Old Feb 22, 2005, 06:41 AM
hamza_b is offline
Find More Posts by hamza_b
Australia, NSW, Ryde
Joined Dec 2004
How to connect BEC to RX
Hi guys,
I got my first electric plane today...only one question
on which channel of Receiver should i connect JETI controller too..its with BEC its a JES 012?...should it be on the throtle channel or should it be on battery.? also the battery is connected with JETI..
this is very confusing for me..please help!
cheers
hamza_b is offline Find More Posts by hamza_b
Old Feb 22, 2005, 07:34 AM
abenn is offline
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
The BEC lead from your speed controller goes into the throttle channel on your receiver. Your receiver doesn't care which channel it gets it's power from, but the speed controller needs to get a throttle signal (through the third wire) from the throttle channel.
Your battery connects to the heavy battery wires on your JETI (make sure it's right way round), and your motor goes onto the motor wires (doesn't matter which way round, you simply swap wires if the motor turns the wrong way).
abenn is offline Find More Posts by abenn
Discussion How to Connect an ESC & Separate BEC Model Aero Power Systems 16 Sep 25, 2009 12:57 AM
Help needed: How to connect 4th channel board to JMP Combo RX? Pjotrrr Scratchbuilt Indoor and Micro Models 2 Apr 03, 2004 01:17 PM
How to connect brushless motor to esc? bradpaul Electric Heli Talk 4 Jan 11, 2002 09:21 AM
How to connect aileron pushrod wires? Basketcase Parkflyers 14 Nov 24, 2001 11:56 AM
How to connect Futaba 240/401 to JR RX/Servo? WilliamSettle Electric Heli Talk 2 May 15, 2001 02:46 PM
