Old Mar 01, 2005, 02:11 AM
abracadabra
abracadabra
Guest
n/a Posts
Flight School - RC Controls and Buddy Boxes
Do ALL RC control have built-in capability to
- plug in a slave buddy box ?
- act as both master or slave in a buddy-box set-up ?
- come with buddy box cable ?
- use a standard (uniform world-wide) socket & plug
format for doing this training linkup ?
If not built-in, can they ALL be retrofitted to do so ?
If not, which makes should be avoided because they
cannot be linked ?
Steve
Steve
Guest
n/a Posts
Re: Flight School - RC Controls and Buddy Boxes
See embedded replies.
Steve
No
Usually, if they have the trainer port at all.
No, none do that I am aware of.
No, every manufacturer is different, and generally only the same brand
equipment can work together as master and slave. (Hitec and Futaba,
plus the store brand from Tower Hobbies being the exceptions.)
No, it must be built in.
> cannot be linked ?
This isn't a brand issue so much as a model issue. The lowest end
radios sometimes do not have the trainer port. Similarly, if you bought
a very high end radio from a few years ago, you might have a 'DSC jack'
that will allow your radio to be a slave, but not a master. (But that
won't be a problem unless you are buying a rather old radio like my
Futaba 9V series.)
My usual advise to anyone who is getting into this addiction and
wants to know what radio to buy is: find out what your instructor uses.
Some brands are more popular in some regions of the world/country. If
you show up at the field with a brand new Futaba radio, and your club is
75% Airtronics and 20% JR, you will probably not find anyone to
buddy-box with. (Don't bother asking how I know.)
Old Mar 01, 2005, 04:11 AM
abracadabra
abracadabra
Guest
n/a Posts
Can you recommend a model in price
- mid-range ?
- top-range ?
I'll use their feature set as a basis for local comparison.
Is the number of channels an up-front decision ?
Can additional Channels be added later ?
Eric
Old Mar 01, 2005, 06:11 AM
Dr1
Dr1
Guest
n/a Posts
Do ALL RC control have built-in capability to plug in a slave buddy box
No, many lower-priced radios do not have the buddy box trainer port.
No, some radios can only be used one way. Sorry, I don't know which
ones.
None, to my knowledge.
use a standard (uniform world-wide) socket & plug format for doing this
training linkup ?
No. Hitec and JR use a standard mini plug. Futaba has used DIN plugs
in the past, and is now using a rectangular plug.
No. Some simply don't have the internal electronics, and on ones that
do, you'd need a schematic to do it. It will also void your warranty.
cannot be linked ?
Brands can not be mixed. Even some radios of the same brand can not be
mixed. Futaba is notorious for this.
The best thing to do is go out to the field where you plan to fly.
Look at the brands most others are flying. As said by another poster,
if your club is predominately JR, and you buy a Futaba, you're out of
luck. You do have the right to choose which brand radio you want to
fly, regardless. If you want to fly a brand no one else has, you might
consider buying your own buddy box. They are usually around $50-$100.
If you buy a lower-priced radio, you could even buy two and use one for
the buddy box, saving the flight pack for a future plane.
Dr1
Old Mar 01, 2005, 12:11 PM
Ted Campanelli
Ted Campanelli
Guest
n/a Posts
Ted shuffled out of his cave and grunted these great (and sometimes not
so great) words of knowledge:
I suggest getting whatever brand is used by the majority of the people
at your flying field. Different brands are popular in different parts
of the country.
> - mid-range ?
Mid range covers just about all the major brands from 5 to 8 channel
computer radios and one or two 9 channel computer radios.
> - top-range ?
EVO 12 channel, Futaba 14mhz
You are better off deciding how many channels above the basic 4 channels
you will need and get a transmitter with that number of channels plus 1
or 2 additional. The MAJORITY of fliers never use more than 8 channels
(actually it is more like 6 or 7 channels ). As far as features go, the
major brands offer similar features.
Yes
No. There are a few exceptions where you can go from 3 channel to 4
channel, however, these are low end transmitters designed primarily for
electrics.
> Thanks,
> Eric
Old Mar 01, 2005, 04:11 PM
Gavin
Gavin
Guest
n/a Posts
On Tue, 1 Mar 2005 03:33:55 -0500, "abracadabra"
> - mid-range ?
> - top-range ?
Go visit the club you intend to learn at (if you do), if they all fly
one brand of radio (my club is almost all futaba) then there is very
little point buying a Sanwa as you won't be able to use the buddy lead
facility unless you shell out for a slave box as well as your main tx.
You many even find someone who can sell you a used system as they have
upgraded to the next model up.
I think the Multiplex Evo system you can do a combination of firmware
updates that add channels and mechanically add the controls in, but
generally what you buy is what your stuck with.
It the very least you should consider a basic 6 channel comnputer
radio, the Futaba 6EXA (or 6XE) costs very little more than a non
computerised system (thats $180 in Tower), whereas the non computer 6
channeler is $150, and the basic 4 channel is $130). As you are stuck
with what you buy it may pay you to buy the better 6exa now than to
have to trade up in a models or two's time. If you need any sort of
mixing you need a computerised radio. (by mixing I mean an plane with
twin Aileron servo's or a delta type tailless plane)
>Thanks,
>Eric
Old Mar 01, 2005, 10:11 PM
abracadabra
abracadabra
Guest
n/a Posts
"Steve" <steve@nowhere.net> wrote in message
news:112824u695ilf17@corp.supernews.com...
Thank you VERY much. Lots of good marching instructions there.
Eric
abracadabra
abracadabra
Guest
n/a Posts
"Ted Campanelli" <tcamp@grumpyoldmen.com> wrote in message
news:bu0Vd.38114$by5.20801@newssvr19.news.prodigy. com...
Thank you for these helpful details.
Eric
abracadabra
abracadabra
Guest
n/a Posts
"Gavin" <gavin@mindless.com> wrote in message
news:i6l921hps8m8t72tuagboq5o1ji1umluac@4ax.com...
Eric
Old Mar 05, 2005, 08:11 PM
seagull
seagull
Guest
n/a Posts
On Tue, 1 Mar 2005 00:14:19 -0500, "abracadabra"
NO
NO
NO
NO
NO
>cannot be linked ?
NONE
Discussion RC flight school visits Elementary School rcfs Beginner Training Area (Aircraft-Electric) 3 Nov 19, 2006 07:35 PM
Question WTB-1st US RC Flight School Manuals - Set of 4 GCL Aircraft - General - Radio Equipment (FS/W) 1 Jul 19, 2005 03:05 PM
How do buddy boxes work? AirVenture Beginner Training Area (Aircraft-Electric) 7 Feb 07, 2002 09:14 PM
Coverting a free flight foam to rc Trobber Foamies (Kits) 2 Oct 06, 2001 04:41 PM
