Old Feb 22, 2005, 01:33 AM
tjl is offline
tjl
Find More Posts by tjl
tjl
Joined Feb 2005
Brushless Motor for Yard Stick or Slo-V
Has anyone put a brushless motor in a Yard Stick or a Slo-V?
Would it make sense to do so?
I see the Slo-V as a good entry level photo platform and would like to upgrade to brushless for power and flight time.
Thanks for any ideas or information.
Tom
tjl is offline Find More Posts by tjl
Old Feb 22, 2005, 02:08 AM
snowball1288 is offline
Find More Posts by snowball1288
1Point Landing Specialist
Joined Nov 2004
I imagine it would make sense...
but if i remember correctly... the slow-v has integrated electronics... so all of it would have to be replaced in order to install a brushless ESC... new servos, Rx, ESC...while your at it, you might as well throw in a new battery. thats one heck of a costly upgrade... you might as well get a proven set up.. like a GWS slowstick.
I might be wrong... ive never owned a slow-V, but i believe its made by parkzone or hobbyzone or somebody that uses those "all-in-one" electronics boards rather than the standardized individual replaceable components.
It is easily do-able... just spendy.
You could get a slow stick... people put brushless motors and fancy cameras on those all the time.
snowball1288 is offline Find More Posts by snowball1288
Old Feb 22, 2005, 12:13 PM
jswjimmy is offline
Find More Posts by jswjimmy
Whatever happens..Happens
jswjimmy's Avatar
Sanford, Maine, United States
Joined Aug 2004
if you want a ap plane and are willing to go brushless go with a magpie or slow stick.
jswjimmy is offline Find More Posts by jswjimmy
Old Feb 22, 2005, 04:00 PM
Gibby is offline
Find More Posts by Gibby
Where's your CofG?
Gibby's Avatar
San Diego
Joined Apr 2004
I put a Himaxx 2015-4100 on my Yard Stick and run it with 2s lipo's. I think I have somewhere around 5:1 gearing with a 9x6 prop. That does pretty good but I should probably go with a 10x7 SF or switch to the 4:1 gearing. All in all I'm pretty happy with it. You can also run 3s on that but you obviously add weight to the plane.
Gibby
Gibby is offline Find More Posts by Gibby
Old Feb 22, 2005, 09:52 PM
slo_dave is offline
Find More Posts by slo_dave
Prying Open My Third Eye
slo_dave's Avatar
Kingsport TN
Joined Dec 2004
I own a Parkzone Slo V and can verify that you would have to replace "everything" to go brushless. It uses a combo ESC and Rx. and non standard 5-wire servos. It flies great even with a camera, but like Snowball said, If you plan on going brushless....go with the Slow Stick from the start. AP was just an afterthought when I bought my Slo V, if I'd have known that I would get the aerial photo bug..I would have opted for the Slow Stick w/brushless setup from the start.
Just me 2 cents
slo_dave is offline Find More Posts by slo_dave
Old Feb 24, 2005, 08:19 AM
tjl is offline
tjl
tjl
Joined Feb 2005
Yard Stic Slo-V
I have a Yard Stick on order from LHS and should have it tomorrow.
I still love the Slo-V, a great trainer that is fun to fly and will take a great deal of abuse.
I wanted to see what it was like to Roll My Own, and the Yard Stick seemed a good way to go.
The Slo-V has an 1180 GWS prop and the 7 cell battery pac.
Tom
Old Feb 24, 2005, 08:28 AM
hall woo is offline
Find More Posts by hall woo
Permanently Banned
San Jose Ca / RSA flyer
Joined May 2003
$55.00 Brushless ESC and Ball Bearing Outrunner
http://www.rcgroups.com/forums/showt...20#post3346020
Has a strong output shaft, won't bend like a GWS shaft
Flies 10 minutes using 7/4 prop and $6.00 surplus LI-ION pack 3S2P 2100 mah
hall woo is offline Find More Posts by hall woo
Sold 450 Brushless motor for Wattage EDF or similar EDF 3200KV motor NIB The Don Aircraft - Electric - Power Systems (FS/W) 0 May 01, 2007 05:12 PM
Brushless motor for Slow Stick..what's everyone using? Jimmy James Electric Plane Talk 49 Oct 20, 2005 12:45 AM
Himax brushless motor for Slow stick Hard Wiggles Power Systems 9 Mar 18, 2005 03:30 PM
What brushless motor for a Slow Stick rtn9105 Power Systems 8 May 18, 2004 06:41 AM
Which Brushless motor for the Slow Stick? stu78 Parkflyers 0 Aug 13, 2003 11:07 AM
