quick Easy Star Question charwoods3 Beginner Training Area (Aircraft-Electric) 2 May 01, 2006 08:50 PM
Question Question? How about an Easy Star wing on a Slow Stick? Sparrowhawk Aerial Photography 4 Nov 07, 2005 04:53 PM
Multiplex Easy Star question koonyue Electric Sailplanes 11 Jun 15, 2005 11:23 AM
