Old Mar 04, 2005, 08:24 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Data
CBA Discharge TEST
Post #27 contains a bit of history and a link to the original first 3 post of the BGV.
http://www.rcgroups.com/forums/showp...9&postcount=27
Please Links to Battery Test only. One post per user only. Use the edit function to add addational links.
LiPoly Management
http://www.rcgroups.com/forums/showp...61&postcount=1
Salt water LiPo disposal
http://www.rcgroups.com/forums/showthread.php?t=592509
Balancers / Adapters and Associated Info.
LiPoly Storage / Shelf Life http://www.rcgroups.com/forums/showp...6&postcount=36
Overdischarged LiPolys
A primer on reading CBA Graphs here.
Why LVC is often hit early in flight.
Capacity versus open volts at 4.2 and 4.1 volts.
LVC versus remaing battery capacity.
11-08 Capacity versus open volts
Battery test are in chronological order. My newest ones at the bottom of this post.
E Tec 700 HP 2S at 75 cycles
E Tec 700 HP 2S testing continued.
An assortment of 1200-1500 3 cell packs http://www.rcgroups.com/forums/showp...5&postcount=23
Same of packs in link above but expanded graph:
E TecHP 1200, Thunder Power Gen2 1320, Kokam 8C rated 1500 http://www.rcgroups.com/forums/showp...9&postcount=22
E Tec 1200 6-7.5C ( old series / classic)
http://www.rcgroups.com/forums/showthread.php?t=325185
E Tec 700 HP 2 cell (7.4 v) [url]http://www.rcgroups.com/forums/showpost.php?p=3201962&postcount=1/url]
E Tec 1200 7.5C -PQ1500 10C- Kokam 1500 8C--Kokam 2000 20C[http://www.rcgroups.com/forums/showp...06&postcount=1
Tansmitter packs: 600 Nicads -2300 mAh Ni MH 2500 Graph added 9-8-05
http://www.rcgroups.com/forums/showthread.php?t=327288
Apogee 2080 mAh 11.1 at 9.5 A Dsch
http://www.rcgroups.com/forums/showthread.php?t=335705
E Tec 1200 Classic & HP 1200s-- Irate 1100 10C
http://www.rcgroups.com/forums/showthread.php?t=336374 @ 6A
Kokam 340 mAh 2 cell @ 2amps. http://www.rcgroups.com/forums/showp...9&postcount=46
Irate 1100 mAh 11.1 v at 6 A Dsch[
Irate 1100 (10C) 3S- Kokam 1500(8C) 3S @ 6 A
http://www.rcgroups.com/forums/showp...07&postcount=1
IRATE 1100 3S @ 2.2A 1st Dsch Loose cells from Cheap Batteries 3-4-05
http://www.rcgroups.com/forums/showp...24&postcount=1
IRATE 1100 3S @ 2.2-3.0-5.0A -8.0A Loose cells from Cheap Batteries 3-11-05 Updated 3-11-05 8 amp. discharge added.Same pack as directly above.
http://www.rcgroups.com/forums/showp...62&postcount=1
IRATE 1100 3S two ea. E Tec 1200 Classic & E Tec 1200HP 3S one ea.3-5-05
http://www.rcgroups.com/forums/showp...39&postcount=1
iRate 1100 3S from loose cells @ 6 & 8 amps. 3-24-05
Thunder Power 3S 730 Pro Lite (beta) Test#2 Discharges #43-92-150-200 at 6Amps. 03--06-05
http://www.rcgroups.com/forums/showp...&postcount=156
Tanic 1050 3S 3-7-05 Discharges @ 2.1-3.0-6.0 amps. Posted 3-8-05
http://www.rcgroups.com/forums/showthread.php?t=344337
Tanic 1050 3S -- IRATE 1100 3S Overlayed. Posted 3-8-05
http://www.rcgroups.com/forums/showp...tcount=1<br />
Tanic 1050 3S --- IRATE 1100 3S Both at 6A. Posted 3-8-05
http://www.rcgroups.com/forums/showp...38&postcount=4
E Tec 1000HP 3S 10C @ 10A Posted 3-9-05
http://www.rcgroups.com/forums/showp...14&postcount=1
Tanic 1050 10C 3S @ 8 amps. Posted 3-9-05
http://www.rcgroups.com/forums/showp...7&postcount=23
Tanic 1050 3S @ 8 & 10 A,
Tanic 1050 & IRATE 1100 3S @ 8A. Posted 3-11-05
http://www.rcgroups.com/forums/showp...16&postcount=6
Poly Quest 850 3S -- E tec 700HP -- TP 730 not ProLite @ 4A. POsted 3-12-05
http://www.rcgroups.com/forums/showp...45&postcount=1
Poly Quest 850 3S @ 4 & 6 amp. Dsch Posted 3-12-05 Dsch#24 added 4-26-05 / 5-24-05 Dsch.#41 added.
