Old Feb 23, 2005, 02:44 PM
Heli Mod Man is offline
Find More Posts by Heli Mod Man
---------Speed!!---------
Illinois
Joined Jul 2003
Spot light kit for night flying?! Strange or cool?
Hey guys, I figured I would show you what I whipped up recently. This all started with a trip to Menard's. I saw these perfect spot lights that run on 12 volts and put out 20 watts! These lights are blindingly bright! One light eluminates my entire front yard (small yard ). Anyway, I thought I would whip up some snazzy carbon mounts and I had a brainstorm. I came up with a simple adjustable mount system.
So, what do you think? I figure I could offer a basic generic light kit that could be used on pretty much any heli.
Cool, or just plain weird?
Matt...........
Heli Mod Man is offline Find More Posts by Heli Mod Man
Old Feb 23, 2005, 02:57 PM
grey is offline
Find More Posts by grey
Panic from above
grey's Avatar
Netherlands
That is SOO COOL!!
Very good idea you had there matt.
Like to see that illuminate the street at night. :d
I myself ordered some stuff couple of day's ago from this site http://www.elwirecheap.com/rckits.html
Grey
grey is offline Find More Posts by grey
Old Feb 23, 2005, 02:59 PM
Kilroy is offline
Find More Posts by Kilroy
Golf pig
Kilroy's Avatar
Ottawa, Ontario, Canada
Joined Mar 2003
Look like Kodak Carousel projector bulbs. Very bright indeed.
Kilroy is offline Find More Posts by Kilroy
Old Feb 23, 2005, 03:00 PM
CRAZYKEV is offline
Find More Posts by CRAZYKEV
CINCINNATI,OHIO - U.S.A.
Joined Nov 2004
I think they look cool and are probably really bright man!
Kev
CRAZYKEV is offline Find More Posts by CRAZYKEV
Old Feb 23, 2005, 03:17 PM
askman is offline
Find More Posts by askman
Destroyer of G-10
askman's Avatar
United States, OR
Joined Jul 2004
I think single light low, and another pointing at the rotor blade would be really cool for night flying. (or one inside the canopy, lighting it up) I've been meaning to do something similiar with super blight white LEDs, but always get sidetracked. I have a 24LED array that runs on 12V at home. draws 200 miliamps and about bright as 10watters....
askman is offline Find More Posts by askman
Old Feb 23, 2005, 03:19 PM
rkramer is offline
Find More Posts by rkramer
Frequent flyer
Grand Forks, ND
Joined Aug 2002
Although not quite up to your scale, there is only so much you can carry on a micro!
rkramer is offline Find More Posts by rkramer
Old Feb 23, 2005, 03:40 PM
aragon is offline
Find More Posts by aragon
Cape Town, South Africa
Joined Jan 2005
Sweet Matt. Those look like low voltage halogen downlighters. You should be able to get them in 50 watt too. But what is really neat is that LED based drop-in replacements for those lamps are starting to hit the streets - they're about as bright as the 20 watt halogens you have, but they use only 1 watt!
How difficult do you think it'd be to get your lights to tilt up and down?
Aragon
aragon is offline Find More Posts by aragon
Old Feb 23, 2005, 04:04 PM
Illinois
Joined Jul 2003
Thanks for the comments, Guys. It would be very easy to make it tilt.
So, what do you guys think about a kit? The bulbs are $2.50 each and each light assembly needs a set of Corona tail boom clamps at $8. So, I would have $21 plus about $8 of carbon in it. Hmm, I would have to get about $45 for a light kit. Is it worth it? Should I list this on my web site?
Matt...........
Oh, as for current consumption, it still only uses a couple amps. No biggie.
Old Feb 23, 2005, 04:15 PM
aragon is offline
Joined Jan 2005
That sounds reasonable I'd say.
I actually want to try find some info on the LED drop-ins. Those 20 watt lamps should draw about 1.6A continuous current, but the LED lamps probably only around 100mA. I'll post here if I find anything...
Aragon
P.S. Mind you, it should be easy enough to just stick a bunch of LEDs into a disc the same diameter of those lamps....
Old Feb 23, 2005, 04:18 PM
grey is offline
Panic from above
grey's Avatar
Netherlands
That would be with the carbon tube?
But what I don't really understand it the power. you say 12v so it wouldn't be possible to connect it straight on the tx. Do you use an extra battery for that?
Old Feb 23, 2005, 04:24 PM
aragon is offline
Joined Jan 2005
Connected directly to the main battery, parallel with ESC. The lights will be just a bit dimmer if you're using 8-cell NiMH.
Aragon
Old Feb 23, 2005, 05:05 PM
mikefaith is offline
Find More Posts by mikefaith
3dmp "It's Magical"
mikefaith's Avatar
Richmond, VA
Joined Jul 2004
Very COOL and reasonable......
mikefaith is offline Find More Posts by mikefaith
Old Feb 23, 2005, 05:17 PM
HoverBovver is offline
Find More Posts by HoverBovver
Scarecow
HoverBovver's Avatar
UK
Joined Sep 2004
Aragon
Google for "Mr16 LED"
Heres a few links...
www.sunbriteleds.com/product.asp?id=86
http://www.lightingfx.com/item--MR16...ulb--L12V16-WH
www.led-lightbulbs.co.uk
http://www.superbrightleds.com/MR16_specs.htm
HoverBovver is offline Find More Posts by HoverBovver
Old Feb 23, 2005, 05:21 PM
Illinois
Joined Jul 2003
Cool!
Matt.............
Old Feb 23, 2005, 05:36 PM
askman is offline
Destroyer of G-10
askman's Avatar
United States, OR
Joined Jul 2004
and if you want super lightweight bicycle lamp, there you are. I think you can market it to bicycle crowd as well. (have a set on your recumbent and mtb) BT stealth lamp. super light, super bright and just SUPER.... good job.
NAV light setup for Night Flying..... 2thDr Aerial Photography 9 Mar 24, 2005 08:39 AM
Mini Lights for Night Flying dmiller Electric Plane Talk 6 Nov 24, 2002 06:34 PM
Strobing Navigation Light Kit for Realistic Night Flying mcu-electric Parkflyers 70 Oct 05, 2002 04:46 PM
Voltages for night flying, or... Possessed BEC. citabria Parkflyers 5 Aug 22, 2002 11:20 PM
Strobing Navigation Light Kit for Realistic Night Flying mcu-electric Parkflyers 5 Aug 08, 2002 07:19 AM
