Go Back   RC Groups > Aircraft - Electric - Airplanes > Foamies (Kits)
Old Mar 04, 2005, 08:21 AM   #1
ldammann's Avatar
Printed P51 Build
Print is from t1mux. Originaly from wcflyer.
32" WS cambered, CF tubes, 5mm Sturdyboard.
First step, rough cut the print and foam. Soak and strip the Sturdyboard.
  • Name: IM000099.JPG
  • Name: 30405TimsP51-med.jpg
ldammann is offline Find More Posts by ldammann   Reply With Quote
Old Mar 04, 2005, 08:24 AM   #2
ldammann's Avatar
Locate where the wing CF will go. I used 30% cord. Use router or cut a v for the tube.
  • Name: IM000097.JPG
Old Mar 04, 2005, 08:26 AM   #3
ldammann's Avatar
Glue in the CF tube. I used a .125 dia. tube and CA.
  • Name: IM000100.JPG
Old Mar 04, 2005, 08:31 AM   #4
ldammann's Avatar
I cut out the wing slot on one of the fuse prints and made a template for the wing camber.
  • Name: IM000101.JPG
Old Mar 04, 2005, 08:35 AM   #5
ldammann's Avatar
Put a 1" cardboard tube under the wing at the CF tube. Weight down the leading and trailing edges to match the template.
  • Name: IM000102.JPG
Old Mar 04, 2005, 08:36 AM   #6
ldammann's Avatar
Temper the foam with a hair dryer of heat gun.
  • Name: IM000103.JPG
Old Mar 04, 2005, 08:40 AM   #7
ldammann's Avatar
Flip the wing, weight it to hold the camber, and temper the underside.
  • Name: IM000104.JPG
Old Mar 04, 2005, 08:43 AM   #8
ldammann's Avatar
Glue the print to the top side of the wing. Trim to print. I used 3M spray.
  • Name: IM000106.JPG
  • Name: IM000107.JPG
  • Name: IM000112.JPG
Old Mar 04, 2005, 08:44 AM   #9
ldammann's Avatar
Glue the print to the underside of the wing.
  • Name: IM000108.JPG
Old Mar 04, 2005, 08:49 AM   #10
ldammann's Avatar
Cut out the ailerons. I followed the panel lines for the flaps on the print. Bevel the ailerons and the wing. Tape them on. I used Scotch brand.
  • Name: IM000109.JPG
  • Name: IM000110.JPG
Old Mar 04, 2005, 08:51 AM   #11
ldammann's Avatar
Glue on side of the print to the foam and trim.
  • Name: IM000113.JPG
  • Name: IM000114.JPG
Old Mar 04, 2005, 08:54 AM   #12
ldammann's Avatar
Place the CF tube with motor stick on the fuse for position. Poke a pin thru each end to mark the other side.
  • Name: IM000115.JPG
Old Mar 04, 2005, 08:57 AM   #13
ldammann's Avatar
Place the tube and mount on the back side lined up with the pin hole. Mark the location. Route out the foam for the tube same as you did the wing.
  • Name: IM000117.JPG
Old Mar 04, 2005, 08:59 AM   #14
ldammann's Avatar
Thats it for tonight. I gotta get to bed. Will finish up tomorrow. Total time so far (less soaking the Sturdyboard) 1 1/2 hours.
Old Mar 04, 2005, 09:53 AM   #15
Mocking Birds
t1mux's Avatar
Lee, That looks great so far!
t1mux is offline Find More Posts by t1mux   Reply With Quote
Discussion Laser Art P51 Build Thread. taekwondo Electric Plane Talk 25 Jan 14, 2006 07:15 PM
L.E.G P51 Build Thread? colin wavell Slope 7 Dec 29, 2004 09:30 AM
My CNC cut P51 build Summer Foamies (Kits) 49 Oct 19, 2003 10:24 PM
Need help with P51 Build. mrebman Parkflyers 4 Feb 23, 2003 10:45 AM
GWS P51 Build Questions.... flipnidaho Parkflyers 3 Dec 16, 2002 06:57 PM
Congratulations SimpleM!
