View Poll Results: who do you want at your party?
george w. bush 15 93.75%
john kerry 1 6.25%
Voters: 16. You may not vote on this poll
Old Mar 02, 2005, 08:49 PM
kevbeer is offline
Find More Posts by kevbeer
3d and other
kevbeer's Avatar
los angeles
Joined Jan 2004
3mm-depron biplane design (images)
Hello Hello,
After long (and failed) search for a local seller, I have ordered a lot of depron from depronusa.com, in 2mm, 3mm, and 6mm. It is very cheap per sheet (US $2.50-4.00 depending on thickness.) I am going to have 12 of the 19" x 29" 3mm (some grey some white) sheets at my disposal, and so I went ahead and designed a bi-plane that is somewhat like the Tensor 4d, which I currently own. Here are the images, tell me what you think. I narrowed down the side-force generators a lot, as I don't like how they make the tensor fly.
kevbeer is offline Find More Posts by kevbeer
Old Mar 02, 2005, 09:15 PM
skyhiflyhigh is offline
Find More Posts by skyhiflyhigh
los angeles
Joined Mar 2004
i can get 1/8th foamcor and 1/8 foamx over in cerritos at hilson specialty products for about 13 bucs a 4x8 sheet
skyhiflyhigh is offline Find More Posts by skyhiflyhigh
Old Mar 02, 2005, 09:26 PM
bamm is offline
Find More Posts by bamm
bamm's Avatar
Planet Jupiter
Joined Jan 2005
Looks like a Tensor
bamm is offline Find More Posts by bamm
Old Mar 02, 2005, 09:30 PM
sbmon is offline
Find More Posts by sbmon
Joined Aug 2004
Looks great!
Should fly nice and slooow.
If tail twist is still a problem like the tensor
maybe you could slightly increase the width of the horizontal fuse in the
rear, then add another piece of depron say 5x1 inches and bevel the sides and
lay them up from the horizontal fuse to the vertical fuse (like the new shocky's)
shawn
sbmon is offline Find More Posts by sbmon
Old Mar 02, 2005, 09:41 PM
kevbeer is offline
3d and other
kevbeer's Avatar
los angeles
Joined Jan 2004
sorry i left some stuff outta these pictures they are not at all the final design, just the depron and support rods. Like on the ikarus and tensor i own(ed) (ikarus is gone), i epoxy small triangular balsa molding along the vertical/horizonatl fuse junction, it helps a lot with the tail. this is directed in the ikarus kit, but not in the tensor directions. I'll most likely just use 2 5" pieces along the bottom, by the tail.
Old Mar 02, 2005, 09:47 PM
kevbeer is offline
3d and other
kevbeer's Avatar
los angeles
Joined Jan 2004
oh and bamm, it is basically the tensor except for a few things, I know. But i did adjust some wing and fuse dimension:
2 inches longer, .5 inch wider wings.
top and bottom wings are 1 or so inches closer together (vertically) for more prop wash.
side force generators have been modified greatly as seen.
support and landing gear carbon fiber rods are lighter and arranged differently.
Old Mar 02, 2005, 10:04 PM
adamg is offline
Find More Posts by adamg
adamg's Avatar
Saskatoon, Canada
Joined Feb 2004
kevbeer, have you played with the biplane wingform used by the ZN Line Evolution and the Quasar (i.e. ~straight TE, tons of LE sweep to make tip chord very small)? I flew an Evolution and its flying efficiency was incredible. I read somewhere that smaller wing chord makes wings more efficient through pushes and pulls.
adamg is offline Find More Posts by adamg
Old Mar 02, 2005, 10:32 PM
kevbeer is offline
3d and other
kevbeer's Avatar
los angeles
Joined Jan 2004
great point adam. I am going to cut 3 kits of this biplane, varying wing are and LE sweep, as well as vertical distance between wings. On one I will copy the quasar wings, only with bit more distance between the wings and a bit more wing area (a little wider from TE to LE.) the images show a wing shape i most likely won't use, but if i cut all 3 sets of wings to that shape, i got plenty of freedom to cut em down more (as I experiment.) thanks for the input.
Old Mar 02, 2005, 11:56 PM
kevbeer is offline
3d and other
kevbeer's Avatar
los angeles
Joined Jan 2004
hows this adam. I think this is the first version i will build. also put up some depron landing gear panels.
Old Mar 03, 2005, 12:32 AM
adamg is offline
adamg's Avatar
Saskatoon, Canada
Joined Feb 2004
It's a start. Here are pics of the Evolution to see the kind of taper I'm talking about.
http://www.znline.com/list_photos.ph...ource=produits
Old Mar 03, 2005, 02:27 AM
kevbeer is offline
3d and other
kevbeer's Avatar
los angeles
Joined Jan 2004
so here is the final design for the first one, with the yellow stripes only on top
Old Mar 03, 2005, 03:50 AM
kevbeer is offline
3d and other
kevbeer's Avatar
los angeles
Joined Jan 2004
heres how Im going to make the most of my sheets of depron:
Built up 3mm depron aerobatic/3D??? bcripe1 Foamies (Kits) 4 Sep 03, 2003 09:00 PM
3mm depron CAP MGoddard Foamies (Kits) 3 Sep 01, 2003 08:36 PM
Slice BlueCore into 3mm Depron localbuyer Foamies (Kits) 1 Jul 08, 2003 11:28 PM
For Sale Fs 3mm Depron Sheets CMT1961 Aircraft - Fuel - Airplanes (FS/W) 2 Jan 28, 2003 01:01 PM
Need help with flying wing biplane design stevenfrancis2000 Power Systems 11 Apr 07, 2002 05:01 PM
