Old May 04, 2001, 11:13 AM
sloflyer is offline
Find More Posts by sloflyer
IFOs & Zagis - love 'em!!
sloflyer's Avatar
Bothell (Seattle), WA USA
Joined Nov 1999
Micro servos
I'm planning on buying some more micro servos and trying to decide between the cirrus CS10 or the Hitec HS50, any comments?
They will be used in slowflyers and small HLG's.
sloflyer is offline Find More Posts by sloflyer
Old May 04, 2001, 11:16 AM
Bleriot is offline
Find More Posts by Bleriot
Bleriot's Avatar
Joined May 2000
Hi My experience with Cirrus(GWS) With Hitec Better qc I think and materials. Best Regards
Bleriot is offline Find More Posts by Bleriot
Old May 04, 2001, 11:29 AM
bhchan is offline
Find More Posts by bhchan
Electric Airplane Junkie
bhchan's Avatar
United States, CA, San Mateo
Joined Jun 2000
Don't forget the JR NES-241 and the new Airtronic something-something-091. I think the 091 can be had for about 20.00(wholesale is about 16.00)
Brian
bhchan is offline Find More Posts by bhchan
Old May 04, 2001, 01:11 PM
Fred Bronk is offline
Find More Posts by Fred Bronk
Our Daddy and Heli Junkie
Fred Bronk's Avatar
In Heli Wonderland
Joined Aug 1999
If power consumption is an issue, go with the HS-50's. They draw much less power than the CS-10's.
If your planes are light the power of either will be fine. We fly 5 lb planes with 30 oz servos, so a 8 oz servo on a 10 oz plane has lots of excess power!
Fred Bronk is offline Find More Posts by Fred Bronk
Old May 04, 2001, 03:13 PM
gnofliwr is offline
Find More Posts by gnofliwr
aka: A.Roger Wilfong
gnofliwr's Avatar
Novi, Michigan, United States
Joined Jan 2001
I'll ditto Fred on current consumption. As to out-door use, I use HS-50's in a DJ Aerotech Nymph (30" mosquito class) HLG. With no problems. I use the HS-55's (a few grams heavier) in RC/RG models - they handle 120 mph boosts just fine.
- Roger
gnofliwr is offline Find More Posts by gnofliwr
Old May 04, 2001, 05:31 PM
Larry Marshall is offline
Find More Posts by Larry Marshall
Quebec, QC, Canada
Joined Mar 2001
Originally posted by gnofliwr:
I'll ditto Fred on current consumption. As to out-door use, I use HS-50's in a DJ Aerotech Nymph (30" mosquito class) HLG. With no problems. I use the HS-55's (a few grams heavier) in RC/RG models - they handle 120 mph boosts just fine.- Roger
I'd second, or is that third this comment. The HS50s also have the benefit of having a flat on the output shaft and a matching one on the output gear. The Cirrus servos are press-fit which is fine until the gear gets loose.
I use HS50s for very light outdoor planes too but favor the HS55s for most outdoor stuff (and thing that's S280 or larger but smaller than a Cobalt 05) to get a bit more control surface moving power and because they're just cheaper. The extra bits of grams hardly matter in these models.
I was digging through my servo box yesterday and realized that the "big" servos I was moving out of the way while looking for smaller ones were Hitec HS80s. Times change.
Cheers --- Larry
Larry Marshall is offline Find More Posts by Larry Marshall
Old May 04, 2001, 06:35 PM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Hitec whatever. Got a problem, they make it right. Big corporations have learned that bending over to help a customer yields big payback in future sales and "for free" advertisement. Hitec must have gone to that seminar several times...that's enough "free" advertisement from me.. ....let's go fly.
hoppy
hoppy is offline Find More Posts by hoppy
Old May 05, 2001, 12:08 AM
PeteC is offline
Find More Posts by PeteC
Edmonton,Alberta,Canada
Joined Mar 2001
I would be cautious about using either of these on an outdoor model. They are REALLY small and quite fragile. IMHO I would be more inclined to step up a bit in size. The torque on these small servos is also quite weak compared to the larger ones.
PeteC is offline Find More Posts by PeteC
Current draw of micro servos Mike L Parkflyers 8 Sep 14, 2001 03:18 PM
Multiplex Micro Servos MX3 Reduced price NIB mecone Aircraft - Electric - Airplanes (FS/W) 1 Sep 07, 2001 03:35 PM
Multiplex MX3 Micro servos NIB mecone Aircraft - Electric - Airplanes (FS/W) 0 Sep 05, 2001 07:51 AM
JR 151 sub micro servos Keithw Power Systems 4 May 08, 2001 01:04 AM
Micro servos (which kind) sloflyer Power Systems 5 May 05, 2001 12:45 AM
