House of Balsa FW-190
With one of the new electric power systems available today, the House of Balsa FW190 is a sweet flying airplane. HOB kits in general are straight forward to build, easy on the pocketbook, look great in the air, and are great flyers, and the HOB FW190 is no exception.
Specifications
  • Wingspan: 36 in.
  • Length: 28.5 in.
  • Wing area: 216 sq. in.
  • Flying weight: 22 oz.
  • Wing loading: 14.7 oz.
  • Prop: APC 8x6E
  • Servos: 2 Cirus 20 or Hitec HS-55 servos
  • Speed controller: Jeti 18 brushless
  • Motor: Mega 16/15/7
  • Battery: 8 cell 600AE or 1100 mAh NiMH
  • Receiver: Hitec 555 or Supreme 8
  • Available from: House of Balsa
A couple of years ago, I built a House of Balsa P-47 for electric use. Flying the airplane with a long can 400 with an 8 cell 600 AE pack was OK, but nothing to write home about. The airframe was solid with very good flight characteristics, but lacked a little on power and a lot on duration. With improvements in motors and batteries, I though it would be a good time to revisit this group of airplanes that House of Balsa has been manufacturing since the beginning of time. (...what I heard from the old timers.)
House of Balsa has produced these 1/12 sport standoff scale airplanes for use with .049 to .061 gas engines for a very long time. They have the FW190, the 109, P-47, and P-51 available, and all are similar in size and weight. The kits are die cut and include all the wood with a hardware pack, decals, instruction book, and plan set. The instruction book contains photos of each step, which make construction easy to follow.
These kits are also very reasonably priced. The wood is not quite as light as some other kits I have built, but not bad. I built a kit from another manufacture a few months ago, and the wood was lighter. In fact, it was so light, I broke about a third of the parts just building the airframe. I fly most of my war birds on grass that is usually too deep for landing gear, so this airplane will be built without landing gear for bungee launch, like the rest of my fleet. For those that have not built many kits, I will follow the order in the instruction book in this review as much as possible so that you may use both for reference.
Construction
Building the fuselage
Start by laying out the fuselage side pieces. Make sure you have a right and left side when you glue on the forward doubler and the center light ply pieces. We will save most of our weight when building the fuselage. This light ply is needed around the wing area for strength; however, it may be more that we will need for an electric airplane. Feel free to cut holes in this area to lighten the sides. Place the fuselage top crutch on the plans and mark the bulkhead positions. Glue bulkheads number four and five into position. Glue the prepared fuselage sides to the top crutch, and join the rear fuselage sides together. The firewall is quite thick and most of this wood is not needed. Cut out the center before gluing into the fuselage. You are now ready to add the 1/8" square support to the fuselage bottom front and rear. Glue in the screw hold down plate under the 1/8" square stock. Skip the next sections on the tail wheel. For bungee launch, it's not needed. Glue in the triangle stock in the front of the fuselage. Most of this will be sanded away when you round off the nose of the airplane. Glue the front two cowl opening rings together and add a standard 400 light ply motor mount to these pieces. The light ply motor mount and a couple pieces if 1/64" light ply for the fillets are the only wood not in the gas kit that I needed for electric conversion. Once the motor mount is in place, glue the cowl rings to the front of the fuselage. Down thrust is already built in.
The next step is building the bottom hatch. This hatch will come in handy when charging you battery. You will have enough access to charge the battery without removing the battery from the airplane if you wish. Mark and glue the ply hold down plate to the hatch block. Put the bottom hatch onto the fuselage and drill a 1/8" hole through the hatch block and both hatch plates. Epoxy a 4/40 bind nut on the inside of the fuselage holding plate. Enlarge the hole in the hatch base with out going through the hold down plate to accommodate a washer and bolt. Glue the outside doublers in place on the fuselage sides. A pre-shaped balsa block is glued on the top of the fuselage. Cut the inside of this block out before gluing it down. This is another good place to save a little weight.
