Old Feb 23, 2005, 08:39 PM
atzero is offline
Find More Posts by atzero
Newbie
Joined Jan 2005
Engine bogs down at full throttle/near top speed
I recently bought a Duratrax Axis with a .21 engine. It is broken in, has had about about 25-20 tanks through it.
The problem is when I try to take the car up to top speed at full throttle, the engine bogs down, and the car slows down. The car works normally when you give it full throttle, just not when trying to max out the engine at high speeds. Gudging by the sound, Im pretty sure its not hitting redline.
Could it be running too lean? I tried turning the high speed screw toward rich, and it still happens.
atzero is offline Find More Posts by atzero
Old Feb 24, 2005, 09:25 AM
danman91393 is offline
Find More Posts by danman91393
Where did the honey go???
Irvington NY
Joined Jul 2004
It may be to rich. I had the same problem. Or try to put it to factory settings
danman91393 is offline Find More Posts by danman91393
Old Feb 24, 2005, 03:56 PM
Dot-Rcu is offline
Find More Posts by Dot-Rcu
Joined Jul 2004
Have you checked that there is a clean path for the fuel form the tank to the engine no dents on the fuelline, filter is clean... I had the same problem and my engine was running to lean...
Dot-Rcu is offline Find More Posts by Dot-Rcu
Old Feb 28, 2005, 05:40 PM
atzero is offline
Newbie
Joined Jan 2005
ok, thanks for the input. I think it is running too lean, because it started bogging down after i put better intake tubing on it. I suppose the more air flow made the carb run a little lean. I havent had a chance to take it out again, but ill try resetting the carb settings for a little richer.
Concrusher shutting down at full throttle Pyrock Power Systems 9 Aug 01, 2005 10:39 PM
0.15 bogs down at full throttle stevesey Engines 4 Jan 30, 2005 12:26 PM
Castle creations and nippy shuts down at full throttle Goleith Power Systems 14 Apr 02, 2004 04:47 PM
Motocalc. Which line is the full throttle level top speed? Balin Power Systems 2 Nov 29, 2001 09:26 AM
ZAGI 400-X ; power cutting out to motor after flying at full throttle Joe-z Foamies (Kits) 29 Jul 15, 2001 10:51 PM
