Old Mar 01, 2005, 11:05 AM
It's been a while.
Daniel G's Avatar
Irvine, CA
Joined Jan 2005
Reducing Noise
My wing warrior eZipper is pretty quiet most of the time, but when I fly full throttle it gets kind of noisy. I have heard that if you move the motor further away from the back of the wing the noise is reduced.
However, I can't move the motor further back than it is because my wing is already a bit tail heavy, so can I cut out some of the foam that is behind the prop to lessen the noise. Thanks.
Daniel G is offline Find More Posts by Daniel G
Old Mar 01, 2005, 05:26 PM
Marlborough, Massachussetts, United States
Joined May 2002
Yes, that does help. I cut out a half-circle, about 4" wide on either side of the motor mount on my zagnutz and it reduced the noise dramatically.
BrianRickman is offline Find More Posts by BrianRickman
Old Mar 01, 2005, 06:50 PM
It's been a while.
Daniel G's Avatar
Irvine, CA
Joined Jan 2005
Thanks for confirming my idea. I am going to try it as soon as my battery charges.
Old Mar 01, 2005, 06:52 PM
Average User
M Ashmore's Avatar
Bakersfield, California
Joined Aug 2003
I did the same cut out on my Zagi. Made a big difference.
M Ashmore is online now Find More Posts by M Ashmore
Old Mar 02, 2005, 01:51 AM
It's been a while.
Daniel G's Avatar
Irvine, CA
Joined Jan 2005
My charger lost the race against the sun.
But I made the cut outs and did some bench tests. The noise has significantly decreased.
Old Mar 02, 2005, 07:49 PM
Dr_DOM's Avatar
Whitby, Ontario, Canada
Joined Aug 2004
I would be interested in seeing a photo if you have one handy.
Dr_DOM is offline Find More Posts by Dr_DOM
Old Mar 03, 2005, 12:49 AM
It's been a while.
Daniel G's Avatar
Irvine, CA
Joined Jan 2005
Here are some pics.
Old Mar 03, 2005, 05:34 AM
Don Sims's Avatar
Outside of Dyer, Tn. USA
Joined May 2000
Cool idea. D Zipper, are the prop savers holding under all those RPM's??
Don Sims is offline Find More Posts by Don Sims
Old Mar 03, 2005, 10:33 AM
It's been a while.
Daniel G's Avatar
Irvine, CA
Joined Jan 2005
Yes, the prop saver works great.
My dad had the same motor and the prop got caught in the grass when landing. The bell of the motor was bent slightly, so now I use a prop saver. I have only had the rubberbands break once after a rather hard landing.
Old Mar 03, 2005, 05:17 PM
It's been a while.
Daniel G's Avatar
Irvine, CA
Joined Jan 2005
I managed to do a flight test at lunch time.
The plane, which I used to be able to hear quite loudly 200 ft away, now is almost inaudible doing WOT 200 ft away. This experiment is a complete success.
Old Mar 03, 2005, 09:08 PM
Dr_DOM's Avatar
Joined Aug 2004
Thanks for the photo. I can clearly see what I have to do to my zagnutz.
Old Mar 04, 2005, 12:09 AM
Ashfield, Sydney Australia
Joined Dec 2004
dont forget to put fiber back over where you cut , i trimed mine (cuth through the fiber tape) and it split about 3 inches during a crash.
tgmtgm is offline Find More Posts by tgmtgm
Old Mar 04, 2005, 12:19 AM
It's been a while.
Daniel G's Avatar
Irvine, CA
Joined Jan 2005
No problem DOM.
Tgmtgm I didn't have any fiber tape in that particular spot and have crashed often so I think I'll be fine.
Old Jun 09, 2005, 10:25 PM
BANNED!!!
soholingo's Avatar
Laurel, MD
Joined May 2001
Is this setup quieter than a tractor setup?
Jay
soholingo is offline Find More Posts by soholingo
Old Jun 09, 2005, 11:11 PM
It's been a while.
Daniel G's Avatar
Irvine, CA
Joined Jan 2005
It's about as quite as my slowstick with a gearbox, and that's the only tractor I have.
Discussion Reducing noise on motors ? philgib Blimps 5 Oct 26, 2006 05:55 AM
Any way of reducing the noise of the XRB ? brian.pedersen Coaxial Helicopters 7 Oct 04, 2005 03:16 AM