Set the top structure base deck on the plans and mark all the canopy parts. Tack glue the 1/4" square stock to the bottom of the base deck. This will come off later. This is used only to aid in gluing down the plastic canopy in a couple of steps. Glue the instrument parts and the headrest onto the top structure. Included in the kit is a thick paper sheet that contains a cutout section for the canopy, instrument panel, and several templates for other parts of the airplane. These are a nice aid in building this airplane. Now is the time to paint this section prior to adding the plastic canopy top. If you want to add a pilot, now is the time. I use liquid mask to cover the top of the canopy. I find it much easier than masking. Lightly sand the inside base of the canopy top in order to scuff the plastic canopy prior to gluing it to the top structure. The 1/4 stock you tacked glued earlier will allow you to pin down the canopy top to the table while gluing it to the top base.
Once the canopy top is dried, pull off the 1/4" building crutches, and trim the plastic canopy to match the base plate. Glue the assembly to the top of the fuselage. With the bottom hatch in place, you can now sand the entire front of the fuselage to shape. There is a paper template for contouring the front of the nose. Cutout and shape the cowl bumps and glue to the sides after you have completed the sanding of the nose.
Wing construction
Lay a piece of wax paper down on the wing portion of the plans. You build the wing directly on the plans to ensure it is straight. You can also build both sides at the same tine if you wish. Pin down the bottom leading and trailing edge sheeting. Glue a piece of 1/8" square onto the back edge of the leading sheet. You will now set ribs two through nine on the spar and the sheeting. Only glue the ribs to the trailing sheeting at this time. You will need to bend the leading edge sheeting up before gluing later. Glue the top 1/8" top spar in place. Add the 1/16 X 1/4" leading edge along with the 1/8" square trailing edge. Add the 1/16" top trailing edge sheeting. You can now glue the bottom leading edge sheeting to the leading edge and spars. Next, add the top leading edge sheeting.
Glue in the angle guides for correct dihedral. You may want to lay these pieces on the plans for reference to ensure you have them the right direction prior to gluing. Add the angle guides and glue in the number one ribs. Glue on the 1/4" X 3/8" leading edge. Sand the interior surfaces of both wing pieces to ensure a smooth bond. Epoxy the two wing halves together with a total of three inches of dihedral.
Using the plans as a guide cut the inboard trailing edges from the trailing edge stock. Grove the forward edge and install the aileron linkage. The linkage pieces are different lengths. Make sure you get them in the correct side. The linkage is pre-bent and easy to install. You may want to put a small amount of oil in each end of the brass bearings on the linkage to ensure you don't get glue in them. Glue the trailing edge assemblies to the wing. Add inboard leading edge fillets and sand the leading edge. A sample of the edge contour is shown on the plans. Cut out wing tips from supplied blocks using the provided templates, glue them onto wing, and sand them to shape. Using reaming aileron stock, make ailerons and sand them to shape.
Prior to covering, fit the wing to fuselage and sand as necessary for fit. The wing will attach to the fuselage by adding a 1/8" dowel to the front and by drilling and mounting a bind nut in the rear. There are heavy paper templates for the wing fillets. I used 1/64" ply instead. I thought this might be more durable if I took the wing off very much. To build the fillets, first place a piece of wax paper between the wing and the fuselage. Slide the fillet base in place on top of the wax paper. This will keep the fillets from sticking to the wing as you build them. I used light filler to form the fillets. When dry, sand and seal to get a good paint finish.
Tail assembly
Since I plan to bungee launch this airplane, I decided not to add a functioning rudder. If you choose to go this route, just glue the rudder pieces together and cover. The elevator is joined with 1/8" dowel, and then the edges are sanded and covered.
Covering
I used Ultracote Light Clear to cover this airplane. I wanted to keep it light as possible since was planning to paint the entire plane. The covering job is pretty straightforward. One caution to the builder should be mentioned. When covering next to the plastic canopy top, do not use too hot of an iron on the plastic or it will warp.
Painting
I like to use Model Master Acryl for painting. I lightly scuffed the surface to be painted to promote adhesion for the paint. These acrylics are fast drying, easy to clean up, and come in a large selection of colors. Prior to painting, make sure you have added an air intake hole in the nose and an exit hole in the bottom of the fuselage. I can paint an entire airplane in an evening with little mess using acrylic paints.
Installation of gear
The Mega motor will bolt directly to the Speed 400 light ply mount, and there is ample room in the nose for the motor.
You will need to add a sheet of scrap under former four with Velcro to hold the battery. I used two servos; one is for the ailerons and one is for the elevator. There is ample room for a rudder servo if you decide to add a working rudder to the plane.
