This thread is privately moderated by 1987tc, who may elect to delete unwanted replies.
Old Feb 28, 2005, 08:34 AM
1987tc is offline
Find More Posts by 1987tc
Trader Rating: 201
Come fly with us in Henryetta
United States, OK, Weleetka
Joined Dec 2000
Trader Rating: 201
Todds Models Wing-E Built and covered.
Below is the information from Todds Website.
He has just anounced that he will no longer be producing any of his kits.
This models is covered in Transparent Blue,White, and Silver So-Lite.
Elevons are not hinged and fins are not glued yet for easier shipping.
I bought it to build. Got it done and enjoyed the build. If it sells great. If it doesn't I will get gear for it and fly it.
Wes
The WING-E was designed with a NASA flying wing airfoil and to use the inexpensive GWS products allowing you to fly at your local small field in the wind. The kit is 100% laser cut with 46 parts and a full supply of Sig & Dubro hardware. CAD drawn plans with written instructions allow the WING-E to be built in a short amount of time. The WING-E is capable of flying in winds that other slow and parkfliers would be grounded in. The WING-E will loop, roll, and fly inverted. Flight times vary depending on flying styles but with a 7 cell 300mAh Nickel Metal Hydride battery pack 10~13 minutes are normal.
Wingspan = 23 Inches
Wing Area 223 sq. in.
Weight = 6.5 oz.
Wing loading = 4.2 oz. sq. ft.
We found the best compromise of performance, flight times, and aerobatics were to use the EPU3 motor and APC 7x4 Slowflyer prop. A GWS EPP0650 will also work.
Other items needed to finish the Wing-E are:
EPU 3 (IPS-DX2BB-2XCS) Motor w/heatsink.
APC 7x4 or 7x5 Slowflyer prop.
ADC001 prop adapter.
Sub-Micro Receiver less than 10 grams.
Two HS-50 or HS-55 servos.
2 to 8 amp Electronic Speed Controller.
7 cell 300mAh or 370mAh NiMh battery pack.
Price is $40.00 + $8.00 shipping. I use lots of bubble wrap!
Paypal only please.
1987tc is offline Find More Posts by 1987tc
Old Feb 28, 2005, 08:58 AM
rpage is offline
Find More Posts by rpage
Trader Rating: 9
Somerset, Pennsylvania, United States
Joined Jun 2004
Trader Rating: 9
Nice looking build. How does the motor mount?
rpage is offline Find More Posts by rpage
Old Feb 28, 2005, 09:01 AM
1987tc is offline
Trader Rating: 201
Joined Dec 2000
Trader Rating: 201
There is a sort of stick mount. I say sort of because it is balsa with ply on each side. Motor then fits over that like on a lot of other planes. Reallly strong. It is glued on the bottom of the wing at the leading edge and sticks out enough for the motor/prop to clea the wing.
Wes
Old Feb 28, 2005, 11:45 AM
rpage is offline
Trader Rating: 9
Joined Jun 2004
Trader Rating: 9
So a puller not a pusher? Sorry if I am being dumb.
Old Feb 28, 2005, 11:58 AM
1987tc is offline
Trader Rating: 201
Joined Dec 2000
Trader Rating: 201
Correct. A puller ( tractor) set up not a pusher. And ask all the questions you want. The only dumb ones are the ones you don't[I] ask!
Wes
Old Feb 28, 2005, 12:06 PM
Tres Wright is offline
Find More Posts by Tres Wright
Trader Rating: 32
Live to ride... and fly!
Tres Wright's Avatar
Forney, TX
Joined Mar 2002
Trader Rating: 32
Wes, great job on yours! Very clean build. The Wing-E is a classic, it may become a collectors' item now that Todd has stopped production.
Rpage, as Wes said it's a tractor. The mount is designed for a GWS IPS motor mounted sideways. Other motors can be adapted to the stick mount. Here's a pic of mine showing how the motor tucks into the nose:
http://www.treswright.vervehosting.c...s/Wing-E-2.JPG
Tres Wright is offline Find More Posts by Tres Wright
Old Feb 28, 2005, 12:41 PM
echoplanar is offline
Find More Posts by echoplanar
Trader Rating: 12
echoplanar's Avatar
Lafayette, CA
Joined Aug 2002
Trader Rating: 12
pm sent
Jon
echoplanar is offline Find More Posts by echoplanar
Old Feb 28, 2005, 02:53 PM
1987tc is offline
Trader Rating: 201
Joined Dec 2000
Trader Rating: 201
Sold to Jon.
Sold Radical-Rc Micro Stick & Garrison Aerodrome Positron & Todds Models Wing-E Yardbee Aircraft - Electric - Airplanes (FS/W) 7 Nov 08, 2006 10:07 PM
For Sale Todds Models Wing-E tizken Aircraft - Electric - Airplanes (FS/W) 3 Nov 27, 2005 04:53 PM
NEW PJS 300 SF and Todds Models WING-E kit $85 shipped phoneguy Aircraft - Electric - Airplanes (FS/W) 3 Mar 11, 2004 09:53 PM
Todds Models Wing E dr.E Aircraft - Electric - Airplanes (FS/W) 10 Aug 17, 2003 11:29 AM
Todd's Models Wing E In Stock Azarr Parkflyers 0 Jul 17, 2002 05:03 PM
