Old Mar 01, 2005, 04:09 PM
millerhill is offline
Find More Posts by millerhill
millerhill's Avatar
USA, VT, Brandon
Joined Aug 2004
What size servo should I use?
I just had a servo go south on me in my eStarter. I'm thinking it was maybe too small, but I'm not sure. It was installed as a single aileron servo. I thought that perhaps it got hung up in the wiring after a nose in or something like that and stripped the gears.
Is there an easy way of figuring out how much torque you need for a particular function?
Steve
millerhill is offline Find More Posts by millerhill
Old Mar 01, 2005, 04:14 PM
pda4you is offline
Find More Posts by pda4you
pda4you's Avatar
USA, TX, Trophy Club
Joined May 2002
On an e-starter it is unlikely you used too small a servo. Gears on the small servos are tiny, and they strip fairly easliy.
You can go to this site to check, but by my guess you would need a servo with 1.6oz of torque - anything can do that!
http://www.mbone.rchomepage.com/serv...calculator.htm
Go get a new gearset replace the gears and make sure the linkage is slop free and that the ailerons work freely.
Old Mar 01, 2005, 04:59 PM
millerhill's Avatar
USA, VT, Brandon
Joined Aug 2004
Thanks for the link. Very handy. I guess I can put just about anything in there from the looks of it.
Steve
Old Mar 02, 2005, 08:29 AM
pda4you is offline
pda4you's Avatar
Joined May 2002
Yep - I remember the days of standard servos being 30in/oz of torque and we used them for everything - one on ailerons on .60 size (7-10lb) ships was fine.
Today the kit manufactures and the radio manufactures are owned by the same parents and they want a servo on every half of a surface. Not bad when the high dollar digital stuff runs $70 a pop. I have seen planes where the servo cost exceeded the airframe cost!
Discussion taking a poll on what size servo ya'll want to use in "500" size heli geneween Electric Heli Talk 0 Mar 11, 2007 01:37 PM
Question What size servos should I use? ceejay flyer Scale Fuel Planes 1 Dec 30, 2003 05:33 PM
What size of prop should i use? kushal_22 Foamies (Kits) 1 Jun 16, 2002 02:13 PM
What flight pack should I use for the Lite Stik? xadmin Parkflyers 2 Nov 13, 2001 12:08 AM
What size prop should I use? ErnieR Foamies (Kits) 1 Sep 17, 2001 11:10 AM