There is plenty of room in the fuselage for receiver and speed controller. I put the receiver directly in front of the elevator servo. Control throws were set as recommended in the instruction book at 3/16" ailerons and the same for elevator.
The House of Balsa FW190 is a sweet airplane to fly. The first flight was fast with plenty of power with an 8X6 prop. It seemed I had the CG slightly forward, so the first flight ended early at about five minutes. After adjusting the CG slightly, the 1100mAh NiMH pack was recharged, and the plane was ready to go. This pack, from Wattage, has been highly touted on a couple of threads on E-Zone. It was great. The FW190 flew very fast and very stable. Outside loops were even possible. The rolls were smooth, and I just did not see any bad flying traits from this airplane. To check for duration, the airplane was flown to BEC cutoff. I usually don't run an airplane down to empty in case I need another pass for landing, but I wanted to get a good estimate of duration with this motor and battery pack. A full nine minutes of flying was achieved on the setup. I was thrilled. It is a great flying war bird, with more power than before, and more than double the duration of my old P-47.
The House of Balsa FW190, with one of the new electric power systems available today, makes a great flying electric war bird. The kits are straightforward to build, easy on the pocketbook, look great in the air, and are great flyers. I'm sure these were good gas flyers, and that is probably why they have been around for so many years, which is lucky for us electric flyers. I have heard of other electric conversions from this series of airplanes where the builders are replacing pieces with lighter wood. I really don't think it's necessary with the new motors we have available. Save weight were practicable, build it, and go have fun. I have already started the P-51, and will be building them all I'm sure. All I need now is for HOB to add a spitfire and a Zero to this collection and I'll be set.
Old Aug 21, 2009, 07:49 PM
wallace Becker is offline
Find More Posts by wallace Becker
Conn.
Joined Jun 2009
FW190 weight
When you were done with all the modifications, what was the flying weight of the plane with all components installed?
wallace Becker is offline Find More Posts by wallace Becker
Old Aug 21, 2009, 07:51 PM
Conn.
Joined Jun 2009
Disregard, the first section was slow downloading, sorry.
Old Sep 06, 2009, 05:47 PM
ihaveahellcat is offline
Find More Posts by ihaveahellcat
ihaveahellcat's Avatar
Joined Sep 2009
That Looks really good
ihaveahellcat is offline Find More Posts by ihaveahellcat
Old Mar 04, 2014, 03:14 AM
wojethebest is offline
Find More Posts by wojethebest
IT"S A PLANE NOT DOGFOOD
wojethebest's Avatar
Australia, VIC, Hampton East
Joined Feb 2013
I have a few questions
1 will 9g servos be fine
2 does this have a balsa i would need because the contents seem a bit small
3 i have a 1534kv engine and what prop should i get(keep this in mind i will have to fly at dendy park Victoria Australia)
Thanks in Advance
wojethebest is offline Find More Posts by wojethebest
Old Mar 04, 2014, 07:57 AM
jbest is offline
Find More Posts by jbest
jbest's Avatar
albuquerque
Joined Sep 2001
9g servos will be fine. Looking back at the pictures I believe all of the wood is there. The wing fillets were added so no wood is provided for those. In addition the light ply motor mount for the electric conversion was not in the kit. We fly at 5000ft elevation so a larger prop is in order. I'm guessing you are going to use a 7X4 or a 6X5 prop. I have built several of these after the article was done and they can be built in the 18oz range which improves their manners and ability to hand launch with ease. Hollow out all the balsa blocks as they are heavy. You can ditch the light ply on the fuse sides also for weight reduction. Lipo batteries will save you some weight over the batteries we used back then.
jbest is offline Find More Posts by jbest
Old Mar 04, 2014, 11:19 AM
E-Challenged is offline
Find More Posts by E-Challenged
E-Challenged's Avatar
United States, CA, Garden Grove
Joined Oct 2000
Years ago at Mile Square Park a guy flew a HOB 190 on an OS .10 and did beautiful rolling circles and figure 8's. I built the P-51 with Tee Dee .049 power with mini-Cannon RC gear. An expert flew it well, and I rekitted it. I have developed bettter tail-dragger technique since then. I have the HOB V-tailed Bonanza kit. May give it a whirl with electric power and light weight construction, covering, and modern V-tail mixing.