DuraTrax RC 2400 7cell NiCad @ 10Amps.
Thunder Power 2100 Pro Lite (Beta) Single Cell 2.1 - 25.2 Amps.
Thunder Power 1300 ProLite (Beta) 1S Posted 3-19-05
PolyQuest 850 3S & iRate 1100 3S Posted 3-31-05
E Tec 1200 3S Classics 4 ea. @ 6 amps. over 100 flights each. Posted 4-2-05
E Tec 700HP 3S versus Thunder Power 730 3S Gen.2 Old Thread but some how I over looked it. This Thread grew into TP 730 ProLite (Beta) Thread. Posted 3-3-05
Thunder Power 480 ProLite single cell.. 1-5A .. 5-24-05
Tronic 1250 15C / TP 1320 ProlIte (12C)
Thunder Power 3S 1320 Prolite #3 used paralleled in Mini Speed Wing 400. Dsch #20 @ 8Amps. Posted 6-26-05
Thunder Power ProLite 1320 #1 Dsch # 6 & 48 @ 8A. Posted 8-7-05 Updated 8-27-05 Dsch # 76 added. 01-12-06 Dsch # 125 added
Electric Power 3S 1600 mAh 12C Posted 7-16-05
Tronics 3S 1250(?) 15C Thread started 7-18-05
Tronics 1250 15C and Thunder Power ProLote 1320 13C
VAMPower 3S 1050 mAh 10C Thread Started 9-19-05 01-13-06 Dsch # 114 added
VAMPower 3S 1700 10C Thread started 10-15-05-
Hyperion VL 3S 1320 12C @ 8A 3-16-06
YUNTONG 2S 2000 mAh High Rate Discahre 4-03-06 Posted in Thread started by distrubitor
X-Power Gold( 20C (2DogRC) 3S 1000 mAh 4-10-06
Electric Power 20 C 3S 1000 mAh 4-15-06
VAMPower 740 20C? 1S
GP 3300 NiMH 6 cell stick packs @ 12A 5-10-06
Traxxas 1100 mAh and IB 1400 mAh 5 cells receiver packs.
Every Ready 2500 mAh NiMH 5 cell receiver battery @ 1 amp. 7-17-06
Sanyo 2700 / Energizer 2300 AA NiMH single cell.
Tenergy 2300 AA NiMH cell 8-06
Thunder Power Extreme 2070 single cell 8-23-06
GraysonPower 15C 3S 1250 8-30-06
M1 / A123 3cell pack 10-06
A123 M1 4 cell @ 8.5 amps. 10-16-06
A123 2300 Single cell @10-50Amps.
REVOLECTRIX 4S 3300
OUTRAGE XP 4S 3700 from HeliDirect
Thunder Power Pro Power 30C 3S 2250
Thunder Power Pro Lite V2 4S 3300
SMC 40C 3300
Thunder Power Pro Power 40c 3S 3250 mAh
2009 Test Start Here ------------------------------
SMC 40C 3S 2200 mAh
Hyperion G3 VX 35C 3S3300 5-18-09
06-09 Zeneee 30C 3S 2200
7-09 Poly No One 30c 3S 3300
Thunder Power Pro power 45C 8-15-09
10-8-09 Spyder 25C 3S2200
EM 25 3S 3300 10-12-09
10-25-09 Eflite 100 / 120 and Hyperion CX 120 single cell mSR batteries.
Thunder Power Pro Power 45 3S 2250 300 cycles at 40amps.
http://www.rcgroups.com/forums/showthread.php?t=1142882
EM 35C 3S 2200 12-09
http://www.rcgroups.com/forums/showthread.php?t=1154986
Thunder Power ProPower 45 extended cycle testing
2010 Test Start Here --------------------------------
May -2010 Thunder Power Pro Power 45 3S 850 5-20 amps.
