Old Feb 24, 2005, 08:10 AM
United States, FL, Starke
Joined Apr 2002
UBEC 4.8V or 6V
Using the 6V vs the 4.8V UBEC will give higher torque and speed from the servos. Is that the only benefit? Are there a down sides to using the 6V UBEC over the more standard 4.8V?
Dave
Doc Data is offline Find More Posts by Doc Data
Old Feb 24, 2005, 08:36 AM
Jeff Meyers's Avatar
Fayetteville, GA
Joined Oct 2000
Your input voltage needs to be at least two volts over the output voltage for best results.....
The 6 volt UBEC will make your servos draw more current....of course....the benefit is more torque and speed...
Jeff Meyers is offline Find More Posts by Jeff Meyers
Old Feb 24, 2005, 11:48 AM
Airdrie, AB Canada
Joined Sep 2004
Some higher end digital servoes are not rated for 6v. Futaba tail servos come to mind. Many have been tested ok at 6v on a regulator.
If your servos can take it you might as well enjoy the extra speed and torque. It's a nice way of waking up some older, tired, gear you have lying around.
mjws is offline Find More Posts by mjws
4.8v or 6v philip m Radios 4 Aug 28, 2005 06:45 PM
graupner 4.8V or 6V or 7.2V ? oferwain Power Systems 6 Feb 15, 2004 07:41 PM
Question 4.8v or 6.0v servo? vpimike Beginner Training Area (Aircraft-Electric) 2 Dec 03, 2003 10:41 AM
Speed 400 4,8V versus 6V Zeroaltitude Power Systems 11 Jul 29, 2003 05:09 PM