E-Challenged is offline Find More Posts by E-Challenged
Old Mar 04, 2014, 02:46 PM
jbest is offline
jbest's Avatar
albuquerque
Joined Sep 2001
Not to change the subject but I'm about ready to build that one soon also.
Old Mar 04, 2014, 04:18 PM
Joined Feb 2013
Thanks for the very fast reply I will be buying one soon (anyone got any good deals)
Edit: I just happened to have a 7x4.5 prop so no need to buy one (in a green puke colour but that can easily be painted)
Old Mar 04, 2014, 08:46 PM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
Have built a 'few' HOB 1/2A planes.. Back in the mid late '70-'s though
Those were Heavy! and needed an 0.10 to fly decently
There are several fw190 plans on outerzone.
All of which will build into a model that will be 7/9 ounces 'dry' and fly accordingly.
There is obviously some current effort to bring House Of Balsa back into the mainstream (retirement funds? dunno)
No issues with that. It was a reputable brand.. in 1976
But a re-engineering of their Kits (beyond punching a few useless 'lightening' holes in the parts) is needed for that to happen.
Bare is offline Find More Posts by Bare
Old Mar 05, 2014, 12:23 AM
Joined Feb 2013
I dont want to go to all the trouble of buying all the balsa i just want to get a kit so i know i have everything need and the house of balsa is the only fw 190 i can find(i want single engine german prop and i prefer it over the 109)
Old Mar 05, 2014, 06:17 AM
jbest is offline
jbest's Avatar
albuquerque
Joined Sep 2001
Sorry, I'm already retired living the good life, no agenda here.
Old Mar 05, 2014, 06:59 AM
tsymonds is offline
Find More Posts by tsymonds
Snappy Title On Backorder....
tsymonds's Avatar
United States, TX, Killeen
Joined Jun 2011
They've been reengineered much more than just punching some holes here and there. It's all laser cut now and the wood selection is quite light and of good quality. First one I built was in the early '90s and it was a tank. All the parts were die crushed and made from steel plate. The -190 I'm building now is basically a different kit compared to the first. Mine is getting modded to a TA-152 with retracts and I expect it to fly quite well based on how the earlier ones flew even at the heavier weights.
tsymonds is offline Find More Posts by tsymonds
Old Mar 05, 2014, 07:24 AM
jbest is offline
jbest's Avatar
albuquerque
Joined Sep 2001
I knew House of Balsa's new kits were laser cut with light wood but was not aware they had gone back and changed the 1/12th series birds. 15 years ago there were a few cottage companies doing electric warbird kits, Jim Ryan kits come to mind that were setup for electric. Most are gone now. It was a slim choice for electric. If you wanted a particular bird you either built it from scratch or converted a gaser. I'm not sure that has changed for balsa. Now you can now have about any warbird you want as long as its foam. Balsa full kits not so much. I think there is a short kit for a FW190 on Manzano laser's web site but again it's a short kit, your going to have to chase some wood.
Old Mar 05, 2014, 10:30 AM
Joined Oct 2000
The desire to buy or build a certain scale model often overrides the person's building and/or piloting experience level . Converting a small model warbird design, intended for small IC power, to electric powered RC, and getting it to fly well, may be too much of a challenge for some, but will be a learning experience, regardless. Small models like the HOB 190 need to take off, fly and land at fairly high speeds to avoid stall crashes. Getting the model through the maiden flight in one piece is the hardest part. Just sayin!
PS: It doesn't look like HOB has redesigned/lightened the 190 and rest of 1/12 scale warbirds for electric power. If you build the 190, hollow out any blocks of balsa and use light weight iron-on covering. Mount battery pack and RC components forward enough to minimize any need to add ballast to the nose. Keep aft fuselage and tail parts/tail wheel assembly light. Don't attempt to fly tail heavy!!!
House of Balsa FW-190 NIB badbill Aircraft - Electric - Airplanes (FS/W) 3 Aug 30, 2004 08:33 PM
FS: House of Balsa FW-190 Ready to Fly Slope Nut Aircraft - Electric - Airplanes (FS/W) 4 Mar 01, 2003 03:19 PM
House of Balsa FW-190 dave_lilley Sport Planes 0 Nov 12, 2002 10:13 PM
House of Balsa FW-190 dave_lilley Site Chat 0 Nov 12, 2002 10:13 PM