http://www.rcgroups.com/forums/showthread.php?t=1241107
5-10-2010 Hyperion EX G3 2S test
http://www.rcgroups.com/forums/showthread.php?t=1242354
5-14-2010 Billowy 50C 3S 2250 LiPoly
Source added to first post in thread 8-5-2010
http://www.rcgroups.com/forums/showthread.php?t=1244249
5-15-2010 Billowy 40C 3S 2200 mAh LiPoly
http://www.rcgroups.com/forums/showthread.php?t=1244882
7-1-2010 Thunder Power pro Power 45 3S 1250
http://www.rcgroups.com/forums/showthread.php?t=1268823
8-8-2010 Thunder Power Pro Power 3S 2250 65C
http://www.rcgroups.com/forums/showthread.php?t=1272169
7-29-2010 Gens Ace 25c 3S 2250
http://www.rcgroups.com/forums/showthread.php?t=1283407
Sept 3 2010 Turnigy nano tech 45C 3S 2200
http://www.rcgroups.com/forums/showthread.php?t=1302258
10-23-2010XPS 65C 3S 2200
http://www.rcgroups.com/forums/showthread.php?t=1326707
2011
6-7-2011 Billowy 60C 3S 2600
http://www.rcgroups.com/forums/showthread.php?t=1452049
6-17-11 Billowy 50C 2S 3900 Hard Cased
http://www.rcgroups.com/forums/showthread.php?t=1457094
12-31-2011
UMX Beast type 2S E flite and Hyperion
http://www.rcgroups.com/forums/showp...98&postcount=1
Jan 2012 Haiyin 500 20C 3S 500
http://www.rcgroups.com/forums/showt...3#post20426812
HAIYIN 20C 3S 800 mAh
http://www.rcgroups.com/forums/showthread.php?t=1581812
If I am unable to add addational links to this post then I will place them here.
http://www.rcgroups.com/forums/showp...8&postcount=36
1-31-2012 UMX class 2S 25C HK naono tech 180
http://www.rcgroups.com/forums/showt...7#post20593156
March 3 ,2012 Turnegy nt 25C 3S 850
http://www.rcgroups.com/forums/showthread.php?t=1606725
Mar. 5,2012 Gens Ace 25C 3S 1,000 mAh
http://www.rcgroups.com/forums/showthread.php?t=1608572
5-1-2012mcp X class LiPolys
http://www.rcgroups.com/forums/showthread.php?t=1643704
July 2012 Blade 130X LiPolys
http://www.rcgroups.com/forums/showthread.php?t=1698288
10-2-2012 Misc. 3S 2200 at 30A Dsc. Blade 400 / 450 class
http://www.rcgroups.com/forums/showthread.php?t=1744125
Charles
Old Mar 14, 2005, 08:20 AM
unbalanced prop is offline
Find More Posts by unbalanced prop
unbalanced prop's Avatar
Washington, PA, USA
Joined Aug 2003
PolyQuest 1500 3S - 2C, 4C, 6C & 7.5C
unbalanced prop is offline Find More Posts by unbalanced prop
Old Mar 17, 2005, 09:49 AM
iflych52 is offline
Find More Posts by iflych52
Helena, Montana, United States
Joined Sep 2003
maxamps 1650
iflych52 is offline Find More Posts by iflych52
Old Mar 17, 2005, 06:55 PM
BEC is offline
BEC
Find More Posts by BEC
BEC
BEC's Avatar
Auburn, Washington USA
Joined Jan 2001
Fusion-Pack 900 and 1200 3s packs at several discharge rates
Kokam 15C 2000, 3s pack
Comparison of Apogee 1570 and Kokam 1250 HDR at 6A
CommonSense RC Budget Series 3s 1250 pack
BEC is offline Find More Posts by BEC
Old Mar 26, 2005, 08:56 AM
aeropal is offline
Find More Posts by aeropal
aeropal's Avatar
Joined Jan 2003
Powerizer 7/1100 2/3A NiMH
7/1100 2/3A NiMH Pack Comparison
7/1650 AA NiMH 2 Pack Comparison
aeropal is offline Find More Posts by aeropal
Old Apr 04, 2005, 07:19 PM
IA-Flyer is offline
Find More Posts by IA-Flyer
IA-Flyer's Avatar
Joined Nov 2003
Discharge graphs
Thunder Power 1320 Gen-2 lipo, 3s – ICE Discharge, Graph. (1.3, 6.0, 7.5A)
GreatPlanes ElectriFly 1200 lipo 3s – ICE Discharge, Graph. (failure after 6 flights, unknown reason)
Tanic 520 lipo 2s – ICE Discharge, Graph. (2.5A, Lifespan test, through 76 discharges)
Kokam 640 (15C) lipo 2s – ICE Discharge, Graph. (1.3, 3.2, 4.5A), (4.5A, Lifespan test, through 125 discharges)
Other graphs
lipo Capacity @ Voltage graphs
How temperature affects lipo batteries
Charger Graphs LiPo & Li-Ion (A collection of charger tests & graphs!)
IA-Flyer is offline Find More Posts by IA-Flyer
Old May 01, 2005, 01:27 PM
pmackenzie is online now
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
2S TP1320 at 5 and 10 amps
pmackenzie is online now Find More Posts by pmackenzie
Old May 06, 2005, 12:48 PM
ager1234 is offline
Find More Posts by ager1234
Joined May 2005
MP-1800mAh Li-Poly 8~12C test by CBA
ager1234 is offline Find More Posts by ager1234
Old Jun 02, 2005, 07:21 PM
ScienceGuy is offline
Find More Posts by ScienceGuy
United States, NY, Marion
Joined Sep 2001
CBA Tests
Tronics 1250 "15 C" lipo single cell
ScienceGuy is offline Find More Posts by ScienceGuy
Old Jun 06, 2005, 02:19 AM
myk is offline
myk
Find More Posts by myk
myk
myk's Avatar
Lake Sawyer, Washington
Joined Jul 2003
E-Tec 1000hp
myk is offline Find More Posts by myk
Old Jun 14, 2005, 11:46 AM
Draganfly is offline
Find More Posts by Draganfly
Draganfly's Avatar
Saskatoon, Canada
Joined Apr 2003
Thunder Power Pro Lite 480 2s
Thunder Power Pro Lite 730 2s
Thunder Power Pro Lite 1320 2s
Thunder Power GenII 730 2s
Thunder Power Pro Lite 910 2s
Draganfly is offline Find More Posts by Draganfly
Old Jun 21, 2005, 10:22 PM
Fishmasterdan is offline
Find More Posts by Fishmasterdan
Stanwood WA
Joined Jul 2003
Great Things 1200 overlay
Fishmasterdan is offline Find More Posts by Fishmasterdan
Old Sep 05, 2005, 04:33 PM
2dogrc is offline
Find More Posts by 2dogrc
2dogrc's Avatar
United States, NC, Vass
Joined Apr 2005
2dogrc Xpower batteries!
The data posted below is at least 1 year old! We are leaving the info up for comparisons form our old cells to newer cells..
Kokam 910 15C
My first graph 09-05-2005
Dualsky 2250 mAh battery, single cell, CBA II tester on a laptop. Connectors are 3.5 mm bullets.
Dualsky 2250
NEW Xpower 12C burst 20C 1320 Graph!
1320 3s 12C burst 20C
Dualsky Xpower 4000 mAh single cell. Check it out. I got 4300 mAh's out of it at 6C!
2dogrc's Dualsky 4000 Graphs
Dualsky Xpower 1700 2s! 12C rating burst 20C. Deans connectors.
2dogrc's Dualsky Xpower 1700 2s
2dogrc's Dualsky 1050 1s graph. Cell rated at 12C burst 20C. Temp at dicharge of 12C is 104F.
1-12C Discharge Xpower 1050 Battery
3s620 15C burst 20C Graph
Xpower Gold Series 1000 mAh 20C
2dogrc's Xpower 1200 20C Graph
New Mad Dog 1300 mAh, 2011
Mad Dog 520 Versus E-Flite Graph at 12C
2dogrc is offline Find More Posts by 2dogrc
Site Sponsor
Old Sep 09, 2005, 09:16 PM
Vamooska is offline
Find More Posts by Vamooska
Vampowered!
Vamooska's Avatar
Crestview Florida
Joined Dec 2003
These are the cells that make up my packs. THe cells are manufactured by Dualsky and assembled to my spec. More graphs are on the way.
Vampower BatT 2250ma 1-10C CBAII graph
Vampower BatT 1700ma 1-10C CBAII graph
Vamooska is offline Find More Posts by Vamooska
Discussion CBA Battery Graph Question sawicki Batteries and Chargers 7 Jul 23, 2007 07:59 AM
2dogrc Xpower 12C/20C 1320 Battery graph 2dogrc Batteries and Chargers 12 Nov 24, 2005 12:35 PM
Inappropriate posts in the Battery Graph Vault RD Blakeslee Batteries and Chargers 12 Oct 16, 2005 05:14 PM
Electric Power battery Graph Milton Batteries and Chargers 29 Apr 12, 2005 08:46 AM
